Adaptive grille ahutter
I found another Part Number reference and a link that relates specifically to Fabia Mk4 models. This drawing shows the 'radiator louvre' assembly and there's no real doubt about what it looks like and its position on the car. There's a Skoda Fabia Owners Club Facebook group and (when I have a moment) I'll ask owners of Mk4s if their cars have the cooling-shutter unit and, if so, which country their car was bought in and its age and specification.
o4vrs joined the community
Kastek started following Felicia MPI: Strange Front-End Noise – Brakes & Bearings Replaced
Hi everyone, I have a Skoda Felicia MPI, and I have been trying to diagnose a strange noise coming from the front of the car for quite a long time. I have attached a video so you can hear the noise. The noise sounds like a metallic scraping or rubbing noise. It does not happen all the time. Sometimes it starts while driving at around 60 km/h, and other times it starts at around 80 km/h. The most noticeable thing is how the noise changes when I turn the steering wheel: When the noise starts, turning the steering wheel slightly to the right makes it stop. Turning the steering wheel slightly to the left makes the noise start again. Turning further to the left makes the noise stop again. Lightly pressing the brake pedal also makes the noise stop. I have already replaced the front brake discs, front brake pads, brake caliper pistons and wheel bearings, but the noise is still there. Has anyone experienced a similar problem on a Skoda Felicia or another car? What would you recommend checking next? I would really appreciate any suggestions, especially from anyone who has experienced the same symptoms. Thanks in advance!
I need Bolero Update :-)
Link to download MST2_EU_SK_ZR_P0253T sent in PM. If you want you can donate The Great Orchestra of Christmas Charity
CORNELCLR joined the community
Octavia VRS Mk4 - real life MPG
I've lived with mine for 3.5 years now and get anything from 11.6 km/l to 13.8 km/l in mixed driving in Christchurch, NZ. Apologies, you'll have to do the conversion to Imperial units on your own. It is quite frugal but has the grunt when you need it. Hope the above helps in your decision.
CKO started following Octavia VRS Mk4 - real life MPG
KodiaqMike21 joined the community
Skoda fabia 1.4 vrs (dq250 swap) help!
Hi my name is Josh, I am doing a skoda fabia 1.4 vrs 2010, rebuild. I am not doing a rebuild because of piston ring land failure, but more as a prevention measure. I noticed there is not much videos on YouTube. So I am documenting it to post for others to see. I will keep you guys who want to see the video updated when I upload it. I wanted to do a DQ250 swap. But it's hard finding a guide or a post of what was done from start to finish. I know I need a DQ250, but is it only the DQ250 from a 1.4 tsi like the touran 1.4 tsi dsg and the golf mk5 1.4 tsi dsg (DQ250) that will fit? Or will others fit from the 2.0 tsi and 1.9tdi/2.0 tdi group fit? I read somewhere the left side drive shafts is fine to use from the DQ200 but, will need different drive shafts for the right side. From what vw/audi car? Or does it need to be a custom drive shaft for that side? Also the shifter, can the DQ200 shifter work on the DQ250 gearbox? I understand about the flywheel, starter motor, DQ200 to DQ250 plug, coding and the oil cooler. If someone who has done this mod before, can you please get back to me. I would really appreciate it. Thank you
Rustyhud started following Skoda fabia 1.4 vrs (dq250 swap) help!
Interior door handle LEDs not working on the right side
Found the problem! The window regulator motor had been replaced by the previous owner, along with the door control module, with a different version that didn't have the wiring output for the door handle lighting, gotta replace it with the original one
- Yesterday
2021 iV - Brakes are poor - Suggestions?
It might just be one of those things. After driving the Ibiza around for a week (one breath on the pedal and you fly through the windscreen), I almost pulled out on someone in the BMW as I midsjuged the brakes! Bear in mind too, that the response is no indication of stopping power. The Ibiza has something like 276mm discs and titchy calipers, while the BMW has 360mm discs with 4-pot calipers.
Are front doors the same on estate & saloon?
I'm 95% sure the front doors are the same. If you look up the part numbers, are they different?
OccyVRS started following [sold] 2010 Octavia VRS TFSI DSG Black , Are front doors the same on estate & saloon? and Retrofit
Retrofit
For coding, remember you'll need to add the cornering light function too.
Not interested, but just wanted to say what a well-written advert this is! Best of luck with the sale.
- Scala SE L 2024 Infotainment unit updates
Rustyhud started following thomasaspin
Joreri18 joined the community
Hi @pab567 Could you possibly send me "mst2_eu_sk_zr_p0253t" for my headunit please? Do you have some kind of PayPal / Buy me a coffee donation set up? Thanks! Jim
skoda superb 2.0tdi not reaching operating temprature
PROBLEM SOLVED! Just replaced the main T-stat with an oem MHALE wich is the producer for VAG. The one i replaced first was a Myle brand. I think what happened is i got a bad myle t-stat that worked for a while but the dsg stat was bad. I then replaced the dsg stat but by the time i did that the myle t stat had failed. Then. Just buy Oem parts. It will save you so much trouble. Hope this helps somone.
Enyaq 85 sel 2026 tyre pressures
The Ice Scraper has moved to the lower lefthand edge of the boot lid (when open). It won't fit in the EV "filler flap" anymore, since the fitting of the big rubber socket seal on the flap door.
thepuss started following Enyaq 85 sel 2026 tyre pressures
Is this the perfect spec Superb?
With the Donald inflated fuel prices, I think a car with the economy of the Greenline is the perfect spec. And even if diesel were £1.40 a litre, there's still a lot to be said for stopping for fuel every 700 to 800 miles.
Lindsayt started following Is this the perfect spec Superb?
Retrofit
But there are 3 pins on the LED lights and only 2 on the halogen. Unless i connect the LED just as straight forward on/off fogs. Is that possible?
No GPS Reception
You hv a NAV button so you have an Amundsen MIB1 map updates stopped 5 years after the MIB1 ws last used in production, which was early 2015 - so the 2020/2021 update is the most recent available for MIB1.
- Where is my oil light!?
Advice please on DMF
its a big job but can be done on the drive at home i did mine over an easter weekend. front in the air on axel stands the hardest bit was getting the gearbox back in i had a helper for this part of the job. i have done many clutches in the past the clutch i used was an ebay solid flywheel kit one.
landroverbodger started following Advice please on DMF
VIN now provided and the ETKA page entitled "Radiator louvre" is greyed out for this car, indicating non-fitment of those items.
Retrofit
Make your own adapter. Buy the connector, pins, wires, and automotive-grade electrical tape, and you’re all set to go.
Hello there.
Thank you. Hopefully, we should be set for a few years!
