Fabia mk2 Repair Manual to inside Boot panel to access Fuel Filler Flap Locking
Me neither - ours has a lockable filler cap.
- Constant app updates
I had no idea they locked with the central locking.
What are they?
thanks for all the replies.
- Spacesaver spare wheel
SD cards and the Amundsen infotainment system.
Quick update: I'd had the sense to back up the old map files on the Skoda SD card. I formatted the SD card to FAT32 and put/copied them back onto the card. Then I deleted the two files the Mac seems to have added. I put it back in the unit and I have maps back, even if well out of date and limited to UK and parts of Europe. They will do for now - but I still need to get this thing updated and new maps installed. If there is a Firmware update and a 'patch' that will get round some of these issues, I would be very grateful for the information on how to do that.
Windows, Mirrors and Doors Issues
Where the door wiring loom passes from door to A pillar is definitely a know cause of door related electrical problems and is usually only a matter of time before continual flexing of the drivers door loom (which obvious gets used more than other doors, except I guess in a taxi) causes a wire to break and give problems. Mine went at 93K miles at the start of COVID. Just shut off main speaker in driver's door (initially thought I'd gone deaf in right ear :-) but depending on wire that breaks, can affect any door as I believe main module for controlling all doors lives in that door. There is a design flaw in original door looms where the wires are slightly too short and hence flex excessively / kink rather than bending smoothly. So if one wire has broken, very good chance others are not far behind. Hence, rather that face a future of playing whack a mole chasing ongoing breakages and faults, had complete new door loom fitted. The new door looms have been redesigned with slightly longer wires to overcome the known problem so in theory should last life of the car, I've certainly done another 88K since then without further problems so fingers crossed the redesign has worked. You can buy repair looms to splice into loom just before it leaves the door which in theory fixes all wires in one and you essentially end up with the redesigned loom. But a lot of effort to solder all those wires and so makes sense to me that once you have the door opened up that you do the job properly and replace complete loom as a single plug and play operation. Before you do anything though, recommend you get the car scanned to get full list of fault codes as whilst the door loom looks favourite here, there could be other issues at play (e.g. genuinely faulty control module).
DrCorbyLee started following Windows, Mirrors and Doors Issues
How? Cairus: I need more information, a drip-feed, a link to something that explains in terms clear enough for an idiot. I do not even seem to now have an SD card that the system will read, let alone load with a firmware update. Even if I did, where is that firmware?
Harrie joined the community
Update Firmware 253 then Patch
Dear Experts , Can somebody please share good Fabia mk2 Repair Manual to open the panels from inside boot to access the wirirng of Fuel Filler Flap for mk2 fabia 2014. Thanks Kind Regards
Rattle From Boot Catch (2022 Octavia Hatchback)
I have an annoying metallic rattle which I have eventually traced to the boot catch. (This was finally confirmed by driving with the boot lid held partially open by a pillow – rattle eliminated!). Although the boot lid seems to close tightly on the rubbers, and there is no play evident in either the locking mechanism or the lower striker plate, there is this persistent rattle. Has anyone else had this problem, and might this be rectified simply by adjusting the striker plate? T.I.A. Barry.
Rhencullen started following Rattle From Boot Catch (2022 Octavia Hatchback)
Regarding Head Lights /Lamps - Any thoughts please
Dear Experts , Please share if you have any experience for compatibility of headlight, mine looks like SPECIAL EDITION black inside OEM number 5j2941017F /5J2941018F but I want to change to 5j2941017j Or 5J2 941 017 D. (Fabia Mk2 2014 Monte Carlo 1.2 petrol 5j) Any thoughts please ? Thanks Kind Regards
raky started following Regarding Head Lights /Lamps - Any thoughts please
- From Amundsen to Columbus: mission almost accomplished!
TomRoadTrips started following From Amundsen to Columbus: mission almost accomplished!
- Hello, again
minsy started following Hello, again
Volume keeps turning up??
Hi, I will make ebay auction for it asap and let you know. that touch panel was made by me. works great, already repaired 50 pieces of that radio in octavia 4. The problem is gone.
Fuel Filler Flap Struck locked
Dear Experts , Please advice the best approach to investigate the struck Fuel Filler Flap for Skoda fabia mk2 . Possibly cause : Fuel Filler Flap actuator/motor is faulty Wirirng is broken any where from BCM to Fuel Filler Flap Door actuator is faulty ( but possibility chances are low since all doors/boot locking/unlocking mechanism works perfectly fine with FOB or mechanically) Possibly approach to idnetify the main issue Access the Fuel Filler Flap wiring connector after removing Wheel liner and check if it is getting required pulse when lock /unlock has been initiated. ( Any body have experience??) Remove panel inside boot , access it and check the same wirirng ( Any body have experience??) It may be difficult to get voltage info going to Fuel Filler Flap from BCM. Please advice best approach to open struck Fuel Filler Flap. Many thanks regards
raky started following Fuel Filler Flap Struck locked
Tow bar install
Has anyone fitted a towbar to their Enyak and can offer some advice. I’m not sure my car has the preparation kit from factory. Would you recommend Skoda or an independent kit and would there be coding issues? Thanks
Servicepoint3 started following Tow bar install
- Regarding Instrument Cluster OEM number for Monte Carlo fabia 13 plate TSI (105 , CBZB Engine code)
- AIR Bag Part OEM Number Fabia mk2 13 plate
- Centre console trim panel - Gearbox boot ring help please
- ANY body breaking FABia Mk2
- Regarding Connectors under seat
Clarity on Number of AIRBAGS -
Dear Experts, All sorted please ignore regards
Hello @LivornoBart , That's really amazing. Thank you for sharing with us. Can you also provide more details about the sensitive touch PCB being replaced(Part no, web link where we can buy it)? All the best
