  2. On oil consumption, I’ve now had the car back a week and while not done massive miles I’ve driven it everyday and cover maybe 30miles everyday at least, so far no noticeable drop in oil. I’m doing a couple of longer drives over the weekend so will feedback again but I’d say it’s definitely improved.
  3. Today
  4. Vesko_1 joined the community
  5. Venus joined the community
  6. Measured mine recently. Im burning 1 litre of oil to every 650 miles. Its also regenning more often than not, which takes me back to my original post. Is the mid range oil which is mainly used on services good enough for the Cupa/Cuna engine? The oil is getting too hot, too often, due to the regens, and the oil is breaking down faster and making its way past the rings. Makes me wonder if thats why some swear by Ravenol/Liquid Moly with Ceratec. As they may have better heat resistance. Obviously doesn't take away the fact the piston rings were never good to start with. But can it be slowed down by better quality oils, and a DPF/EGR delete?
  7. Odin515 joined the community
  8. I have similar issue but i have done fair bit of mileage, mine is a 66 plate 2.0 TDI and clocked 180k. Lately its been consuming too much oil, i do about 20 to 25k miles a year, but this is my 3rd oil top up of about 500ml within this year. I never used to do it then i did once a year then two and this time its three. i might have done 4 to 5k miles between the topups. looking at forum it looks like its not abnormal.
  9. bret joined the community
  10. I found out that on Obd11 you have to go to 4B module, switch to raw binary view(click bytes icon). Then find byte 11 and deselect bit 0. Important to reset headlights after - go to main module 4B main screen and select Basic Settings, run Headlights Basic Settings routine and then run Acknowledge Headlight Basic routine -that should do the job. Let me know if that worked for you. I don't have obd 11 and using Car Scanner, that's why I had to get some help. Hope it will go well!
  11. Thanks all for the advice. As I said I am overdue on the water pump, so I will change to the G12 evo when I fill the coolant back up.
  12. Do the fog lights actually come on with headlights or just the dash symbol. Had foglight symbol on dash when headlights were on but fog lights as far as I can remember were off (cant actually remeber if I checked) until switched on. It turned out to be a bad connection at rear of cluster. I removed cluster and cleaned and reseated it. Had a few dim lights on dash as well including DPF. Same car as yours 1.9bxe so no dpf which made me think cluster was problem not wiring. If your removing cluster disconnect battery first. Alasdair
  13. This thread may help. Third post down https://www.briskoda.net/forums/topic/515242-fuse-help/
  14. Almost certainly this. Other end looks to be riveted in, so standard part of box whether used or not.
  15. its not mentioned in the book, it may be wrong or just an unused fitting, I need to know what other peoples Elroqs'look like to know, but your right it does look wrong. Maybe something is supposed to bolt to it, but its not fitted to my car??
  16. It rather looks as if @JulianR has gone off radar.
  17. Best selling car (not just EVs) in China, about half million, which is by far largest car market in the world. That looks very good value and would probably suit a lot of people...
  18. I'm not convinced; they were imported in multiple container loads at a time, so they weren't low-value imports. Most of them in my area were destined for a large warehouse in Essex and a couple in East London. They were going to huge wholesalers who had set themselves up as suppliers to smaller independent wholesalers who were not large enough, or had poor credit ratings. Meaning main large-name UK and European manufacturers would not supply them. Often these smaller wholesalers would operate from a shopfront and would sell to the general public,, who would not be allowed to use a proper wholesaler.
  19. Good afternoon Dave, is the 80Amp fuse link under where the nylon fuse extractor is? That missing terminal post nut clearly looks wrong - what does that fuse protect?
  20. I scraped with a knife the black coating at the marked area and now it's more visible... Not great but good enough 🙂
  21. Hello, Skoda Superb Mk3 2.0 TDI L&K Looking for some advice. I have a small coolant leak, and I think it is coming from the water pump. The car is on 84,000 miles, and I don't have any records of the cambelt ever being changed. I have asked Vindis Skoda in Cambridge for a quote to change the cambelt and water pump, and they came back with £1630.70 inc vat which I think is outrageous. I could do it myself but I want the record of it being done for future sale. I was under the impression it was covered under a fixed pricing strategy, but the link http://www.skoda.co.uk/finance-and-offers/service-and-maintenance/simply-fixed is now just a redirect. They have an old 2021 document https://www.skoda.co.uk/_doc/8b70c541-726b-4996-9999-66ebc7ca520b stating it is £500 for a cambelt and water pump. Vindis currently has a price match guarantee on https://www.vindisgroup.com/skoda/servicing-offers/price-match-skoda/ so I am thinking I need to find somewhere reasonable and get them to match it. I have found https://www.john-clark.co.uk/volkswagen/servicing-parts-offers/cambelt-waterpump/ which is currently fixed at £799. https://www.vantagemotorgroup.co.uk/skoda/servicing-pricing/ is currently fixed at £700. Has anyone had theirs done recently, and what did you pay?
  22. Even without the Silicate pouch or dispenser, G13 coolant is quoted as having a service life of two to three years. If doing your own coolant refill, be aware that persistent air-locks can be problematical unless either vacuum-filling or VCDS purging procedure is used. I intend to change to G12evo on my next coolant replacement - unless VAG decide to change, yet again!
  23. There are new measures here in the UK and the EU to stop low value imports, by requiring full customs entries rather tgan Low Value simplifications, so there are less import entries of higher value and more of them can be paper anfmd physical examined plus more taxes collected. Should help reduce these poor quality shipments.
  24. 26DIPP started following oil filter 3v5 DTUA
  25. I am just looking for an oil filter for our SIII. Searching online comes up with 2 different cartridges - a 101 mm and a thinner 161 mm one. Which one would be for the 2L TDI with 200 bhp?
  26. The sole reason I provided a link to the video was because it demonstrated the 'kitchen towel' ploy. The business end of my Fabia Mk4's dipstick is as shown in the attachment below and matches the drawing in the relevant Owner's Manual. The main difficulty in identifying the oil-level is due to the dipstick's black colour.
  27. Unfortunately I don't deal with MIB3 units :(
  28. @pab567 has a good deal of knowledge regarding these updates I believe so maybe he could assist.
  29. Hi all, I've been happily driving my mk4 for the last 5+ years without many issues. Besides the occasional unavailable front assist, infotainment black screens and the inability to connect to carplay. Carplay not connecting was annoying sometimes but almost always fixable by rebooting the system. Carplay is the only thing I use and I didn't care much about the infotainment software itself. During these years I have had a few (maybe 5 or 6) requests coming in for OTA updates. I always accepted these and didn't think much of it. Now the last few weeks Ive been looking into upgrading the tech in my car. I thought it would be nice if there was custom software or a jailbreak available, so I could get more out of the screen and solve the slightly annoying issues. This is where I discovered I'm still running v1664, pretty much the first version of this software. So none of these OTA updates I accepted actually came through.. Trying to update the software through the infotainment system resulted in endlessly searching for an update, even though I seemed to be connected with the server (the globe icon is white). This is where I discovered I'm a bit too late for any OTA update and the infotainment sucks bad, as many of you probably know. No feedback from the system about why things do not work whatsoever. I thought well, I'll update the system myself. I'm pretty tech-savy and thanks to the great community I've been able to create a USB with v1941. However, trying to update the system with my USB, I ended up waiting hours for the update to continue past 0%, without any luck, and of course, without any feedback from the system. I've tried some "workarounds" like rebooting the system just before running the update, or turning off the engine and opening the door after starting the update. But these didn't work for me. After doing some more research it seems there are more intermediate steps (versions) I have to update to first, before ending up with the latest version 1985. As far as I could find I have to follow this path; 1664 > 1810 > 1896 > 1941 > 1985 I'm hoping someone here with more experience could confirm this path, and also confirm this is all possible using USB instead of ODIS. I'm also hoping someone can provide me with version 1810 and version 1896, as I couldn't find these online. My system details: Device Part Number: 5E3035816A Hardware: H56 Software: 1664 - MOI3_EU_VW_R6640L ABT hardware: H44 ABT software: 2088 It would be great not having to go to a skoda dealer to get this sorted out, as this can be quite time (and money) consuming according to some of you. Thanks in advance!
  30. .AI is watching and learning.
  31. Looks like 4 separate gaskets, one for each port: https://www.lllparts.co.uk/catalogs/skoda/CZ/FAB/225/1/133/133035
