  2. Doubt the difference bewteen 94 and 91 would make any real difference but the increased side wall will help. 205/55/16 against 225/45/17 side wall difference is about 3/4" more. I run 205/55/16 on my mk2. Mid range GT radial FE2 94V and its not bad plus good tyres in dry and wet. Son has 15" GT radial all season on his fabia and again good tyre in dry and wet Alasdair
  3. Everything has been back to normal for a few weeks now, I don't know if it was the car or the android auto. Skoda said there is nothing wrong with the audio system. I hope it continues to work..
  4. Had different but similar warnings on my mk2 58plate 1.9tdi. Foglight symbol on bright with lights even if the fogs were off. Also quite a few dim lights. EML just showing,DPF just showing and a few that came and went all dim etc. I dont have DPF so I removed cluster and cleaned terminals etc and replaced and cured the phantom lights. Reckon it had come loose or was making a bad connection.Remember to disconnect battery before removing and replacing. Alasdair
  5. The UK Government with the loudest voice Iain Duncan Smith is so very worried about China that they got their nickers in a twist about China and France building the new Nuclear in the UK. This government is so concerned over security and China that they do not want a Company fabricating wind turbines in a Yard in Scotland. No issues with how many Oil licences that a Chinese business has for oil and gas extraction in the North Sea because the is in partnership with Sir Jim Ratcliffe's company. No issue with how many ports Chinese companies own, or business,s or allowing a huge Embassy to be built in London. This is a very very strange state of affairs in the UK.
  6. Today
  7. VRS-Rich joined the community
  8. Yesterday
  9. Don't, just ordered a reversing camera 😆
  10. Kimmo81 joined the community
  11. Alright, final update! A few weeks in with the Revo Stage 1 tune and what an improvement it’s been. For my application, Revo is no longer making a high/low torque map. It’s just one file with switchable maps for 95/97/99 octane. The mid range torque is impressive and coupled with the TVS DSG tune, driveability has improved drastically compared to what the car was like stock. They complement other perfectly. Fuel consumption has stayed about the same (although there’s a bit more temptation to get a little heavier footed), and temps are still spot on both in the city and on long drives. As expected, my issue has now become wheel spin all the way through first and second gear, sometimes to the start of third, so better and wider tires are in sight. Overtaking and getting up to speed have never been easier. Overall, if you’re been looking for just a little bit more of everything from your EA888.4/DQ381 combo without making any sacrifices, I can highly recommend it. As always, make sure to stay on top of your maintenance and run the correct fuel map.
  12. Skyy replied to Hyeung's topic in Skoda Yeti
    Hi, Has your issue been resolved, if so what was causing the fault. Thank You
  13. Skyy started following Multiple Faults?
  14. zeta_91 reviewed danfer's gallery image in Octavia Technical
  15. Been having no luck trying to capture the lightning and finally got one!
  16. Link to download RNS510-6276-Update-VIM+Tm_60_35_5 sent in PM
  17. Hi, Looks similar to this thread : Or this one : Unfortunately, no Skoda solution yet.
  18. Still the same updates. 😑 Will wait for another version 🤞update and hope it fixes this...
  19. This evenings task was to get out the cardboard spray booth again. This time painting parking sensors for the front sensor retrofit project. I used the punch for the bumper to cut holes in a small cardboard box and taped them in place as an easier way of masking up the sensors. The loom has also arrived but is missing the 18 pin plug and is for LHD so some wires also need extending.
  20. This evenings task was to get out the cardboard spray booth again. This time painting parking sensors for the front sensor retrofit project. I used the punch for the bumper to cut holes in a small cardboard box and taped them in place as an easier way of masking up the sensors. The loom has also arrived but is missing the 18 pin plug and is for LHD so some wires also need extending.
  21. Hasnat joined the community
  22. Oh really? Will look it up tomorrow! Thank you!
  23. Hi @pab567 , could you please send me the RNS510-6276-Update-VIM+Tm_60_35_5 ISO via PM as well? I have an RNS 510 HW H27 / SW 6276 (C14) which is stuck in a boot loop. Thank you very much! 👍
  24. patak started following Bootloop media player
  25. patak joined the community
  26. I don't have a 'scope that I can use to test this part with however I don't see much movement in the value which I would likely see if the value was oscillating over time. Presumably we can't know if the superseded part was an improvement or simply a change of sub manufacturer. The eBay advert I purchased it from specifically listed my car model as well as the aforementioned OE part number so I thought it would be the correct type. For a non-safety critical part like this I was just trying to see if I could save a little money.
  27. I replaced my 2 front tyres this month, and was also a bit surprised to find them worn down to the threads on the inside edges 😬 They were Goodyear Turanza T005 which I’ve been quite happy with, so replaced them with exactly the same and had the tracking done at the same time. The garage said they’d found the tracking “only slightly” out. The fact they were so worn down on the inside came as a bit of a surprise as I’d been checking the tread depth regularly…will keep a closer eye on the inside edges in future. Mine are mostly motorway miles and I usually have them at 2.2 bar. I might try them at 2.5 which I think is listed as the “fully loaded” pressure.
  28. My 2009 79k miles had it since aug 24 so just over two years 11 thousand trouble free miles .changed all discs and calipers and obviously pads ,since i got the car its had some quirky electrical warning lights on dash ,if any light is lit in car sidelight boot light interior light etc etc etc then warning lights show up on dash a left hand green indicator light and oil low warning light if i indicate left the left indicator light on dash flashes but also the right , i am told its likely a short somewhere ,a bad bulb a bad earth etc etc its not caused me any problems but would love to find the fault .would a code reader be able to identifyespecially if it was a dealer version,?
  29. I have thought that the suspension on my Octavia seems a bit harsh and, having searched the forum, it seems that I’m not alone. My car is an ‘Elegance’ with 17” rims and 225/45x17 tyres and the beam axle rear suspension. Looking at the driver’s handbook, it says that the load rating for both 205/55x16 and 225/45x17 tyres is 91. However, it looks like the majority of 17” tyres that are available have a load rating of 94, as are the ones on my car. I think this could be contributing to the problem, along with the 45 profile on our potholed roads. I’ve decided to go down a wheel size to 16”, as 16” tyres are much more available in 91 load rating, together with the 55 profile, I’m hoping for a more comfortable ride. Has anyone else tried this? Out of interest, what size wheels and tyres does the VRS have?
  30. daveo138 started following Wheels and Tyres
  31. Try buying a genuine one from TPS, they usually deliver as well when you set up an account.
  32. It's weird because according to parts catalogue your car is equipped with BT module 5N0035730D. Look under passenger's seat.
  33. That turns out to be consistent with the parts catalogue. For your VIN, the number you quoted is complete without any suffix. It has been superseded by 5K0 907 659, but that's not the key point. Circuit diagrams for your date of manufacture (28.08.13) show no sign of the output being a LIN bus signal. Searching through Yeti circuit diagrams that I have, as far as mid-2016 still don't show a LIN output version air quality sensor, so I suspect that this model never changed over, unlike in that thread I linked above. I suspect the item you've bought suits LIN-based air quality sensor systems instead. Try to match your exact part number, or the superseding one above, and ignore any that have suffixes after the main 9 characters.
  34. Unfortunately, there is no postfix to the part number. Other writing on the older failed unit is 'PAG', the end opposite the sense intake has 'IND 12' and 'II 232/32'. Presumably the latter being a part manufacture date.
  35. Having owned two Sportlines and driven a few others, I take the view that the two best options are: - Dynamic Chassis Control. It makes a real contribution to taming the appalling road surfaces that are so common now; - LED matrix headlights. Magical technology at its best. All headlights should be like this and one day maybe they all will be.
