edrew97 joined the community
1.5 TSi - engine mods - intake / exhaust etc
The only practical experience I have is with my Leon and a mate's A3. Both cars had the MQ250 box and 150ps, although mine was a 1.4 TSI and his a 2.0 TDI. Both cars were mapped, and his still runs to this day, albeit with a new clutch. Mine was sold before it became an issue, although I had no issues. His has more torque than a stock vRS, so it makes sense.
Lucky643 joined the community
Not building it to race around Just a little more pull would be nice 👌
- Activating SmartLink on Swing 3
Jack Point
The undertray design is different, IIRC. The two small covers on the Skoda are utter garbage. You need to undo a screw and slide it back and off. You'll figure it out. Getting it back on is a nightmare. I almost gave up - three slidey clip things, one screw, one locking tongue and a locating tongue. Only VW. Uhmmmmm... I think it'll be a tight fit with the covers on over the pad. I can try it for you in the next week or so if you do want to know, as I need to lift the car up. You can absolutely cut a hole in the cover, or just leave them off. I'd try and keep it covered during winter, but I don't think it'll die.
Apologies, I was thinking of the 1.0 Octavia with the MQ200. I don't often come into Superb land. The MQ250 will fare better, but again, just watch it. While the 'factory limit' for the box is 250nm, you should be able to put 300nm into the clutch without any immediate issues. Just drive it sensibly, and you'll be fine!
Trav's 2021 Superb 280 L&K
I can't say it looks any worse than the one that was on there before. At least the RL parts are interchangeable between EA888.3 and 4. Be a shame if something happened to them...
Å koda Octavia Mk2 headlamp upgrade
Hi Friends, Has any one upgraded there Octavia Mk2 headlamps to newer style projectors.
Gixon-T-Jose started following Å koda Octavia Mk2 head unit upgrade. and Å koda Octavia Mk2 headlamp upgrade
Jack Point
Thanks, My plan was to fit a set and leave them there. How do they fit at the front, do the removable covers fit back over the top or do you need to leave them off? If the covers foul the pads, maybe they can be modified by cutting out a circle around them, obviously leaving enough clearance for the jack. I've found this set of OE pads which come with modified front covers. More expensive .. mmmm... https://www.akstuning.co.uk/shop/home/976-12156-genuine-vag-jacking-point-replacemementupgrade-kit-mqb-platform.html#/1013-jacking_point_options-skoda_octavia_mk3 Not sure why the MK7 Golf version which is cheaper is not the same as that that shown for the Octavia III. The rear is different, wonder if it fits?
Gaz59 joined the community
Hi I need help to know which is the best Headunit upgrade for mk2 Octavia
Who needs a sports car?
A bit off topic but Proper car. No frills or tech plus bet it puts a smile on your face every time you drive it. There is one in Inverness and the guy driving it always looks happy. Daughters got a classic mini with the 1275 engine plus a mint Peugeot 205gti. Both are brilliant to drive and if you ever need cheering up I would reccomend it. Alasdair
Alasdair1 started following Who needs a sports car?
I normally run on 'individual' driving mode, which is basically a combination of comfort suspension and normal drive. That actually dealt surprisingly well with most of the journey and noticeably helped to smooth out the rougher surfaces in some areas. For the particularly twisty parts, I flipped to full sport mode - having the physical dial to switch mode is really useful sometimes. That was more for the improved pick up out of the corners than for the reduced body roll. I didn't bother with the paddles; the auto drive was fine. The other change from my usual set up was that I switched to speed limiter mode instead of my default ACC/Travel Assist. I always do that on bendy country roads where I know I will be continually blending between brake and accelerator. It makes sure I don't accidentally get caught out and breach speed limits, which is easy to do with all the power under your right boot. The only downside was that I had a little brake pad glazing after the 45 minute hard workout. The brakes squealed for a few stops after the end of the trip. But they were soon re-conditioned and back to normal with just standard stop-start driving; no need for any hard braking routines to burn off the glazing.
Å koda Octavia MK2 ABS upgrade
Hi, As anyone upgraded ABS model on Octavia MK2 1.8tSI
Gixon-T-Jose started following Å koda Octavia MK2 ABS upgrade
fmartine21 started following Usb port
Dead battery in Sardinia — EFB vs AGM replacement & DIY registration (Superb Mk3)
Provided the BCM is correctly adapted to the replacement battery type, there will be no problem replacing a EFB with AGM.
Gixon-T-Jose started following Need Steps to swap BCM on mk2 Octavia
Hi Friends, Can you help me in swapping the BCM on a Å koda Octavia MK2 to enable more functionality.
- EPC Light On During Drive Home From Purchase Of Car
- Locked out :-(
JackTurner joined the community
Matrix headlights with auto high beam
If the high beam is activated, pulling on the stalk (like you would pull on it to manually flash, not toggle) should deactivate it (so disabling manual toggle or automatic highbeam).
TimoB started following Matrix headlights with auto high beam
- Locked out :-(
1.0 TSI manual: difficult to pull away smoothly
The "small battery" will be the back-up battery for the Fabia's emergency SOS eCall system and was discussed here in February 2026. https://www.briskoda.net/forums/topic/538090-backup-battery-trouble-code-b1916f4/ Online comments suggest an average reliable working life of 3 to 5 years and, although a new battery may be (fairly) inexpensive, to actually replace it can be a very labour intensive task as there's no standard place in cars for the battery to be located. At least from your comment, it sounds like the eCall battery in Fabia Mk4 models is reasonably accessible.
- Bolero firmware update request – 5Q0035840B, MST2_EU_SK_ZR_P0353T to P0369T
Mick11 joined the community
More worried about damaging it with mapping 🫣😂
Honeycombe upgrade
No worries. I think golf etc is in the bumper too
- Locked out :-(
Locked out :-(
Try an other battery for fob. I have had a couple that even though they were new battery they were pretty old and past it. If that doesnt work reckon an autolocksmith. Could be the car battery has gone flat even though it was working the day before. (interior light on etc) Had this problem a few years ago. Old car that hardly got used and car battery went flat with doors locked. Same problem manual entry was seized as was never used. We got a couple of jump leads and put power to main starter motor terminal and an earth to chassis to jump the car with 12v and managed to unlock it. You could also see if you can get to the bonnet release through or near front grill. Alasdair
