Can high beam assist be retro fitted to my 2021 Octavia SEL with front camera?
I know that is FEC and for my car never will be in the store I guess so if HW is ok I hoped you can do that.thx
the truth about electric cars
I don't do less than today trucks and if want or need to go slower then just get off the motorway. Scenic does have a Misubishi cousin i gather now and the Nissan Ariya is also with the same under pinnings mainly though they have 4 wheel drive Nismo version with over 400 hp as one of the variants.
Just come back.up the M1 and passed a Scen EV doing about 55 mph causing a right tailback as the wagons were having to pass it at 56 mph or there abouts. Obviously on cruise but oblivious to the rest of the world. Other than that I notice that on the continent the Scenic seems to be sold as a Mitsubishi Grandis.
2025 Skoda Superb Navigation Update
Unfortunately in my country i cannot update via OTA.
Kodiaq memory seat coding?
I would guess you need someone with odis to ensure it’s got the right dataset. For control modules I’ve found trying to buy second hand one from as near identical vehicle as possible spec/ model wise is most likely to succeed.
Binx1310 started following Kodiaq memory seat coding?
It's a licensed feature. If it's not in the Skoda Store, it's not currently possible. Your hardware is fine
What have you done to your Kodiaq today?
MOT today. 5 years old and 48,000 miles. No issues at all.
Fabia mk2 Repair Manual to inside Boot panel to access Fuel Filler Flap Locking
Appreciate All @Evolution13 @Lee01 @Breezy_Pete for their time and trying to help me , Yeah Fabia Mk1 have cable and Mk2 have just lid lock no motor controlled flap through central locking system. Thank you so much for clearing my confusion happy that this is not issue. Flap has not been opened for months and so it was jammed was scared to force it but slight wiggle had opened it and at least I can see understand the mechanism . Once again thank you so much for your support. Kind Regards
SD cards and the Amundsen infotainment system.
Thanks for that. The SKODA card I have reports at 16Gb. I tried the UK and western Europe map, (ECE 1) downloaded it, formatted the card FAT32, then unzipped the map onto the card with 'Unarchiver' which seems to have a decent reputation with Mac OS. The zipped file is 8Gb and the site says a 16Gb minimum is needed. Should be fine. The result of that effort is what appears in photo 4. A fail. Simply selecting NAV, then following the prompt to insert the card tells me it's accepted the card OK as a source of Nav data - but then it says it can't use it or words to that effect. Doesn't seem to make sense. I'm just wondering if the Mac OS is putting something else on there that I can't see when the file is being unzipped which then screws up the card.
I assume that You have navigation package. Maps updates are automatic OTA. You do not need to do anything. I believe that the page where one can check map updates for a specific VIN number is meant for older cars.
ufwojcie started following 2025 Skoda Superb Navigation Update
Constant app updates
I've been getting this too, from posts elsewhere it would appear that a download is being rolled out in batches of VINs. Today I got the message and was driving the car long enough to actually get the download downloaded and then theres a message to install it which takes 20 mins,, after that theres a further message to install the Apps which can be done in the background.
thamestrader started following Constant app updates
- Regarding Head Lights /Lamps - Any thoughts please
Ottocast issues
I bought a cheap one before and it wouldn't work at all
- Fuel Filler Flap Struck locked
- Changing Tyre Sizes on Fabia Estate 1.4 petrol VRS 2013
Evolution13 started following Fuel Filler Flap Struck locked and Changing Tyre Sizes on Fabia Estate 1.4 petrol VRS 2013
Dear Experts, Thought to update, Luckily I was able to open the fuel flap with just light wiggling and close and reopen all worked fine. Also I don't see any motor lock pin system ( no perturbed pins found when central lock /unlock key fob is pressed ) , but I can see that fuel cap have LOCK which works fine with car door mechanical key . Does this mean this is correct functionality please any thoughts .. I looked PR code for my car which have number "4K3" and it states that "Door and tailgate/trunk lid locking 4K3 mechanism"- "Central locking w/ radio remote control, interior controls and SAFELOCK" and it does not mention about Filler Flap so I understand that this particular model MAY NOT not have motor/actuator fitted for fuel filter cap and which works with central locking system. Any thought please would be highly appreciated. Thanks Kind Regrds
If you just want maps the Official Skoda website has them available for download , as long as your Official Skoda SD card has enough space for the new maps you will be fine, some older official Cards are to small for the new maps to fit on, hence why people suggest a new larger "Official" card (the standard MIB2 Units are locked down to only use official SD cards). The mib-helper website is a good place to start for information about updating or patching you system, or there are some very good YouTube Videos on the subject too.
Tea4Me started following SD cards and the Amundsen infotainment system.
New Dacia Spring, big revision as the Dacia Spring, 45, 65 were pretty awful and the Spring 100, whilst big improvement, was still fairly naff. It shares much with the new Twingo I gather.... (Chukier, Heavier and Roomier ((but actually less power but torque not too bad for a 1.2 T car and makes it at low revs)).
Get it Ready For Winter
I use all sorts. Clean glass with white vinegar or meths if I don't drink it and rub with old newspaper then Rain X, fog X clear glass or whatever. Buff with old y fronts or a soft cloth. Treat window rubbers. Or not bother sometimes. Today I did most of that 3 times. Brae nicht the nicht, fair drawing in.
Evolution13 started following Regarding Head Lights /Lamps - Any thoughts please
@Evolution13 I've never used RainX - got put off it ages ago when it talked of the criticality of cleaning the screen before applying it. Is the in your photo a single application version?
SteveTheElder started following Get it Ready For Winter
You just press in flap and it opens. Unless stuck. Frozen winter time. Czech built cars. Not that great in island nations. Some even had an ice scraper you could not get to.
zaqu joined the community
Rattle From Boot Catch (2022 Octavia Hatchback)
Thank you so much JamesK! Great information - I shall try greasing (silicone spray) those pesky blocks tomorrow. Barry.
That's what my Google says as well. Don't the MkII's have a release cable in the boot somewhere under the trim panel?
