Firmware 6276 source
Could you please send me the link for SW 6276 L that supports DAB radio? Thank you.
the truth about electric cars
Fine, if that is the closed-mind approach, then I'm out of this thread, and you can all get back to making yourselves feel good about things. I have already made the changes to the system, so I now no longer follow this thread.
Timing of transition/implementation of the EU driver assist regs for different Skoda models
I personally would buy a vehicle without SFD 2.
Lane Change Assist
I don't use travel or lane assist since I find that lane assist in particular is quite violent in 'tugging' the steering where the system detects a variation in lane keeping. In fact and in law I, as the driver, am solely responsible for maintaining the car in a safe condition, presenting no hazard to other road users. In the event of an accident I doubt whether a law court would accept my plea "the car did it, not me Guv", euro mandated or not.
Colin1051 started following Lane Change Assist
If the supporting evidence is scientifically correct, verified and repeatable with the same results then whether it’s good or bad doesn’t come into it. But when evidence is gathered by “the one lone scientist who saw something 100’s of others didn’t” is the basis for claims, that rarely stands up to scrutiny. P hacking is an easy way to make a claim that supports a bias - ie stop testing when you get the result you wanted and ignore the data that you also got the doesn’t support it.
Juraj_1971 started following Firmware 6276 source
Juraj_1971 started following pab567
Juraj_1971 joined the community
2025 Skoda Kodiaq Sportline
My car was first registered in March 2025 and has covered 8500 miles. On locking the car I've noticed recently that the drivers door mirror squeaks quite loudly when folding. My problem is where to apply lubricating grease, and what type of grease to use. Can anyone assist me please ?
Colin1051 started following 2025 Skoda Kodiaq Sportline
This was an a very interesting problem and a novel approach to resolving it.
Sorry, but I'm not kicking off, just making a statement. Factual information could be construed as misinformation by anybody who either does not want to accept that the information is factual even though it is supported by evidence. The name of this thread is "the truth about electric cars", so is it not a fact that some truths will be pleasant and accepted, while other truths won't be accepted but will still be true just the same?
hillth01 joined the community
Fuel pressure regulator valve (n276), fuel pump or something else?
Hi I haven’t managed to solve the problem. I am hoping someone else on the forum might have some ideas. Recently I personally checked the power to the fuel plug. When car is on it gets 14v on one pin and 1.7 on the other pin. This should mean the wiring is ok. The resistance of the fuel pump solanoid is 1.8ohms (measure across the pin) . Apparently this is within tolerance . My Research still suggests the replacement used fuel pump I bought is faulty. So it looks like I need to get a new replacement pump. I can only find cheap import fuel pumps for £70 to £90 (unbranded I think) Anyone suggest what else’s could be wrong or which fuel pump to buy?
- dsg clucking noise from p to n
scotthugh3s started following dsg clucking noise from p to n
Visually etc. My car of the day -today
Bloody eco warriors 😆
2015 vrs occasional brake judder
Thats something I didn't think of, will check later. 👍
- 2015 vrs occasional brake judder
Might sound odd, but check the engine mounts, mine was doing this and I knew my engine mounts were dead, when I put an insert in the dog bone mount it went away. I guess it was just the engine wobbling about under braking load.Sharpy64 started following 2015 vrs occasional brake judder- What have you done to your Superb III today?
Recently upgraded to newer iPhone with USB-C connection rather than lightning. So today’s task was routing a new 90degree USB-C cable from the rear ashtray through to the armrest cubby to replace the lightning one. I pulled the old one out with some wire attached and used it to pull the new one through. All done and dusted in 5 mins. Hopefully get a chance to change front brakes and have a go at installing the aftermarket blind spot kit this week.- Today
- the truth about electric cars
Don’t kick immediately after I’ve unlocked it, or it will just get locked again and will stay like that.- the truth about electric cars
The problem with misinformation is that it may not be actual misinformation but factual information based in information that is not yet general knowledge.Graham Butcher started following the truth about electric cars- TMC traffic events no longer being received...firmware update required?
Thanks for confirmation.- the truth about electric cars
Aaaannnnd…. We’re reopening after a little break and getting the room painted a more tranquil shade of “let’s all get along beige”. So let’s all remember to play nice, not spread misinformation, don’t scare monger, don’t try bait for reactions and don’t be attacking each other on a personal level.bobon123 joined the communitylullable started following Android Auto Connectivity Issues- Chip Protection on Sills
its fairly thick as I had to remove some to patch sills on my old octavia. Its good protection but on mine over time moisture got behind it and ended up with holes. Weird thing is my sons mk1 is a few years older 55 plate and its still perfect but my 58 plate octavia is now a parts donor car as sills have gone past repair. Alasdair- Thinking about an Elroq, but...
You might investigate a charger in a garage / handy shed or mounted on a post by your drive before giving up on home charging.Luckypants started following Thinking about an Elroq, but...Rafitata10 joined the community- Changing the front badge and rear lettering on 2020 Fabia colours edition
I have done this to my own Fabia Colour Edition. I purchased mine from Skoda Parts: https://www.skoda-parts.com/spare-part/6va853687a041-inscription-skoda-46996.html You can also find options for black Fabia badges but I opted not too. It is a qenuine part and it arrived quickly.- Chip Protection on Sills
