  2. Abdelrhman joined the community
  3. coley06 joined the community
  4. Thank you for the feedback. Deposit paid today, collect Wednesday.
  5. Today
  6. Fabia Mk3, MEN2_EU_SKGPx_P0460L, ver. 8780 - Success! It worked like a freaking charm. Huge thank you @Zlatko580! And thanks @bigwhale42 for a Linux version (did mine on Mint) Also, photos were really helpful! In my case I didn't need to do factory reset, CarPlay, Android Auto, MirrorLink everything worked from first run after plugging unit back.
  7. Hi, Had my Samsung Galaxy s23 setup with android auto on my 2016 Superb, until recently it won't connect and I get a USB error message. The phone has had a couple of updates, so not sure if the is the cause. Tried new cable, selected transfer files and android auto setting on my phone and still get the USB Error message, any ideas what the issue could be r what to check next. Thank you in advance Tony
  8. Hi All Driving over Cairn'o'mount last week the mounting point on my rear left steering knuckle \ hub carrier snapped leaving the trailing arm trailing on the road - literally! Trying to source a new one. 2011 Superb Estate 170 4x4. Apart from £300 for a new one I'm struggling to find cheaper options. Škoda part numbers: 1K0 505 433 1K0 505 435 AD 1K0 505 435 Q Happy to go used too. Is it common to other VAG cars?
  9. One minute I was toddling along minding my own business, and then this stopped me: Gaz
  10. Yes, it works fine. The manual isn't totally clear. What I've found is that you need to activate it once by pushing the stalk away from you (as if you were selecting high beam on a car without the assist feature). The 'A' symbol then comes up: white when it's on dipped and blue when it's switched to full beam. It you want to override it when it's selected dipped, you can push the stalk away from you a second time, and it will then stay on full indefinitely. You can also pull it towards you for a quick flash of full, as usual. I haven't tried this, but I presume you can override auto full beam by pulling the stalk, as that's what the manual implies.
  11. Hi, Noticed this week one of my screen jets was very weak on my 2016 Superb Saloon, so took it off and blasted it with air to clean. Then noticed both my screen wash jets are very poor. The water tank is full. Could it be pump blocked, feeder pipe blocked? Is it easy to access the water reservoir and pump and how do I access it? Thank in advance Tony
  12. rum4mo replied to royread's topic in Skoda Karoq
    Yup, typically Mahle rebranded to VW Group item at initial engine build and typically only Mann rebranded to VW Group item for service parts. I tend to look for VW Group at sensible prices and also for current Mann prices, and buy which ever is cheapest at the time.
  13. Anyway 17s are on with ps5s , car drives so much nicer imho so all good here 🥰🤗
  14. Hello Mick 9879 If it’s not too later there are loads of reasonable offers on eBay with full kit and free delivery when you have decided exactly what you want
  15. CJL started following Space Saver Spare Wheel
  16. Apparently my search skills aren't up to par on here, I apologize if this has been mentioned before. I'm in the middle of replacing the pistons on my 1.8 TSI with a 6-speed manual (LHC) transmission. Somehow, I forgot about the need to remove the screws on the seal behind the flywheel, to be able to remove the upper oil tray cover thingy. I'm thinking I'll disconnect the transfer box/bevelbox instead of having to remove subframe and so on. Also, is it really required to disconnect the driveshaft from the box going to the back wheels? I've already pulled the drive shafts and the right side drive shaft flange. Does anyone have any experience with this? Or if you have any tips on resources/videos of just this gearbox? I would really appreciate it! Thanks.
  17. McDuff replied to royread's topic in Skoda Karoq
    Don't know, but any of those you mentioned will be fine, as well as Mann.
  18. Guys Today I fitted my dashcam from my previous car to the Karoq. My car has a rain sensor, so I decided to power it using a FitDvr adapter. This piggybacks into the wiring to the sensor and gives switched power, so no parking mode. Dongar also do a fitment for our cars, but were out of stock at the time. I took my time, ensuring proper connection and no damage to mirror shroud. It was dead easy. One thing to note is that the power doesn't switch off until 30s or so after you lock car and comes on when you open the door. For a video, watch FitDvr on YouTube for fitting to an Audi. Hope this helps someone.
  19. On my little A series (it has the current software for touch screen etc) you simply say the word "next track" and it skips. No " hey Mercedes" required. If your car is similar, there are several commands you can use with direct speech too
  20. andrewww joined the community
  21. I had a colleague who had one of these. The engine sounded great and he loved everything about it....except it ate front tyres strangely enough. MB said they often do that. Something to do with the standard alignment (it hopped about at low speed, especially manoeuvring and in cold weather). In the end, he took it to an alignment specialist and they adjusted the car to what they considered a more 'sensible' set up and there was once more peace, in the world.
  22. Was ordered in January , No problem wish they would have let me know as little things like this sway customers to other place 👍👌
  23. Not best impressed was expecting Contis .
  24. My Skoda Superb also just has the standard screen for the tyre pressure settings. A bit poor really. My 2015 Vauxhall has individual pressure display for each wheel which I woupd argue is a cheaper make of car. Bit disappointed when I first noticed.
  25. The Skoda 'configurator' for UK-specification Fabia cars currently indicates that five brands of tyre (Continental, Goodyear, Kumho, Laufenn, Nexentire) may be factory-fitted depending on the particular model and wheel-diameter that the buyer has chosen. 15" wheels may have Continental, Goodyear or Kumho. 16" wheels may have Goodyear or Nexentire. 17" wheels may have Laufenn or Kumho. 18" wheels will have Laufenn. I'm sure that the contract that the buyer signs will have a clause warning that the vehicle's specification is not set in stone and that the manufacturer has the right to change it. (I was at a Skoda dealership last Wednesday and there was a brand-new 130 in their showroom. The car had Continental tyres...
  26. Could be the alternator belt as you suspect but flat ribbed ones generally dont screech as much as V belts unless loose/glazed/oil contaminated or perhaps a tensioner/bearing has failed puting it out of alignment. Check the edges for wear and also check tension of belt. Alasdair
  27. As there are no further updates available for the colombus unit in my superb, thought I `d try Waze for the satnav? As far as I can tell phone is set up correctly and paired to the car no issues, but I cannot get any voulme through the car speakers like it`s supposed to do. Anyone had similar issues and know how to get it to work or is my colombus just not compatible? 2014 Lauren +Klement Superb Estate..
  28. How do you check this max privacy ?
  29. Some applications cannot be updated while you are driving. Try stopping the car, apply the handbrake and see if the app will update with the ignition on but engine off. Also check you are not on max privacy. If it won't then a trip to the dealer my be needed.
  30. I might have answered my own question. It appears the mk3 chassis is different to the mk2 so you need a different towbar. Pity. Still it means I now have a mk2 towbar to sell😃
