Past hour
Cabin heater easy way in with cabel from enginebay
Hi, i took the clutch cutout inside. How did u do it? Any tip on how to route and Where to ground the 230v input in the front ? Left or right side and where did u ground?
Jaaaaaa started following Cabin heater easy way in with cabel from enginebay
Jaaaaaa joined the community
Rear springs...replace?
The Greenline does have lowered ride height. According to the Kilen spring catalogue, the Superb MK2 1.6TDI estate Greenline has rear springs with OEM part number 1K0511115BT. 1K0511115BT has one blue paint mark, and three yellow paint marks. This is the only Superb MK2 rear spring with lowered ride height that has three yellow paint marks. There are two other rear springs with lowered ride height with three paint marks of the same colour, but these colours are green and orange not yellow. So it does look like it's 1K0511115BT. 1K0511115CA is one up in the hierarchy, 1K0511115DG is two up in the hierarchy. If the current rear springs have started to sag compard to when they were new, then just replacing them with new 1K0511115BT rear springs or going up one in the hierarchy may be all that you need. An alternative, could be to replace the lowered ride height rear springs with standard ride height rear springs. Sachs 994 454 lowered ride height rear springs (matches 1K0511115BT) (build code 0YD) Length 330mm Wire diameter 11.75mm Saches 994 363 lowered ride height rear springs (matches 1K0511115CA) (build code 0YE) Length 333mm Wire diameter 12.00mm Sachs 994 360 lowered ride height rear springs (matches 1K0511115DG) (build code 0YF) Length 333mm Wire diameter 12.5mm 1K0511115DH lowered ride height rear springs (build code 0YG) Length unknown Wire diameter unknown Sachs 994 373 lowered ride height rear springs (matches 1K0511115CD) (build code 0YH) Length 342mm Wire diameter 12.25mm Sachs 994 361 lowered ride height rear springs (matches 1K0511115CE) (build code 0YJ) Length 342mm Wire diameter 12.75mm Sachs 994 559 lowered ride height rear springs (matches 1K0511115CF) (build code 0YK) Length 345mm Wire diameter 12.75mm
unfortunatly i dont have a steering wheel with paddles or heated wheel ( really cant justify ebay prices ) but the heated REAR seats seem warmer than the front 😇😜
Today
S3 owners - electric tailgate / hatch closing from inside
I have VCP. You can code what your controller allows. You may be able to write a new data file if it is available. I wanted to get the inside opening and closing functionality for our 2023 SIII but have not been able to do it yet. Skoda have fitted different controllers for different years and they have dropped functionality and called it safety. You might have to change your controller. But that also involves coding.
skoda_superb_2022 joined the community
1.2 TSi CZJC Lumpy, stalled, wouldn't restart
When I replaced the timing chain on my own car - completely different engine, I still made timing marks in white paint. Once the chain is fitted and locking tools removed the engine should be turned over (by hand) a few times and checked against the timing marks before any covers are refitted. Having marks present does not surprise me. They are useful as checks. Getting the timing wrong usually is catastrophic. Even where parts have timing marks I highlighted these with white paint to aid visibility. Kev.
tetley started following 1.2 TSi CZJC Lumpy, stalled, wouldn't restart
Expert help required
You're welcome.
Though I have heated windscreen, I sometime use a very efficient method when I'm in a hurry to leave: a simple spray bottle that I fill with household alcohol. This prevents any risk of scratches on windscreen and any glasses. With ice scrapper, if your glasses are a bit dirty, it may cause awful scratches. 😬 BTW, it reminds me an old joke in the '80s: _ Do you know why Ladas have heated rear screen? _ To keep your hands warm, when you have to push it. 😂
Mark8206 joined the community
Gearbox Emergency Mode
the wet clutch DSG is very different from dry clutch DSG... an is much more smooth and durable. The wet clutch DSG has also emergency mode (mechanical redundancy for limp mode ) , which dry clutch DSg does not have...
- Skoda Scala 2021 1.0 TSI 95cv – Intermittent clutch problem, gears won't engage
- Engine Overheating
Photography Thread
b2311e joined the community
liammurphy joined the community
Haven’t started yet 😂😂😂
Especially on AliExpress!
In my experience, once you start, that’s the seal broken…
Loads of plans but seem To have lost interest now Unsure whether to mod it because it’s such a nice car as it is
I'm concerned by your mechanics reference to using 'marks' to establish correct valve timing while replacing your cam belt - AFAIK, it is critical to use the correct tool to physically lock both the cam and crankshaft in position while doing this job.
Warrior193 started following 1.2 TSi CZJC Lumpy, stalled, wouldn't restart
Amundsen MIB2 Firmware Update
Hello, I am looking for firmware mst2_eu_sk_zr_p0253t and MST2_EU_SK_ZR_P0480T I now have MST2_EU_SK_ZR_P0241T (which also would be nice as backup) Thank you in advance
EmillienR started following Amundsen MIB2 Firmware Update
EmillienR joined the community
Photography Thread
Lovely clouds, sky, Moon (99% full) and reflections this afternoon. Only had my phone to hand sadly🫤
Latest Software update information (Recommended?)
1941 is not actually the latest software version, although it is considered a stable release so if it isn't causing you issues, I'd just stick with it. 1989 is the latest version, although I myself stuck with 1985 as it was (and still is) working absolutely fine for me. 1985 and 1989 are the only 2 releases after 1941
1.6tdi revs high at idle after driving car short distance/DPF???
Ah that might make sense re battery. Think its about a year old but cant remember if I bought a new one or nicked a good one from one of my older cars. Will check voltage tomorrow. The high idle has only been there for the last few cold days -3C and below and only today did it fail a regen hence fans on. Previously it just sat at high idle but no signs of regen or fans. Its supposed to get a bit warmer tomorrow (a balmy 4 degrees!) so will monitor it plus give it a good run when I can. Cold weather is hard on batteries so hopefully thats it and nothing more sinister. Alasdair
zeletu joined the community
Does it if the battery charge is getting low, particularly in cold weather. May be first sign of battery getting tired.
Weird it has done it the last two/three days in a row even after a 30min blast down road. Alasdair
Mines does the same but also get strong exhaust smell. Only in winter the smell but the high rpm is regular due to short runs.
Martin0k94 started following 1.6tdi revs high at idle after driving car short distance/DPF???
Same here used to do longish runs but now all fairly short. It used to wait till engine upto temp but now seems to do it from cold plus a good blast yesterday seemed to cure it. This morning was the same again?? Seems to be regen every time I start car?? Apart from that car is running perfectly Alasdair
yeah, thats the dpf trying to get a regen done. mine does it pretty regularly since i stopped driving it for work (stupid fleet management taking my mileage off me for a van...) so once a fortnight i bring for a run to let it blow out or force one through my carista if its getring very high
