S3's Virtual Cockpit
Hello everyone. Im partially new to the site so sorry if there's a topic on this already. I had a VC retrofited to my 2018 sportline diesel. From my experiment's whit ObdEleven i managed to get the Sport layout and a few other stuff set up. Curently when entering the car i get welcomed by the sportline boot logo on my mib2 (mst2) and whit the regular skoda logo on my dashboard. I was wondering is there a way to get the VC to display the Sportline boot animation rather than the regular one. I can't find the coding/adaptation and from searching around i was only able to see it be posible on the facelift superbs whit newer cluster revisions/versions. Dashboard info: Hardware number 3VD920790 Hardware version 505 Software number 3VD920790 Software version 1710 System J285 System description ΚΟΜΒΙ Eny help would be great. I don't have acces to Odis/vcp, Only ond11. Thanks!
Muni started following S3's Virtual Cockpit
Headlamp Help Please
Remove the rubber access seals for the headlamp bulbs and fire a hair drier in to the unit. HTH Thanks. AG Falco
AGFalco started following Headlamp Help Please
- Bixenon Headlights auto-adjustment problem
steel wheels
18in Steel wheels for Karoq SEL 4x4 150bhp diesel. Are they available anywhere?
Yassou started following steel wheels
Bulb Failure Warning
Yes, that's what it means...
DSG Gearbox Errors. Advice Needed
So, what was the outcome of this in the end?
Tristan2026 started following DSG Gearbox Errors. Advice Needed
eagle3024 joined the community
Tristan2026 joined the community
Power steering (Rapid)
@gswainyboy if you'd like to reply to the message I sent to you asking for the VIN, I can look up what system you have.
Thanks for that inspectorman. Back up on the ramps tomorrow and check all pipes and connections now I know what I am dealing with .
- Hunting down my old skoda
Clunky Gear Changes
Hi, yes it is DSG.
Clunky Gear Changes
Is this a DSG Gearbox ?
Warrior193 started following Clunky Gear Changes
Yassou joined the community
Binx1310 started following L&K Front Fog light Bulb access? and Bixenon Headlights auto-adjustment problem
You can get a hair dryer or heat gun and gently warm the area. it will hopefully soften the clips etc to prevent snapping in the cold weather. they can be a bit awkward and stiff but you pull straight forwards in line with the car, not at the angle the trim is at. That seems to be the main issue. I am assuming it is pre-facelift. I am not sure how the facelift ones come out.
Clunky Gear Changes
Hi all, has anybody got any experience/advice on how to reset/fix jerky gear changes at slow speeds, affecting both up and down shifts? I.e crawling in traffic speed or slight downhill low speed prompting a gear change is very noticeable, whereas normal acceleration is ok. Any tips greatly received as all changes used to be very smooth. 20month old 2l Diesel with 40k on the clock. TIA. :-)
Ccc1 started following Clunky Gear Changes
- Looking for Update Software
So the crash repair is the most likely issue. Might be a long coding issue which tends to tell the car which items are installed. If the car doesn’t think it has self-levelling headlights it might not be listening to any level sensor if that makes sense. What’s the make model and year? And do you have DCC?
I’m not sure either , i found out that you can fill out a form through the council and find out from them and they will tell you certain details about the car like who the last owner was and what not but you have too prove too the council why you need such information and you need a reasonable yet valid excuse and I’m not sure me saying i just wanna buy the car back is reasonable and valid enough
