Spacesaver spare wheel
The below foam and jack kit can be ordered for the Fabia MK4 from any VAG parts department by quoting the relevant OEM part number, ie. 6VA093860A. The VAG parts department can confirm whether this is correct for your vehicle by reference to the car's VIN number. The Czech price on "skoda eshop cz" is 2079CZK which is about £74. The below foam and jack kit uses a 185/65R15 5.5Jx15 ET40 5/100 57.1 spare wheel. Fabia MK4 foam and jack kit (includes everything except for the actual spare wheel) (OEM part number 6VA093860A) Sada pro výměnu rezervního kola 15Určeno pro: Fabia IV.Alcar 4055 5.5Jx15 ET40 5/100 57.1 steel rim (for Fabia MK4) https://www.mytyres.co.uk/rims/details?vehicleId=1360399348768339044&rimCode=ALCAR4055 Alcar 4055 5.5Jx15 ET40 steel rim with fitted 185/65R15 tyre https://www.mytyres.co.uk/cw/tyre-selector?share=&vehicle_ids=1351328927594845284&sortCode=none&limit=15&rimCode=ALCAR4055&rimType=steel&sizeTyresOnCW=noChanges&season=so&price=&brand=Uniroyal&brand=Vredestein
Carlston started following Spacesaver spare wheel
8755 Software Update - Skoda Fabia 2019 Carplay Issue
How do I figure that out?
PhilRhodes joined the community
the truth about electric cars
I know about that, hence my surprise that you actually admitted to using Tesco fuel after you posted this.
Upgrade Carplay on my Superb 3T
Interesting, how have you done that?
Octavia RS AFS (Bending) Lights don't work
Turn your cornering lights back on and see if that brings them back. My Sharan has AFS lights and when one of the static cornering lights bulbs was out it disabled the AFS headlight function. Also, there is definitely and off switch for AFS as I have the option on the display to disable bend lighting, so there must be an equivalent VCDS option somewhere.
- [GUIDE] Activated Android Auto + Apple CarPlay on MIB2 Technisat for €0 (No dealer, no paid codes)
Guess the Hire Car.... Mac's 2019 game
Nope sorry @Gaz ... It's actually not a bad drive, is from part of the Stellantis group and has lots of little 'easter egg' (unfortunately not of the chocolate variety) motifs all round it harking back to it's WWII forefathers. Enough of a clue??
Is this a LHD car on UK motorways?
Karoq diesel engine oil 4x4 - recommendations / manufacturers?
What's the best oil for a.... Brand SKODA Model Karoq Engine 2.0 TDI 4x4 (110kW) Fuel type Diesel Production year 2020 - 2025
Ooopnorth started following Karoq diesel engine oil 4x4 - recommendations / manufacturers?
2011 Fabia 1.2TSI, 67,737 miles, AP Coilover conversion *non-running*
There's this? IMG_0754.HEIC AFAIK all recalls were actioned. I got the vehicle late 2014 from a Skoda dealer.
Sportline 85
I dont have the vehicle yet - only just ordered it but hoping to avoid the Gitis if possible
- Spacesaver spare wheel
offthewall started following Spacesaver spare wheel
are u running 8740 or 8755?
Skoda Superb mk2 columbus sytem not starting up.
Download link to RNS510-5238A-josi-VIM-Testmode-60-35-5 sent in PM. Why in PM? To minimize the risk of any attack.
If the rate of recharging keeps going up as quick as it has been recently ie 1 MW charging and faster, perhaps we will get a similar trigger mechanism, maybe with a locking trigger like US and Canada, bar Quebec province as state government don't trust their citizens !
Tescos had contaminated fuel a fuel years back. Silicone contamination. Quite a few people got compensation for engine damage. £8M paid out. Thurrock plant contamination.
- LED daytime running light (DRL) failing/flickering - 2022 Fabia
I think you missed the point of my comment, I was saying that you don't get sidetracked talking to other drivers when doing a splash and dash or even a full refuel with liquid fossil fuel because you have to be there, squeezing the trigger for the fuel to flow to your tank, unlike an EV. Of course, rain, snow, etc is going to have just as much impact on the rolling resistance of an ICE car as it does on an EV; that's pure physics.
Android head unit upgrade
Hi Andy, Audio Tech Direct have a comprehensive list of aftermarket Head Units for Skoda Cars. hope tthis helps.https://audiotechdirect.com/oem-style-units/skoda/
Beerhunter17 started following Android head unit upgrade
@lol-lol The Superb they used was a standard one and the only things modded were the fitment of low rolling resistance tyres, which many owners do as well. The only other thing they did was lower the suspension by 15mm to match that of the Greenline version. All Superbs have a smooth underfloor, unless someone has not replaced the various undertrays after doing a service on the car? The fuel tank holds 66 litres because it is a bigger car than the B and C-segment cars you mentioned; the Superb is D-segment and so has a heavier weight and has a larger wind resistance to overcome. An Octavia is a C-segment car and has a 50-litre tank, but their WLTP ranges are broadly similar, so the extra 16 litres did not give it any advantage in range. As to the fuel being chilled to allow more fuel to be stored in the tank, as far GWR is concerned, that is not allowed. What was that about Tesco fuel destroying ICE engines with water and other debris in their fuel, and yet you use it for your 5p and 8p-a-litre discount vouchers, which you use up? 🤨
Door Umbrella
Unfortunately not, I'd already checked there. We do have a couple of non-Skoda ones in the boot though.
Opinions for new shocks+springs
Thx for the reply. You didn't find the eibach pro kit too firm for daily driving? Also i thought that for optimum performance you should use b8 shocks with the pro kit because the oe-spec shocks would wear out faster, thus the use of shorter shocks like the b8's.
Crankshaft position sensor location
Crank sensor on the 1.4/16v is on the back of the block, low down, pointing in towards flywheel area. The sensor has a captive cable, I think, with a plug/socket somewhere higher up, in the area of the top of the dipstick tube, from memory. Check spark plug for cylinder 3 first, and if that's OK, change the pencil coil if it has individual coils on each plug, which I think will be the case on a 2003 1.4/16v.
Promark747 started following Spacesaver spare wheel
Sillyskoda started following Cars For Sale
Just as an update as I said I would. Drove the car this morning in the dark - right side of the motorway was kept in the dark, trees on the left were lit up. So mine all looks fine to me. 2021 L&K with Full LED Matrix etc
