Past hour
Garage Labour Time Per Job....
All depends if the job went straight forward or they came accross a problem like seized bolts etc. I would ask the garage if the job went as planned. How many hours did they charge you for the job. It may have included taking it to and from MOT centre/road test/alignment etc. Alasdair
Alasdair1 started following Garage Labour Time Per Job....
Adjutant started following Intake manifold flap gone - best replacement
Window regulator
Meant to add check that the runners that the glass sits in door are clear and top isnt obstructed. Alasdair
Window regulator
Normally you press up till window fully up and hold for a few secs then repeat down. Should reset itself. Is the glass fully in the regulator at bottom and are the cables running ok Alasdair
Alasdair1 started following Window regulator
- S3 owners - electric tailgate / hatch closing from inside
Given the reference to Ebay module, presumably this charging mode isn't OEM standard ?
- 1.5TSI Axial bearing (2018 car)
Today
Error: selector lever...
I have booked an appointment today service center on Monday morning. Let's see what they are going to say.
Bonnet support clip come away
push this whole holder in a hole, than push this little pin inside too. it will spread those 4 litle legs.
imart143 started following Bonnet support clip come away
Just had this error pop up after a cold start a week ago, went away and didn't come back. Late 2022 dq381. I hope it won't become a regular occurrence 😬
nin0 started following Error: selector lever...
Passenger side mirror won’t unfold
Took apart the mirror as much as I can in situ and the motor looks very much like a sealed unit. No obviously broken wires from what I can see. You can hear the motor start and then nothing moves so I suspect a damaged gear or motor itself rather than wiring issue. Managed to source a whole replacement second hand mirror unit from eBay for £49 delivered. Bonus being it appears to have the ££££ dimming glass installed on it too! Hopefully a straight swap and change the mirror cap for black and away we go. Watch this space…
InstinctHelper joined the community
Autodoc - avoid!!!
I've used them maybe 6 times over the years, as said you really do need to do your homework to check that parts are correct for your use, I use an online VW Group parts listing to get the correct and latest version of the part numbers for my cars first, then make sure, for items like road springs, that my part number is the only one that is listed against their offering. My mate wakened up the other morning to an offer from them for rear brake callipers for his old SAAB 99 - both his rear callipers have seized bleed valves and they are the small type - he claims them to be 6mm AF but I'd think that they started life as 7mm AF and have "rusted down a size", so if his latest Autodoc purchase works then he can either refurb the originals or just snap the bleed valves off (worst case), once they are off the car. He's had wrongly supplied clutch parts in the past, but as, unusually for him, he paid the "safe order" premium, the parts got swopped over FOC to him.
Hello from newbie
Hi everyone, recently bought my first EV after many years of gas guzzlers, and thoroughly enjoying it.
kenyaq started following Hello from newbie
Did you manage to sort this out? At least on my wife's 2015 VW Polo 1.2TSI, the area under this clip is hidden as it is on a plastic body part that bolts down onto the next metal body part - probably the lock carrier in VW Group speak.
kenyaq joined the community
imart143 started following How are your EFB batteries holding up? and 1.5TSI Axial bearing (2018 car)
Jack Point
Now dispatched and should be arriving today!
yes on eco 2 engines, but on evo 1 engine it is unlikely, The V-belt tensioner does not allow tension in the other direction, the belt could fall off, while the evo 2 tensioner is completely different. instead, With an eBay memory module installed behind the dashboard button, your alternator operates in a steady, conventional charging mode rather than aggressive regenerative mode—and it is actually healthier for your 12V battery over time. How Your Alternator Works Now Simulates a manual button press. Every time you turn on the ignition, the module sends a quick electrical pulse that mimics you pressing the physical Start-Stop "OFF" button. Aggressive coast-only charging is disabled. Because the car's Energy Management System sees that Start-Stop is turned off by the driver, it abandons the fuel-saving "recuperation mode" (where it lets the battery drop to ~80% charge while cruising so it has empty room to absorb braking energy). Constant, steady voltage. Instead of fluctuating wildly between 12.2V (cruising) and 14.8V+ (braking), your alternator now outputs a steady ~13.8V to 14.3V during normal driving. Smart protection remains intact. Because the battery sensor on the negative terminal is still plugged in, the ECU still monitors battery temperature and health, tapering off the voltage once the battery reaches near 100% state of charge so it never overcharges. What This Means for Your Car Longer 12V battery life. Standard recuperation cycles constantly undercharge AGM/EFB batteries (keeping them around 75%–80%), which accelerates sulfation and shortens battery lifespan. Keeping the battery near 100% with your memory module typically makes it last noticeably longer. No fault codes or side effects. Unlike unplugging the battery sensor wire, the car treats this as a completely normal user action, so all safety and convenience systems work properly. Minimal fuel difference. Keeping the alternator engaged continuously adds a tiny mechanical load to the 1.5 TSI engine, resulting in a negligible fuel consumption increase (typically around 0.1–0.2 L/100 km).
I believe the COD system engines do use regenerative (micro-hybrid) charging - the alternator ramps up the output voltage during overrun and/or braking conditions.
my friend which works in a battery shop told me to charge up battery to 100% once a month to prolong lifespan. and i am charging it. maybe diesels engine have regenerative charging but mine 2 cyl off system when release acc pedal, dont charge anything.
Quite possible in some cases that the 'smart charge' algorithm is not helping by limiting the alternator charging to around 75% max - if the battery is consistently not receiving the remaining 25% through regenerative charging, this could be a problem.
Autodoc - avoid!!!
I'm happy for you that you have had good experience. I ordered from there 4 times and 3 times there was a problem. But agree that prices are competitive
A VW Group Global Recall 2026.
Following up on the previous email, they’re waiting for a shipment of thousands of those screws and will give me a call once they arrive 😅
