  2. If your metal 'blade' in the key is broken, you should have it remade by any key specialist shop, is only the machining needed. The electronic part of the key is separated from it. I would advise against homemade attempts to "glue" this together, if your lucky you it will break in your pocket and you will lose the metal blade part, if you are unlucky it will snap when the key is in the door lock .. and you can guess how that saga would continue 😁
  3. leolito started following Broken Key
  4. Timcooper55 started following Broken Key
  5. On my 2016 Superb Mk 111 2.0 the key has come detached. I noticed a crack in the casing. Do I have to get a replacement from a dealer, or is it something I can fix myself. I’ve done a quick google, where it seems to can get replacement fob cases, but can’t see how you would insert your original key. Fortunately I have a spare, but for peace of mind would like to have a spare again. Thank you.
  6. Today
  7. Fix was to replace both lambda sensors. After replacing lambda1 (pre cat, B1S1), it started to throw active codes for lambda2 (post cat, B1S2). After replacing both sensors the fault (codes or MIL) hasn't come back. My guess is that the car had a missfire problem and lambda sensors problem - both of which are long gone now.
  8. MrAB joined the community
  9. Yes, see https://www.skoda.co.uk/owners/over-the-air-update-restrictions
  10. Did you get all the bits sorted? Hope you got on ok in France!
  11. Fjord1ambassador joined the community
  12. @East_Yorkshire_Retrofits have OEM folding towbars for kodiaq listed on their website. they may well do for superb too. These are priced about ÂŁ1500
  13. Binx1310 started following Towbar help
  14. Yesterday
  15. Hi I got the P2196 error code today, do you have any updates, what was the issue with your Skoda and how did you mange to fix it?
  16. Hi all, Today, while driving, my octavia's check engine light came on, plugged it in to an OBD scanner and it said: P2196 -> O2 Sensor Signal Biased/Stuck Rick bank 1 Sensor 1 I must mention, that earlier in the week I happened to notice that when I start the engine on, and the AC starts running, I can feel a smell of gasoline coming in through the vents. I checked online it says that it can be a high pressure fuel pump problem, or something completely different. I am open and thankful to suggestions, since this is the first time I experiencing this type of problem. Is it safe for me to drive the car? Should I immediately leave it at the workshop? Or what more could I check? Is it a common thing with these Octavias? The car has 133 000 kms on it. Thanks in advance.
  17. I had a flickering headlight. Swapped ballasts and it stayed in same place. I found the torx screws on the ballasts quite difficult to get to. I wiser if you have an 90degree bit holder or Allen key type torx bits. I then Changed bulb and all good. I upgraded to LED bulbs. They’ve been brilliant although I did have a faulty one (I suspect I damaged it trying to install it) but the supplier replaced FOC under warranty. Been perfect ever since and a nice upgrade. A pair is significantly cheaper than one HID! https://ebay.io/m/1DxukA Just a pain in the bum to fit. Wheel off, arch liner out. Hopefully won’t have to change them again for a fair while!
  18. juff24297 joined the community
  19. In Greece, we have space saver wheel as standard, in every trim or version-including seven seaters-except the iv version
  20. MogSa joined the community
  21. It's 2012. ,1.2 TDI ,new egr fitted but still has same code and glow plugs light flashing,I was going to find out what voltage I think should be 5 v at which pin , and wanted to know iif there was a common place wiring may be damaged
  22. SarahV joined the community
  23. NickyB joined the community
  24. Maarten71 joined the community
  25. From memory, think is was a minimum of 5mm
  26. What year is the car and which engine type does it have?
  27. My car is in the garage and its a very big garage connecting several building, and when I get out, it gets confused and the gps/navi is wrong. Basically it can even go into the wrong direction. Happened again today, drove 30min, parked car for 5h and on the journey home, everything worked perfectly.
  28. Jcbbuk joined the community
  29. I should also add that I have previously ‘validated’ the ‘Since refuelling MPG’ with brim-to-brim fuelling and the figures were within 0.5 miles per gallon, so I that’s good enough for me.
  30. Fitted a new egr valve , plug looked ok ,pins ok , still have egr code po 40300 and showing no live data , I need to check pins next but is there anywhere that the wiring rubs or breaks ect
  31. woowoo started following Egr problem wiring ?
  32. MIB-Helper indicates that the latest official Firmware version is P0253T but there’s P0353T available (and I can see a ver: P0359T listed, too). My current version is P0241T. Is it safe to use the P0359T or should I just stick with P253T? Thx
  33. woowoo joined the community
  34. jeffgover joined the community
  35. I'd have put the strip in warm soapy water, make it more flexible, not saying it would work but that's what I would have tried.
  36. If you intend to use Skoda main dealer 2 services have plans. Monthly payments with zero interest . They also have an all in plan form year three https://customer.vwfs.co.uk/service-plans/skoda.html?traci_c=UK|SI|GA|PM|SKODA:DM-P:&traci_s=SI:SKODA:SEA:Google:PerformanceMaxAd:2024-12:&traci_ee=22041507480::::::&traci_t=:::&s_kwcid=AL!10901!3!!!!x!!&gad_source=1&gad_campaignid=22051408243&gclid=CjwKCAjwyuDTBhB-EiwANCQhLCkFGobbhgE7ZfHM_hd8s4Q2bcibzWXgUH6bN2ly46HTm2MZD08GDBoCDL8QAvD_BwE
  37. Kiss point is point in the clutch movement where the clutch faces touch. Used to determine clutch pressures/ release points when changing gear etc. might be that? Adaptation of the dsg includes configuring kiss points among other things.
  38. I've just heard the use of the word KISS in relation to VAG automatic transmission.( Mechanitronic ?) any one familiar with it? Possibly to do with linking the transmission to the engine?
  39. Can anyone please advise what main dealers charge for the second service on a 2 year old car, low mileage. I live in South Yorkshire
  40. I popped to a classic car meet today and saw a couple of Ford Taunus's (Taunusi?) "Knudsens". We had them as the MkIII Cortina. Dad skipped the MkIII and went from a MkII to a MkIV but the neighbours had a MkIII in orange. Then I googled Taunus GXL and this video was the top hit. The very same car (the one with the Hamburg plates)
  41. Hi I currently have 215/40/17 on my Rapid Spaceback. As mentioned by someone in the thread it is a very hard ride. I am looking to reduce my tyre size to 16 just trying to check what tyres to put on to run best with 16s I’m seeing 205/55/16 as best option, any ideas?
  42. Hmm I guess it must have been an option. Rear heated seats and 3 zone climate was only standard on L&K models I think.
