- Hello, again
minsy started following Hello, again
Volume keeps turning up??
Hi, I will make ebay auction for it asap and let you know. that touch panel was made by me. works great, already repaired 50 pieces of that radio in octavia 4. The problem is gone.
Monte Carlo 2013
fabia mk2 Monte Carlo 2013Plate ( 2014 ) Facelift .
raky started following Monte Carlo 2013
Tow bar install
Has anyone fitted a towbar to their Enyak and can offer some advice. I’m not sure my car has the preparation kit from factory. Would you recommend Skoda or an independent kit and would there be coding issues? Thanks
Servicepoint3 started following Tow bar install
- Regarding Instrument Cluster OEM number for Monte Carlo fabia 13 plate TSI (105 , CBZB Engine code)
- AIR Bag Part OEM Number Fabia mk2 13 plate
- Centre console trim panel - Gearbox boot ring help please
- ANY body breaking FABia Mk2
- Regarding Connectors under seat
Clarity on Number of AIRBAGS -
Dear Experts, All sorted please ignore regards
Hello @LivornoBart , That's really amazing. Thank you for sharing with us. Can you also provide more details about the sensitive touch PCB being replaced(Part no, web link where we can buy it)? All the best
Regarding special connector 843 written on it( is it ignitor for side airbags or earthing )
Dear Team , All sorted . Great learning it took some time but I feel have built up good knowdgle for airbags related wirirng , connectors and about seatbelt tensioner etc. Always grateful to Pete @Breezy_Pete for his timely and invaluable guidance, he had kindly provided all necessary material and support to accomplish the task, without his support I would have not dare to start the project. Please DM me anytime should you need any knowledge on electrical related to AIRBAGS. It is NOT rocket science but need lot of patience and time. I have faced challenges at multiple stages but finally had happy ending. thanks Kind regards
Superb1916 joined the community
Ottocast issues
i have ottocast, but flat one. sometimes it wont self connect, then i manually tapping on display few times and after few times it connects, in settings i choose to connect when phone is off, so when i enter in the car, start engine, i dont turn of multimedia till 1 minute pass. then it connects itself good, sometimes about 2 of 100 connections fails, then manually reconnection fix problem.
the truth about electric cars
So many new and nearly new and hardly used EV bargains about though. Cars cheap as chips. Cost to Public charge is high or pretty much as fuelling an ICE costs. Home charging is no place near the cost of liquid fuel, but there is a charger to pay for. Unless like me you use a 3 pin plug cable. eg, 350 miles for £8.00 or so while Petrol or Diesel @ £8 a gallon or so might take you 35-60 miles.
Another Oil Consumption Topic
Bad maintenance and high mileage, sport driving style increase wear of piston and rings and engine consumes oil. too much oil in exhaust dpf cant burn and get clogged. EGR also have lifetime, and egr pipes get clogged. i hope you didnt pay car much.
- Activating SmartLink on Swing 3
you553ph started following Activating SmartLink on Swing 3
Ottocast issues
Had the same on our Kodiaq and gave up with it. I replaced it with an AAWireless2 that works flawlessly
Running costs may be cheaper but the cost to change is still very large and takes a long time to recoup. This is what matters to most people. I'm sure you'll mention cheap PCP deals on EVs but they done matter to many people buying through savings or second hand.
I've been trying to rescue a Felicia riddled with cancer
Thought I'd share my video logs of what I started with and how its going. Here's a sample, a 'thank you' for some lads here that already helped me out: https://youtu.be/vMaZPU-n_KE
keywacat started following I've been trying to rescue a Felicia riddled with cancer
What engine for a Skoda fabia estate?
I would avoid a 1.4 TDI with a DQ200 DSG. Some advertised are pretty high mileage. Just a case of finding one well maintained. Hopfully someone here has had one and knows if the fuel efficiency is that good.
Evolution13 started following What engine for a Skoda fabia estate?
I don't even know what this part is called in English, all I know is I need a new one...
Huh. My car does not have that yoke between the manifold ports the yellow arrow is pointing to.
The whole point is that self charging hybrids and plug in hybrids still rely on combustion engines. Self charging only have an very short ev capacity and PHEVs, mostly are not plugged in they used as tax dodgers.
What are they?
imart143 started following What are they?
The reduced Oil Refining facilities in the UK and none in Scotland is not good for Transport Fuel or petrochemicals security in the UK and the reliance on LNG from the US is a risk. The Scottish Dual Fuel Ferry Glen Sannox that has been nothing but trouble & hugely over budget has been running on diesel since July. A major issue that seemingly was not life threatening. We will see..... A valve and sensor issue and lack of shared information from a manufacturer about updates and modifications to the owners / operators/ staff maintaining and sailing the ship.
Hi I’m looking for some advice, Ive just started working a job where I have to commute 50 miles each way down the A1 and I’m looking to replace my current car for a fabia estate (open to suggestions) what would be the most economical fuel wise I am familiar with the 1.2tsi engine but have seen the 1.4tdi is meant to be a lot better for fuel. Does anyone have any real mpg values of each of these? Many thanks
