Past hour
Park Distance Control: please clean rear sensors - 2022 Octavia 1.4TSI iV
There's still a free check you can do without live data. Ignition on, handbrake on, reverse selected, then put your ear right up to each rear sensor. A working one makes a faint fast ticking. If one is silent while the others tick, that's your suspect. Holding a phone on voice record against each one helps if it's hard to hear. All of them showing nothing with the exclamation mark doesn't mean all of them have failed. On these VAG systems one bad sensor is enough for the whole rear set to be switched off. If none of them tick at all, I'd look at the bumper loom and the plug where it joins the main harness before buying sensors. For the measured values later on, a VAG specific tool like VCDS or OBDeleven will read the parking aid module. A generic OBD scanner usually only gets the engine side.
- Cairus's Leon FR
AdBlue
I've taken my 2016 Greenline from 152,000 miles to 191,000 miles since I bought it in March 2025. In that time it's been 100% reliable in terms of never breaking down and never going into limp mode. Including when a glow plug failed on a trip to Prague in September 2026. The car drove fine and I replaced the glow plug when I got back to England. I've topped it up with 10 litres of Adblue plus a bottle of Wynns anti-crystal every 6,000 miles or so. I've had no Adblue issues. No DPF issues. No EGR issues. I paid £0 road tax for 2025. And £20 for 2026. It does 60+ mpg on a long run, driving at the speed limits when safe to do so. Insurance is below £400 per year for me. OK, it's a slow grand-dad's car to drive. But 99.99% of the time, the lack of engine power is not an issue on the roads of the UK and Europe. Any time I lose by a lack of rapid acceleration is made up by having to stop for fuel every 700 to 800 miles.
tyres
which is month and year of production ot that tyres? best is to buy al 4 new if you change tyres, i dont like to drive different tyres front and back. but sure you can put new back, and next year it this time rotate and put new ones on front. those tyres are for electric cars btw.
Cairus's Leon FR
thats very cool
Octavia VRS 2.0TDI DPF Issues HELP
DPF is full of ash, it needs proper chemical cleaning outside vehicle, EGR system needs replacing or detailed cleaning, when i had EA189, 2012, intake manifold was 30% blocked with some kind of soot, greasy and hard. yours is also similar probably. you need to invest, but you already aware of that when buyed sport version of TDI with 300k
Reverse doesn't always engage on the first try
If it was linkage, you'd have issues with other gears as well - either 5th due to side-to-side play, or 4th and second due to forward-backward movement. The reverse is unsynchronized on these gearboxes, with reverse gear sliding in between other gears. With some wear on those gears, it's quite easy to hit side of the gears. Once you leave the clutch, gears spin for a bit and you can get a better position on the next try. I always tried to hit the right moment after pressing the clutch, when the gears stil spun a little, to make the engaging easier. But if you do it too soon, the gears will grind.
Coolant overflows
A partly blocked radiator would usually show as the temperature climbing and staying high under sustained load, like a long hill or a motorway run, rather than jumping to 105 and dropping back to 92 within seconds. It also shouldn't push coolant out of the tank unless the coolant is actually boiling, so I'd put it lower down the list. The pump is more interesting on that engine. The 2.0 TDI EA288 has a switchable main coolant pump. A shroud slides over the impeller when the engine is cold so it warms up faster, and the ECU pulls it back once it's warm. MAHLE put out a technical note about the shroud sticking closed, which stops the coolant circulating even when the engine is up to temperature and makes it overheat. The same note says that when the pump is changed, the actuator from the old pump has to go onto the new one and be reconnected to the ECU. As you've already replaced the pump, I'd check which type went in and that the actuator is fitted, plugged in and actually switching. If the flow drops off under load, the head can boil in spots and push coolant out of the tank, while the sensor only shows a short spike. I'd look at the main pump and its control before the electric pumps. If the EGR cooler and the leakdown both come back clean, that's where I'd go next.
Evilserge joined the community
Fifth gear popping out (gearstick)
When it does happen, it tends to be either when already in gear and just driving steady (ie random) or, on the occasion it did it several times, on acceleration. If that helps diagnose!
- Reverse doesn't always engage on the first try
D.FYLAKTOS started following Reverse doesn't always engage on the first try
Hey from the North East of England!
Fairly new Skoda owner (it was my wife's, but I foolishly traded my car in so she could have an electric car, received her Karoq because I tend to do about 1000 miles a week, she does a total of about 300 including the back and forths to various 'socials'. Never had a Skoda, more of a van / mondeo hit it with a big enough hammer and it'll keep going kinda driver, with enough spanner wielding to fix most things until the computers in the cars became more than just "is that the right key?" and "How much oxygen you got there mate?" - Weirdly I'm a software developer by trade (proper software, ground up - not a script writer) and robotics is a fun hobby - so you'd think I'd be over the moon about the computerisation of cars. So, seeing as you can't even change a battery without cranking out a copy of VCDS and prodding the brains of the unit I thought I'd better come and get some coercive support from someone! That happens to be you. I hope I can assist as much as I need to be assisted - we'll see I guess! For now I'm going to sit here, watch the sea broiling out of my window and wonder how I can get my good old 2007 Mondeo back from the dealership pmsl Doofs
Doofah started following Hey from the North East of England!
Your issue is most likely to be excessive wear in the gear cluster, although this can sometimes be due to faulty engine mounts on some older vehicles. Does this this tend to happen more when you accelerate - or when you lift-off the throttle ?
Warrior193 started following Is the oil service really needed ? and Fifth gear popping out (gearstick)
Today
Presumably your vehicle is on fixed, annual servicing schedule. £250 is expensive for just an oil service! If you now have used up all of the services paid for under the plan and now require a further oil service, you are free to have it done anywhere you like - just make sure that the correct specification oil is going to be used.
tyres
car has Hankook ventus all round, but the back are now around 3mm front 5mm Big decison do i go like for like with a new pair on the back or switch to four Hankook flexclimate Any one have experience of the range drop going to all season tyres and are they worth it for someone whose main use is between March and sept Less than 5,000 miles a year total
Stonekeeper started following tyres
- Coolant level warning mystery
- Cairus's Leon FR
I don't seem to have hardly any voltage at the plug. The earth seems good, but the other is something like 0.05V. I think I'm checking correctly, as the battery read 12.6v on the meter. Strangely the warning didn't come on for a short journey yesterday but is back on this morning. I'll keep the meter in the car and try and measure it next time the warning doesn't come on.
Firmware Request MST2_EU_SK_ZR_P0480T
sent in PM
Cairus's Leon FR
Does this mirror the main screen or can you have the maps on vc and different thing on MiB screen?
Cairus's Leon FR
Successfully mirrored Apple CarPlay and Android Auto from the MIB2 STD system to the Virtual Cockpit (VC) for Seat vehicles.
Karoq 2.0 TDi 2019 - has developed a tic. Mechanic is just throwing my money at it with no effect
Hey all. So this started with my wife, this is her car used for a daily 30m commute and weekend travels to see family (2 to 3 hours, sometimes the odd 200 mile drive down the A1/M1) car has been flawless for years. Every day things like tyres, brakes etc, every service hit, no MOT issues. Until August. In August, randomly, the car would just stutter/misfire. No codes on the dash, nothing in OBD, it would just randomly once on her 30 min journey lurch and then pick up as if nothing had happened. I originally thought it was just a wrong gear for the pull out on the roundabout issue (A174, stop start for 10 miles then a series of slip roads and roundabouts) - booked it in at a VW specialist, they replaced the battery and coded it in, sent us on our way. 2 weeks later, a series of the same stutter, 5 or 6 in a row, with maybe 3 mins between each, dashboard lit up with hold assist fail, traction control fail, parking sensor fail, glowplug light, engine management light. She was stuck in traffic having a panic, engine in limp mode. I told her to not abandon it at the side of the dual carriageway but leave at the exit 2 miles up or into the parking area just after if she couldn't get into the lane in time. She killed the engine (which was holding revs at 10,000) and sat. I drove over with the van (which she won't drive because it's too big) got in, started the engine. All is forgiven, no lights, no limp, no stutter. Back to the specialist - reads the codes, crankshaft sensor he says, replaces with OEM, sends us on our way. 2 days later same again. Back to the specialist - reads the codes, still crankshaft sensor... must be the loom. I'll make a bypass cable. He did that. 3 weeks with no issues, then the symptoms returned. Back to the specialist - I said, "if that cable was knackered, what's the chances that other cables in the loom are also knackered?". Quite possibly, but it's a bitch of a loom to access, codes say camshaft sensor, lets replace that. Oh and while I'm here I'll take out your air care sensor - they're known to make the signals dirty. Now we're 2 weeks on from that and its doing it again. The loom apparently wraps under the gearbox, is incredibly difficult to get to and will take 20 hours labour at least, so I've said I'll find another mechanic to look at it. However, has anyone experienced this before I start my phone calls to the auto electricians in the area? It might not be the loom, given replacing the crankshaft wiring didn't fix it (he ran a separate wire bundle to the ecu). I can get codes etc from the car, he sent me everything that VCDS recorded.
On Saturday I collected 4 x Drakon wheels with 2 x Dunlop and 2 x Goodyear winter tyres, that I bought on eBay. On Sunday, with the help of my son, I fitted them to my Greenline estate and drove 200 miles on them. The Dunlops had slightly more tread left on them. So they went on the front axle. The Goodyear eco summer tyres that I took off the rear axle have 39,000 miles on them and looked to have a very low amount of wear on them since new. I'll be putting them on the front axle in March / April - depending on the weather forecasts we get then.
@pab567 Good morning! Could you please help me too with a valid link or the MST2_EU_SK_ZR_P0480T file, so that I can fix the display and sound errors in my Rapid. I would greatly appreciate it!
Add rear USB-C connectors
Hi, Just wanted to thank you for this write up. I've successfully managed to change over the slow charging ports to 45W PD. The only changes i had to do was the pinout change, switching 5V and ground cables, and some adjustments to the housing, as the motherboard was slightly wider, so had to snap off the previous holders. I had to do a motherboard swap in the housing, as the latches from the new pd module did not align with my plastics. I also added a 10 amp fuse instead of 7.5, but i think that might not be necessary. Also, if anyone attempts this themselves - turns out you don't need to get to the charging module from the sides, it can be removed easily from the top, as it's just held with 4 latches on my octavia mk4... figured this out too late though. Anyways, an easy mod at the end of the day, and now i can charge my laptop through the ports!
Powugh started following Add rear USB-C connectors
Doofah joined the community
Powugh joined the community
Coolant overflows
Thank you! I did the co2 test again after hard pulls and still no co2 in the system. I will test the egr cooler tomorrow and do the cylinder leakdown test. I work at a garage so I can do all the work vy my self and save some money there. I was just curious if electrical water pump issue or bad radiator could cause this problem🤔
