Tent Box and roof rails on MK3.5 Hatchback
Official hatchback roof bar kit is 5E5071126 which lists a 75KG static load max - as do Thule for their roofbars. That seems fine based on tentbox's recommendation so assuming it's fitted properly, I can't imagine a tentbox would cause any issues for two average sized adults. It might be worth checking everything it still tight before use...
Octavia 5e Retrofit ESC and ParkPilot Buttons - Need Wireing assistance
It's probably worth spending a few quid for an hours access to erwin so you can download the correct schematics for your car. It makes this kinda thing so much easier 😉 Images of both relevant sections are attached, not sure about any coding for the ESC/ASR button.
MIB2.5 Upgrade Issues
Nope - all the buttons use the same wiring 👍 There are various versions. Your originals are likely one of these: 3V0919719A (No DSG paddles) 3V0919719B (DSG paddles) 3V0919719C (No DSG paddles + heated wheel) 3V0919719D (DSG paddles + heated wheel) The equivalent versions with a view button instead of phone are: 3V0919719E (No DSG paddles) 3V0919719F (DSG paddles) 3V0919719G (No DSG paddles + heated wheel) 3V0919719H (DSG paddles + heated wheel) As I have a manual car without a heated steering wheel, I went from 3V0919719A to 3V0919719E. No need to touch the clock spring or even recode, plug and play!
Pretty sure you don't need to change the steering wheel... Pop the airbag out and just change the buttons. It's what I did when I fitted a VC to my Octavia 😉 I used 3V0 919 719 E if it helps!
Replacement wing mirror on MK3 Octavia Estate not staying firmly clipped in
You should be able to just move the plastics across :)
AliExpress virtual cockpit
3VD is a Chinese Superb... That link still has the trip reset button so is not an Octavia cluster. 3V0 would be a normal Superb. An Octavia part would start 5E0. Namely 5E0920790 or 5E0920790A 👍 I think a Chinese Octavia might have 5ED part.
Probably broken clips - I assume you're replacing the other plastics so I'd just wait for them all to arrive. You can see the two clips on the new cover, take a look at see if there is anything for them to clip into. Certainly looks like something has snapped off here:
Based on these links: - https://www.aliexpress.com/item/1005004696403539.html - https://www.aliexpress.com/item/1005004717676841.html They suggest: - it will show a Superb not an Octavia - both the speed/fuel level will be off by 10% - there is a trip reset button which might make finding a suitable trim piece harder Based on that, I would not fit one to my car...
2019 Challenge Standard Equipment?
Welcome. The Nov 2019 brochure suggests the VC was not standard on the Challenge I think it might have been on some 2020 versions though... Octavia Brochure Nov 2019.pdf
Footwell light - PIN in BCM ?
Not possible with VCDS. You need to have direct access to the BCM EEPROM so you'll need either VCP or ODIS-e
Retrofiting reverse parking cam to Mk3
Good chance 5E0035820A is missing the hardware to support an RVC. At least based on this old post: https://www.briskoda.net/forums/topic/443780-retrofitting-a-reversing-camera/#findComment-4989995 It might worth checking with @pab567 as he tends to know most things and maybe able to suggest a replacement unit if needed
MIB2 STD2 Unit nr: 565035864 DAB/DAB+
Seems very unlikely DAB will ever work as there is no socket for a DAB antenna Based on these pictures, it's missing a black fakra to the left of the white double fakra...
Handed wiper blades
Yes - MK3 Octavia front wipers are handed. - LHD part number is 5E1 998 001 - RHD part number is 5E2 998 001 There are a few other part numbers as it looks like it's been superseded, but the initial 5E1 vs 5E2 means it's different for LHD and RHD. If you want Bosch areotwins that'll be: - LHD part number A620S or A419S (former is 475mm passenger side, latter is 450mm passenger side) - RHD part number A860S (only a 475mm passenger side option) Simple reason is that areowipers have a front facing profile so if the attachment clip isn't in the centre or can't be reversed, it would be backwards... It took longer to write this reply than google for the answer
Trunk lock
Octavia III - can't code ILA or traffic sign recognition
Can you start with a full auto scan from vcds? If you haven't already, I would also suggest taking adaptation maps in CSV if every module. At least the way you know what coding/adaptions your car had to start with. The instructions you're following probably aren't perfect for you car as there are various cameras over the years which are slightly different. I assume you've currently made no changes and everything is working as expected?
- 4 replies
- assist
- high beam
- lane assist
- octavia
Tagged with:
2010 Superb 2 Xenon Headlight aim codes 00496 00497 01537
I think the AFS master be behind the climate control panel as I'm pretty sure the MK2 Superb is similar to the MK2 Octavia in this regard. Snippet of a wiring diagram: If I remember correctly: - J745 is the AFS master - G76 is the rear sensor - G78 is the front sensor
At a guess, it's either an issue with the internal voltage regulator in the AFS master control module or there is a wiring issue between the AFS master and sensors shorting out the power line... I expect both sensors share a power supply but I know they have separate pins on the connector for each sensor. Should be a very easy job to disconnect the AFS master connector and then beep the wiring out to each sensor to rule out issues.
Just moved to France and failed Control Technique (MOT) on headlights
You'll need to replace them... Normal LED headlights are handed for either LHD or RHD traffic. The option in the infotainment is only for short term use and just drops the beam height rather switches the pattern. This is why there are sperate part numbers for LHD and RHD LED headlights
Jimmyke
Welcome... There is a 2019 UK brochure here: https://www.roberteardleyskoda.co.uk/brochures/04-01-2019/superb.pdf Although other regions may have different options, the S is typically the lowest spec Superb and that brochure suggests it doesn't have cruise control. The main difference is that all other models get more options! Whether that's important is down to you but given you've already bought it, it's probably too late to change
False engine overheat warnings - constant
It's most likely to be the water pump sleeve.... Take a look at this thread:
front shocks
Just over 70k... It'll very much depend on the roads and your alloys. Mine are 19s and they've had some massive hits in that time including his hard enough to buckle the alloys and even pop a tyre on the M11. It was dark and wet, whatever I hit took out about 10 other cars too, one hell of a bang though! My old MK2 TDI on 16s was still going strong at 190k on the originals. It's very much down to luck I think 🤔
What options for a corrupted infotainment screen?
I think it's quite an uncommon headunit unfortunately, looks like 3V0035869C to me... As it's an all-in-one unit, a dealer will only be able to offer a complete replacement hence the price. If it were me, I'd be tempted to open it up and replace the LCD. You might be able to find a part number sticker attached to the rear of the LCD and then try Aliexpress/eBay or find an identical used headunit to get the screen from. There is one hopefully version but the description and photos don't match so you should check before buying: https://www.ebay.co.uk/itm/335358189693
- Amundsen Mib2 Map Updates 2025
I'm afraid not - the inbuilt nav can only use releases from VAG. They are currently updated every ~6 months but as you can see, the actual map data is normally ~1 year older. I believe there is an online portal to request updates to the maps but it'll probably have an 18 month lead time between your request and finally making it to a release. I would suggest connecting your phone and using Android Auto or Apple CarPlay as 'connected' nav apps such as Waze or Google maps tend to be much more up to date
- 51 replies
- amundsen
- discover media
- maps
- mib
Tagged with:
Steering wheel retrofit - three-spoke
The buttons tend to work across multiple cars so there is a good chance they will just work given both are MQB platform. At least assuming they have the same buttons on them. Swapping them is also pretty easy but the plastic frame is easily damaged so if be tempted to try the new buttons first if they look suitable. No idea what colour lighting they'll have in afraid. I think both those years are using the older airbag design so it should all be pretty easy...
