Everything posted by Kenny R
TMC stopped working
- Kopacek/Superskoda
- Moving from 2015 fabìa 1.2 petrol to a August 2022 Karoq 1.5 petrol with dsg automatic
Don’t panic when you lift off the accelerator going down a hill and the coasting function kicks in and car freewheels down hill, a dab of the brakes will re engage the gearbox to allow engine braking.- Kopacek/Superskoda
My experience is exactly the same as 137699 above, I have used them from when they were Superskoda many years ago, to a few months ago and have never had any problems with quality of goods or delivery.- Hi, I've got a 22 Plate sportline and was wondering how to update the map. With the e-Sim I thought there was no physical SD card just a blanking plate. Can anyone assist? TIA
Maps update OTA as and when required.- Karoq replacement key options?
I’d be more worried about who has the other key.- Subframe corrosion
Is it available in 45 gallon drums for underside of that Yeti- "Hand Gestures" function/feature
There should be an option to untick gesture in the display menu.- What are these icons?
Signal strength and battery charge level of attached mobile.- 1.5TSI or 2.0TSI?
Exactly, if it’s fine in the bigger Kodiaq, it’s going to be more than fine in a Karoq.- Central Locking Issues
Do you have KESSY?- 1.5TSI or 2.0TSI?
I previously had a 2.0 Tsi 180 4x4 Kodiaq and went through the same dilemma when choosing my second Kodiaq. The things that swayed my decision were, the price of the 2.0 Tsi with options I wanted would take the price over £40k which would incur the £500 annual VED, and it looks like the Karoq Sportline could be the same. Secondly I put great thought into do I really need 4x4 having suffered Haldex failure in my previous Kodiaq, the cost of extra maintenance and the extra fuel required to hump around the extra weight of the bigger engine and 4x4 system ( which is equivalent to carrying two people around), and as I already used winter wheels/ tyres during the winter, I decided to go for the 1.5 Tsi 2WD option. All I can say I’ve not been disappointed, the 1.5 copes admirably even when loaded with grandkids and all their paraphernalia, and regularly achieves 40+ mpg using Tesco momentum 99 E5.- 1.5e-Tec info please
Didn’t know the 1.5 Tsi was now available as a mild hybrid, thought only the 1.0 Tsi 3 pot was available with this.- A/C not working
Every car I’ve had with climate I’ve set it to 19/20° a/c on and on auto 24/7 365, never had any need to put on lo, or make any changes to temp at all.- A/C not working
It’s anything but a sealed system and auto a/c systems are well documented as to loosing up to 10% of the gas annually, through pump seals, o ring seals and rubber hoses.- Skoda Connect tells fibs
If you click on the screen that is showing unlocked, another screen appears with a refresh button top right, after it refreshes it will show true locked/ unlocked status.- Diesel or Petrol
If you’re looking to achieve 40mpg your choices are most likely to be Diesel or the 1.5 TSI that will achieve the mpg you’re looking for.- Karoq or Tiguan
Do you not get the FWD Kodiaq in Sweden?- Rear wiper blade 2022 VRS?
Update on this. I ended up buying a Skoda rear wiper blade. On inspection of the old blade, the wiper rubber can be extracted quite easily from the end. I then removed the 280mm rubber from a new Bosch yeti blade I had lying, and with a bit washing up liquid to help inserted it in the Kodiaq blade. Wish I had thought of this earlier, but there you go, if you don’t want to pay Skoda prices , just buy a Bosch Yeti rear blade and replace the rubber in your Kodiaq blade.- Petrol gauge
As above it is not a tick sign, it is an icon of a garage fuel pump and an arrow informing you what side the filler flap is on. When the fuel level gets low you should get a warning of how many predicted miles till you run out of fuel, and instructions to where nearest fuel station is.- Petrol gauge
Are you sure it’s not the garage fuel dispenser and the arrow showing what side the fuel filler is on icon.- A hypothetical question.
The car will stop, somewhat abruptly. If you’re willing to try it, make sure you have your brown trousers on- TPMS?
With the direct tpms the display shows the current tyre pressure and the recommended pressure in brackets. No need to reset as in previous indirect tpms.- Automatic Kodiaq Issue
Sounds like you’re turning the autohold off and not the stop start. To be fair they do look similar.- Permanently disable Kessy on Scala SE L
Pressing the lock button on the remote twice disables the alarm and also the deadlocks. - Kopacek/Superskoda
