Dipped headlight adjustment
I'm reasonably sure that the automatic levelling system will operate from the basepoint set on the manual adjustment knobs - so your new manual settings should stay the same.
Octavia 2.0TDI vRS Cranking but not firing
I suggest getting the compression tested first.
Fabia III accelerates/maintains speed on its own after releasing the accelerator pedal
Even with a 'fly by wire' throttle, there will be an end stop on the pedal potentiometer - the throttle tap may help to eliminate this as the cause.
Oil pressure regulation valve P164E00
The oil pressure switch will almost certainly only warn of a loss of pressure - not excessive pressure. I'd have thought that there would be a visual warning in addition to the OBD fault if the regulating valve had failed.
struggling with 2014 standard sat nav system
Hello Rob, does you unit have a single slot for a SD slot and one for a CD ? If the SD card is in place, it should protrude very slightly from the slot.
I'm not positive - but my best guess is that the oil pump is rated to supply a certain minimum pressure at idling speed - the pressure regulator valve would then bleed-off excess pressure as engine speed rises, to prevent possible damage to seals from overpressure.
I'm not sure how that can work, my MIB2 Amundsen screen displays the message 'Map Data Unavailable' when the map SD card is removed.
Hello, welcome to the forum. Can you confirm your infotainment system, is it Amundsen MIB1? Are you sure that your sat nav is working without the SD card? Are you able to actually able to use it to navigate to a particular point - or is it simply displaying a general area map of the vehicles current position?
Looking at the image posted, the yellow caps stay in place - you will need a correct hex. key (allen key) to adjust - I'd suggest a 'T' handled one for this.
Cam Belt Change on WaterPump Replacement
I believe it is driven by a separate belt.
Battery not holding charge. No Parasitic drain.
I think you misunderstood - I mean connect the meter probes (DC volts setting) on the battery terminal and read the lowest voltage while the starter is cranking. If battery voltage falls below 10 volts, battery is either discharged or dead.
A load test on the battery would have been a good way to check - that could have been done with the Fluke connected to the battery terminals while someone operated the starter. Very likely that the battery had died though.
- Screw in the tyre of Enyaq
Every time I have had this, (my winters, in particular are screw magnets) the tyre always deflated very quickly when I removed it. In my multiple cases, the tyre had sealed to a certain extent around the object while it was in place - where I was losing about 0.5 bar over 3 to 4 days. Provided the puncture is far enough away from the sidewall, a tubeless tyre repair is permissible.
1.6 TDI manual gearbox whining
Hello, welcome to the forum. I was not aware that there was a M5 version. My M6 gearbox is silent in all gears. If the noise is noticeable while driving, I'd suggest that a bearing was in the process of failing - or a gear tooth is chipped.
Three G11 coolant mixtures, boiling-cooling time comparison.
Warrior193 replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanVery unlikely for any need for 50% mix in those circumstances - but I've known gearbox class Kart racers in the past who've used stronger concentrations in liquid-cooled rigs - so that they don't blow their coolant all over the track when they overheat.
Warrior193 replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanI think that you are looking at this the wrong way - the function of the coolant (together with the lubricating oil) is to transfer excess heat away from engine components and prevent them from overheating. A 50% glycol mix has approximately 20% lower ability (specific heat) to transfer heat away from those components. Yes the engine may be less efficient for a short period until it reaches normal operating temperature, but the way to achieve this sooner is to restrict coolant (thermostats) and/or air flow (shutters) - not by reducing the specific heat properties of the coolant.
Warrior193 replied to D.FYLAKTOS's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanMy understanding is that the reduction of heat transfer is significant as glycol concentration increases - but the requirements to raise the coolant boiling point, along with corrosion inhibition and anti-freeze protection also need to be considered.
Thinking about replacing Octavia ??
I think it is a little unrealistic to expect an engine to consume no lube oil at all. Providing oil consumption does not exceed specifications, there should be no concern for a small quantity to be used between service periods. There was even a time where Rolls Royce would recall cars for engine rework if they were found to be not using the correct quantity of oil.
Hello Peter, welcome to the forum. I believe your engine family is EA189, can you confirm? Is there anything in the service history for cam belt tensioner replacement? Get the tensioner checked - there is a history on this engine for failure of it. There are also a number of recent reports for TDIs failing to start due to low cranking speed - is the battery good?
Scala battery type
My suggestion works well with the Octavia and the common, flat type of double-insulated cable usually found on low wattage appliances.
Scala battery type
If you feed the mains supply cable into the engine compartment beneath the edge of the LH headlight trim panel, you will find you can fully close the hood with the charger in place.
Advice wanted
From memory, all information required (ET, PCD and wheel section) is there in the inside of the rim of all original VAG wheels.
Advice wanted
Hello Brazil, welcome to the forum. Very likely to be identical, but a later revision. To confirm, ask the seller if they can post an image of the information embossed on the inner face of the wheel (underside)
Haldex Failure
Were the front wheels spinning while the video was taken?
