defsix
Everything posted by defsix
  1. I'd imagine it's the lock motor is failing or failed. It might work tomorrow. If it does, don't lock it again. Get the correct part number based on your VIN, as there are a few variations ranged in price from €60 to €250
  2. I believe it's the old one. Just need to find the correct part number so.
  3. Sorry to jump in here. I have a 2020FL model with Heated Steering If I were to add DSG paddles, I assume it's a complete wheel swap. Can anyone advise a part number ?
  4. It looks about 25% Brighter / Crisper. I was getting confused looking at the left of the images. We should concentrate on the bricks to the right.
  5. Was this a worthwhile upgrade for you ?
  6. I've mine running for 10 mins before I'm driving. I have heated screens from and back. The temp gauge hasn't even appeared by the time I leave Takes a few KM's depending on the driving to get to 90deg.
  7. https://www.briskoda.net/forums/topic/535580-head-lamp-led-become-yellow/?&do=getLastComment
  8. If you've the battery changed ,it does take a few miles to fully charge I believe. As for other options, of not the ABS, maybe the ABS ring or the socket for the sensor or loom. At this stage you need to do a bit of logging.
  9. Just my 2 Cents, but the 3 biggest cause of random issues featuring a Christmas Lights display seem to be Depleted Battery, ABS Sensor followed by Cam position sensor, although the last refers to more of a drivability issue.
  10. Skoda Air Flaps reeet.
  11. I think he means the LED Board within the headlight.
  12. Sprayed the entire sensor in IPA. Not had the issue since.
  13. I've not seen this option on mine. I have the same model/year as you. Out of curiosity is there a version with dynamic indicators in the front headlights or am I dreaming?
  14. Does it not measure Rear Right deviation? I notice on your results it says not installed.
  15. I had same issue. 2019, cars is on its 3rd battery now. When coding the latest Battery in VCDS I noticed the previous installer of the Halfords Battery hadn't coded it in. Maybe this led to its early demise. I first noticed the issue when the trip computer and vehicle statistics all reset at half a tank. I panicked and though I'd a hole iny fuel tank because I'd only done half the distance I usually do. It wasn't until I checked the odometer and compared it to my fuel logging app did I see the error! After that, the following day after a short trip the day befor I was presented with Christmas 🎄 Lights on the dash! I knew 99% it was the battery , 1% chance an ABS sensor.
  16. I'm assuming they meant check the wiring going to the struts rather than the internal strut wiring. To me it sounds like a damaged cable.
  17. Ah, i though you were getting the complete Google maps on the dash. Now I understand !
  18. Sorry, I should have clarified. What I meant was, can you do Google Satellite view on the Digital Dashboard.
  19. No, it's all got to come out.
