travs
Everything posted by travs
  1. I don't think this is a birdbomb alone. My instinct would be to say that that is a respray with sub-par panel prep, or a single-stage respray (colour-layer and clearcoat all in one). You can test the latter by using some polish on an area near and see if the cloth has colour on it (I don't think Skoda uses coloured clearcoats). I've seen it be absorbed into clearcoat (what is commonly referred to as 'etching'), but it needs to be left on the paint in the sun as the clearcoat opens up in the heat and absorbs the contaminant. To seemingly go through clear and penetrate into colour to the extent it lifts it doesn't pass the smell test for a factory paintjob...
  2. Either way, I think the best place to start is autotrader...😇
  3. This came up recently - definitely normal
  4. Ok - next likely is a wheel speed sensor; usually the rear left. Not sure on any way to check other than looking for fault codes thrown.
  5. When was the battery changed last? Random gremlins are very common the battery getting to end of life.
  6. Few snaps from work. Such a good-looking car.
  7. Any random electrical gremlins should always be considered first as the result of a battery on its last legs. Unless you’ve changed it in the last 22 months, I’d do that first and see
  8. They're brilliant for low dust - amazing how clean the wheels stayed when running them.
  9. Meh - then it wasn't meant to be. Could have been a dog, could have been a gem. Either way, tomorrow's another day.
  10. If you planning on updated pads, leave the rears standard. I have DS2500 all round and the rears pads squeal as I don’t brake hard enough often enough. I have to brake late and hard. Thinking of swapping rear pads back to standard which will be a real waste but I’m just not using them. The 310mm are just a little too big for the 340mm front.
  11. Following on from JRRS’ points, it won’t rub because the wheels are already inside the wheel arch and when the suspension compresses, the wheels curve inwards rather than straight up. Even with wider tyres and spacers as suggested there’ll still be sufficient clearance. The Superb has a naturally tucked setup. Look from behind and you can see the wheels sit in-board compared to the body. Mine sits about 30mm lower and is absolutely fine too. You could always swap to 235/35. Makes the speedo over-read by an extra 1-2mph (but that’s a safer misread) but the car sits lower but gives a little more arch gap. But you really don’t need to do that at all.
  12. Definite red flag on no history. Bit odd that there’s absolutely no history but is that place from Skoda HQ? If not, approach them. Gearbox should be serviced at 40k miles so it’s due if it hasn’t been done. Haldex is every 2 years now but it use to be 3 so it should have had 3 services. However the exceptionally limited mileage (if genuine but assume you’ve checked that on the MOT history) should have mitigated running on poor servicing to some extent. My gut feel is they’re pricing it on mileage. If you ask too many questions on servicing etc they won’t bother wasting their time as they know they’ll get that a lot (if not already) and they’ll flip it to auction to be sold as seen. DSG service you’re looking at a few hundred. Each Haldex is about 150 so if nothing’s been done you want to factor in at least 600 for those. If it were me, it’d be an oil change straight away, and possibly brake fluid, air con, plugs. You’re looking at best part of £1k just for peace of mind. Then you want to be looking at the state of the brakes, cabin filter (easy miss if minimum maintenance has been carried out) and look at the air filter too; again that will give you an idea of whether it’s not been touched in a while. Low mileage can be great but it can also mean very short trips, not running the car up to temp often, and prolonged periods of sitting around. So it basically comes down to how the owner cared for it. It’s worth a look, but keep your eyes open, radar switched on and ignore pretty much everything the salesman tells you.
  13. I do prefer an angled look than perpendicular to the car. I also think if they weren’t diamond cut they’d look slightly softer. But they’re a good looking wheel in general, they’re forged, rare as hen’s teeth and exceptionally light. Are they perfect for the car? Maybe not but I absolutely love them for all that they are.
  14. Adding @Tiglon to this list too. Cheers Will!
  15. If you click on people's profile, you can see when they last logged in; especially important when a thread is a little old.
  16. While the front wheel was off I had a go at rotating the spring. It turned easier than I imagined, because the hub was hanging free. Will see what it’s like when manoeuvring. Fingers crossed!
  17. New (to me) wheels. McLaren 570 super light options. 7.5kg which should translate to less inertia to change wheel speed. And they look ****ing lovely. And will be so easy to clean!
  18. Couldn’t pass up the opportunity to put new wheels on when they came up. Given the temps are settling out of winter then it was time to get them on. (Yes the car needs a wash!)
  19. Pretty sure there isn’t an indicator on its own. When you put auto full-beam on, the indicator is blue, but when you’re in a slow or built-up well lit area that’s a white full-beam indicator. I think that’s the closest you get.
  20. Just seems to translate as turn signal. Turn them off is BMW-mode…? 🤭
  21. Its understandable about wheel bolts. I've got wheels from another make and they are almost the same but they're not. Same width, length, thread pitch, same seat design....ever so slightly different size seat size. M14mm x 1.5 (width x pitch depth), 27mm thread length, Radius seat (sometimes called Ball seat). Great. But Radius Seats come in R12, R13 and R14. Slightly different size. Skoda are R13, new wheels are R14.
  22. Awesome stuff. Bet that surprises a few onlookers when it disappears up the road
  23. Oof - lovely! #ERROR <SIGNATUREOUTOFDATE>
  24. And..of course what happened to the Remus? Maybe it can be sold to tombee if not already.
  25. Click on the profile and you can see the last visited time; 1st August 2025. May have moved on sadly
