S3 owners - electric tailgate / hatch closing from inside
Would you pay for the rear hatch / tailgate to close from the button inside the car? 129 members have voted
  1. 1. Would you pay for the rear hatch / tailgate to close from the button inside the car?
    • Yes, I live in Kent and would be happy to travel to Folkestone and pay for this to be enabled
      17%
    • I don’t live in Kent but would still be happy to travel to Folkestone and pay for this to be enabled
      72%
    • No, I live in Kent but this doesn’t interest me
      9%
  2. 2. How much would you be prepared to pay for this?
Please sign in or register to vote in this poll.
1 hour ago, ile7 said:
Easly done with carscanner, didn't had to choose other dataset version, just changed interior button option to allow open and close while ignition on and off. Closing with button pressed, opening tap button
Glad it worked ok. I’ve seen it work fine for some and others it won’t even read the module. I think it’s very dependent on what hardware you’re starting with!
  • Replies 211
  • Views 100.3k
  • seriousness aside -  a number of supercars deploy rear wing spoilers at high speeds for increased downforce/stability. bugatti, amongst others also use the rear spoilers as air-brakes too.
  • I've done 450 miles this week so far with another 330 to do tomorrow. Happy to drive to you. Happy to pay for it. Will bring you a pork pie and a decent bottle of melton red ale as a cultural exchange
  • As a disabled driver, I would happily pay a reasonable amount for this.  The non availability drives me bloody mad.  Who in their right mind would design a facility to open the tailgate from inside, o
On 01/08/2021 at 06:12, AlVal said:
Select the right module for the bootlid controller (6d), on the list on the right it's 'data transfer', and send the parent xml file (the one called "arbeits"), it will send any children files also
Hi, do you open the file and just use arbeits file? Thanks in advance Al
Hi @AlVal do you just send the parent file not the whole downloaded file?
Hi. I have a problem configuring the trunk lid closing function using the button located next to the DSG shifter. My control module is 5Q0959107L. During the attempt, the error shown in the attachment appears. “Odśwież” means “refresh.”
Facelift model?
5 minutes ago, defsix said:
Facelift model?
No, 2016.
It seems very hit and miss as to if it works with carscanner. Perhaps try a hard reset in the relevant long coding section?
Thank you for your reply. Could you explain to me how to do it? I’m a beginner.
@Dawid93 check in 6D module Adaptation, line Activation using rear lid remote unlocking switch-Tap function for closing
Do you have this visible?
Unfortunately not.
Go to long coding, boot lid and then scroll to bottom and select hard reset.
Long coding
6D bootlid
Hard reset
