Modifying Your Fabia MK III
Ok good, are You also change positioning switch inside car ? This is important too.  Regards Łukasz
  • Replies 1.1k
  • Views 289.3k
  • matt_black_90
    matt_black_90
    New emblems from Superskoda
  • matt_black_90
    matt_black_90
    I've built a small 8" subwoofer for my Fabia It's designed to fit snugly in the "basket" in the trunk and have a quick connection so it's easy to remove if needed.  If someone wants to see
  • Just bought my monte carlo a few weeks ago.    Only done a few mods to it so far.   I've lowered it on eibach springs (30/45mm) and sprayed the badges black.    Also clay
What is the positioning switch? Can you send a picture?
Hi, this is it 6V0941333.
I do not know how it is in it, only the difference is that it is up and down in the direction of the h4 lamp.
No, not only this, the light is too low even you set on hi position. You need replace them.
But then what is the other type? I'll see you later this afternoon. Anyway, I set the lights manually to suit the height.
Is not possible to set them right manual. You dont pass MOT i make test on testing tool And is too low. Send privat message we can contact via skype.
Hello! I would like to install an aftermarket steering wheel but idk what short hub + quick release to choose.. any suggestions ?
On 26/07/2017 at 20:35, Nathanb93 said:
I think im going to get the friedrich motorsport exhaust, they are on ebay and arent too expensive, you also get to choose the end tip. And the pipe comes out a little more to the left so it doesnt come through on the rib of the diffuser.
Hi I´m new in the foro. Did you install it finally?
6 Month delivery date. :o
Look closely.
Thanks AG Falco
Look closely.
Thanks AG Falco
pic was posted in july :nerd:
Yes, the look closely comment was hinting at that.
Thanks AG Falco
Hi Guys,
Can static cornering lights be enabled by the dealer on the request, and how much would they charge for this. My previous Polo had this function but not on my Fabia :(
9 hours ago, EdHru said:
Hi Guys,
Hi,
- Modul 09 - Central-Electronics
- Adaptation 10
(5) -Leuchte12NL LB40-Light_Function_B_12  mod to Abbiegelicht links
(5) -Leuchte13NL RB3-Light_Function_B_13  mod to Abbiegelicht rechts
This was the setting I had for the Fabia 3 for the corner light.
My front fog lights are used as cornering lights.
Switched them on myself using Carista module.
Unfortunately I have no access to Carista module.
8 hours ago, rooflessdriver said:
Thanks for this. To be honest I didn't know that you can get them on Amazon. Reviews are saying that an app is required to use it at the cost of £40. Is it worth having it long term?
did you had to pay extra for the app/subscription to enable this?
you usually get a month for free carista if subscribe, make  your changes, then before the month ends cancel subscription
From memory you get a month free which is enough to play with it.
i subscribed as my car is leased so I can revert changes when serviced or returned.
plus more changes appear every so often.
Hi, no haven't bought one yet. I heard it voids the engine warranty so I'm just going to wait.
Are 17" Gigaros from 2010 MK2 VRS a direct fit to the Mk3 Monte 2016?? Is there anything else to be aware of apart from the tyre size change??
I want to respray and powder coat my old 17" MK2 VRS Gigaro Alloys and replace the 16'' spiders to the MK3 Monte (with new tyres)
Will be going from 215 /45 /16 to 205/40/17 (0.7% less on speedo - got loads of spare 205/40/17 tyres)
the 16" spiders will be getting winter tyres at a later date.
Going for a gun metal dark grey look. not sure what this colour is off website but i like them a lot
getting done at same place as my Green MK2 wheels £160 Preston http://www.tillingalloywheelrefurbishment.co.uk/
Absout lowering springs.
Will springs made for 1.2tsi fit 1.0tsi?
Don’t want to get it wrong. It’s 30/40mm springs
There's eibach's which are for both the 90bhp 1.2 and all the 1.0 versions.
https://www.dpmperformance.co.uk/car-parts/skoda/fabia/eibach-30mm45mm-pro-lowering-suspension-springsfabia-nj-10-10tsi-12tsi-082014
The main thing you want to look at is the front axle loading. If you put higher loading springs on (for the 1.2 110 or 1.4 tdi) the front may ride high and/or stiffer than expected.
The 1.0 is a light engine, so you want lower loaded ones. Go off the weights in the eibach one for a start maybe. (I'm getting the eibachs i linked later this summer closer to insurance renewal time).
Edited by FabiaGonzales
