- Fabia 2024 door plastic
Have you asked a Skoda Dealership in Israel for the cost of new replacement parts? If the new ones faded because of Climate / Environment are new ones not just going to go the same way? A Skoda Fundamental Design, Engineering, manufacturing, material fault and a product not suitable for your region. TELL THEM!.
Evolution13 started following Fabia 2024 door plastic
Yogev started following Fabia 2024 door plastic
CHIPPED OR NOT?
Thanks Warrior193, that's exactly what the code reader says; can you point me in the right direction to check the connection? It's a bit of a bird's nest under the plastic cover and there is a bit of damage to the metallised fabric heat shield that's now held in place by tie-wraps because the pop fasteners have torn out of the fabric..... No, only the faulty one was changed (£154 +VAT) so they didn't bother with the second one which appeared at the time to be OK, because of the price. The question still remains - is there an easy way to see if the ECU has been modified to allow extra "poke"?
Skoda Karoq 1.5 DSG gearbox
As far a cracking / leaking & also the accumulator cracking. 2017 there was a Service Campaign started on 2013-2016 DQ200,s., 3 times recalled in Australia. (There are repair kits and upgrades, but not from VW. ) This was '34H5' a software update. This is nothing to do with '34F7' 2009-2012 Changed synthetic to mineral oil and a software update. Millions recalled globally but only a service campaign in the EU / Europe. IMPORTANT. No point comparing issues. 2009-2012, or 2013-2015/16 with the DQ200,s built 2015 on and the issues. Then the 1.5TSI Kangerooing issue up to 2019/20 was Manual or DSG, and there were Updates. Maybe more hidden with a DSG. Later Stop / Start , cutting out issues and another Kettle of Fish, or Can of Worms. As to this link... There were Clutch Upgrades and software updates. http://briskoda.net/forums/topic/439395-the-story-of-the-famous-dq200-clutch-slip
@thamestrader A DQ200 DSG should not start of in 2nd regardless of fitted to a TSI or TDI from 70 ps - 192 ps. There is a small filter in the MCU, but that needs to be off and opened to change it. @munnst Who is it that advises changing the MCU oil at 40,000 miles? Can you link something to this affect? There is so many Chinese Whispers stuff regarding this online. If changing the Oil change both oils, if you know what you are doing. IMO. Cleaning out the stoor in beside the clutches is more important as far as i am concerned.
Evolution13 started following Skoda Karoq 1.5 DSG gearbox
Columbus Software Version
Hi , just checked mine it is on Software version 0519
2011 Superb VR6 Starts then dies, Fuel Issue??
First link in Google... https://lmgtfy.com/?q=vcds+software
@thamestrader yes I know that but it seems like replacing the fluid can allow any circulating "bits" to get dumped out - while VW Group maintain it is not required. I was only speculating that having the fluid changed might, just might have meant avoiding this issue - although if it is the accumulator developing cracks then nothing would have avoided that in the initial build of the Mecha unit. Edit:- though you are talking about aspects of DSG use that, as someone that has yet to use one, has always concerned me, maybe without any good logic or reason.
Error: selector lever...
Clearly an old issue. I had the "error selector lever" message twice whilst in France about 10 days ago. It has not re-appeared in about 1200 miles driving since. I will call the dealer on Monday. As an aside, with diesel now costing the equivalent of more tha £2 per litre in France, its a good thing that the VRS diesel averaged over 59mpg for the trip!
NormanE started following Error: selector lever...
I've not been offered any new updates since my last post so fingers crossed it is finished now
Willie94 joined the community
Brake pads wear indicator does fabia colour edition have brake pads wear indicator light on dash ?
Thanks very informative 👍
Firmware update MST2_EU_SK_PQ_P0369T
Anyone have access to a copy of the firmware upgrade MST2_EU_SK_PQ_P0369T For a 2017 Skoda yeti infotainment system as shown In photo
Marty started following Firmware update MST2_EU_SK_PQ_P0369T
the truth about electric cars
The only car to appear in 3 sections as well.
Rbz5416 started following Columbus Software Version
What version do you have? Mine is on 0519 & doesn't seem to have changed in the 15 months of owning the car. Certainly not since December when I first recorded it.
Have had well worn pads that I reckond would be ok for a while as car wasnt getting used that much but due to age and wear/heat the pad parted company from the backing plate. You get a definite squeel when that happens. If there well worn as in down to 2-3mm I would change them for peace of mind. Alasdair
Constant app updates
Something you guys might want to check. Not sure if it was the result of the work a dealer did last week or a subsequent OTA update, but my instrument/infotainment lighting is now stuck on max, with the slider to adjust doing nothing. Makes driving at night problematic due to the high level of light beamed into the eye line. 🤬
This link may be of interest https://www.sunset-derby.co.uk/how-do-you-fix-your-vws-squeaky-brakes/ You said in your original posting "...my brake pads seem to be well worn...". Assuming it's your car's front brakes that are squealing, received wisdom (example here) https://www.rac.co.uk/drive/advice/car-maintenance/brake-pads/ is that, if the pads' thickness has to reduced to 3mm, the pads should be replaced, but that advice obviously depends on a car's annual mileage. My wife's bought-new-in 2009 Skoda Roomster has only covered 27k miles, does under a 1k miles annually nowadays, and its original front and rear disc pads still have plenty of 'meat' on them.
cop4u joined the community
Mxl joined the community
Marty joined the community
- Skoda Karoq 1.5 DSG gearbox
DGW started following CHIPPED OR NOT?
Firmware 6276 source
Download link for RNS510-5238A-josi-VIM-Testmode-60-35-5 sent in PM
SimkoVojta joined the community
- 01276 ABS Pump
Vrs Engine cooling fan
I had same problem there was water or moist in the ecu connection. The windshield had been reaplaced and the plastic lip under the wipers that should click in to the windsield rubber was broken,cousing water to leek to the sraight to ecu connection. Cousing the car to safe mode fans full blast, obd reading nothing. Dried connecions and sealed the crack with silicone now no problem Regards Jon
nonni started following Vrs Engine cooling fan
01276 ABS Pump
It maybe a loose connection somewhere or bad earth. The fact that it worked under heavy braking may have moved connector or broken wire. Did you remove and check fuses for looseness and corosion? Sons Mk1 fabia had an intermittent fault and it was a cracked strip fuse in engine bay fuse box. Only noticed when I removed fuse and it broke in two. Alasdair
