  2. Best asked on the Octavia Mk4 forum https://www.briskoda.net/forums/forum/396-skoda-octavia-mk4-2020/
  3. I have the same set up. It works about 75% of the time. However, sometimes it fails to charge altogether. Others (like now), Octopus says the car is not plugged in at home when it is. Has been like this for the 6 months I've owned the car. I suspect it's an issue with the car, not Octopus. Does it work faultlessly for you?
  4. Meant to add check the main feed from battery to starter is tight. If its slightly loose it may explain V drop. You could also check voltage accross battery when cranking to see how far it drops. Alasdair
  5. I have a granny charger and Octopus Intelligent Go. Octopus controls the charging perfectly 👍 You can set departure and max charge percentage and cap to off peak only if you like. Can also boost charge of you are peak and need to charge. Works off location and handshake with Skoda to know when plugged in and stopped/start charging.
  6. I get the same reversing on to the drive with my other Half's car parked to the left at 90 degrees. Car thinks I will hit and frightens me to death when it slams on.
  7. Hi, Has anyone else encountered this error, P256300? The yellow coil light appeared 2–3 times, followed by the "check engine" light. How did you resolve it? From my research, it seems to be related to the "turbo actuator." The vehicle is a 2014 model with a 2.0 CFGB engine and DSG transmission.
  8. Ratza25 started following Error P256300
  9. Dubb3rz started following Manoeuvre Braking
  10. there is difference LHD are using right inner light part number 5E6 945 308 A and RHD 5E6 945 308 C and to make sure do you have Full Led lights (Matrix,Top Led)
  11. Today
  12. Hey guys, Just picked up a 2010 Octavia mk2 about a week ago, so I'm still very new to the car and trying to figure out all the quirks. Running into a weird Bluetooth issue and hoping someone here knows if this is an easy fix or just how it is. The car has the standard Bolero radio (with the factory 3.5mm AUX in the center armrest) and a Kufatec FISCON Basic Plus module installed (Maxi-DOT shows Mainboard 2.16, PBoard 3.31.6). Regular hands-free phone calls work great through the steering wheel buttons and Bolero display. But whenever I try to play music from my phone, the car basically acts like I'm on a phone call. The audio comes out in flat, tinny mono with zero bass. Meanwhile, on the Bolero display under the MEDIA menu, the "BT-Audio" button is completely greyed out and unclickable. Could this be as simple as the wiring being plugged into the wrong pins behind the radio? For example, the Kufatec harness output being wired to the mono TEL+ / TEL- pins instead of tapping into the stereo pins (like the AUX or CD changer inputs)? Or is this specific Fiscon box just hardwired to only do mono audio like that, or maybe missing some VCDS coding to wake up the BT-Audio button? What I’ve already checked/tried: Radio Settings: Went through the Bolero setup menus to ensure "Bluetooth Audio" and "AUX" are enabled/ticked. The settings are turned on, but the actual on-screen button under Media stays inactive, grayed-out. Phone connection: Checked the Bluetooth profile on the phone, it shows connected for both "Calls" and " media audio". Re-pairing: Deleted the device, re-paired from scratch, and tested, same result. Just wondering if it's worth pulling the head unit out to inspect and repin the harness, or if I'm better off not wasting time and just plugging a small Bluetooth modulator receiver. Thanks for any help or advice!
  13. There are two or three engine codes that fall within your description, on two different parts diagrams. Item 6 here if all 3 scrwws are the same https://www.lllparts.co.uk/catalogs/skoda/CZ/RO/481/1/131/131035 Item 8 (two lines in table) if there are 2 shorter and 1 long https://www.lllparts.co.uk/catalogs/skoda/CZ/RO/481/1/131/131030
  14. They should be changed on the B service (every 2yrs) on the Merc. Generally remote key batteries did last for years in the past though - I don't recall batteries running out being a big deal until keyless entry fobs arrived.
  15. Sorry for the mistyping. 1500rpm only of course. 😉
  16. Check the spade connection sizes. It could be that the starter has a slightly smaller spade than one than the spade connector. There normally 4.8mm or 6.3mm Alasdair
  17. Has anyone found a VAG jack pad insert for the Octavia Mark 4. Powerflex say they don't do one. However, I wonder if the PF3-1663 for Mark 3's will fit if one is prepared to adapt the underbody panels by trimming the existing holes back a little. The plastic plugs in the floor are clearly visible. Please let me know if you can advise on this. Many thanks
  18. mib helper is your friend for such info... https://mib-helper.com/index.php?train=MST2_EU_SK_ZR_P0241T
  19. FakeRalph joined the community
  20. Radio wires - yes I checked with multimeter at time. AI says the aftermarket are susceptible to voltage drop and under 10.5v they shut down. Suggested I buy add on that has loom and small capacitor to take up the drop in voltage on cranking. Car wouldn't start now - the spade connector in starter motor had popped out. Any suggestions on holding it in? I crimped spade connector for tighter fit but it was already as tight as it would go. The aftermarket starter motor might have had some wear on its male spade end. I used duct tape but it came unstuck. Soldering a bit extreme and hard to get to. Don't think this is related to radio though. Thanks Ps found this for starter motor relay wire. 1K0973751 1 Pin Prewired Starter Connector for VW AUDI Seat. Currently there is just a female spade connector. Will this part fit? Methinks not....
  21. igerecs joined the community
  22. Hi everyone, I have a 2018 Skoda Octavia and I'm thinking about getting a set of all-season tyres. I'm a bit tired of changing between summer and winter tyres every year, so I thought it might be worth giving them a try. I mostly drive around town, with occasional longer trips, so I need something that handles well in the rain and is also decent in colder weather and light snow. I've been looking at a few different brands and comparing prices online, but there are so many options that it's hard to decide. I also came across an autodoc review while looking for information about online parts and tyre shops. What tyres are you guys using? Any recommendations based on your own experience? I'd especially appreciate suggestions that offer a good balance between price, comfort and durability. Thanks!
  23. Could they have been changed as part of a service? Even if the Merc doesn't have kessy, 14 years from a single battery seems a stretch. Unless they're rechargeable? I had a 3 Series where the battery in the fob recharged wirelessly while driving. The car died after 15 years but the key was still going strong.
  24. From memory the yellow wire I think is permanent live and red is from ignition. The yellow wire is there to keep settings etc. It may be that the Kenwood is more susceptible to voltage drop. Check that the yellow wire is getting 12v with ignition off. Alasdair
  25. I hope Amazon Duracell are OK. BTW, we have a Mercedes 62 reg C180 with 20,000 miles showing and the key fobs have never been changed. Could Skoda fobs last that long?
  26. Apologies, it’s for a 19td Skoda roomster 2 - 2007, I thought I had posted the details - thanks for looking
  27. mdasem joined the community
  28. JozsefK74 joined the community
  29. OK. So to enable both fog lamps only a coding/adaptation OR dataset change is required. I'm trying to figure them out. For sure there is a small difference between LHD and RHD cars, and merging them will results in both fog lamps on. Can you share a BCM backup of your current state? Thank you
  30. Long time no posting! I’ve recently moved over to the dark side and purchased a full electric ( not a Skoda…) In my driveway, I have my 2011 petrol VRS estate. Current state: Occasional ECU communication errors (mainly in very wet days!) Needs wheel speed sensor (traction control error warning) MOT expired (although I’m confident it will pass once the sensor is replaced) My question is: Replace wheel sensor, get MOT, sell through auto trader Get ridiculously low price from We Buy Anycar as is Scrap Other option? To be honest, I’m not comfortable advertising on Autotrader as I would feel bad about the occasional ECU error unless the person buying was comfortable resetting the error code every now and then!
  31. I've had 3 MK4 Petrol VRS' (hatch, 2020, 2023, 2025), and the average for all of them has been between 40-42mpg. Can easily be 50mpg on a long motorway run, and if I get 30mpg on a Sainsbury's run then I've done well. It's pretty efficient if you are happy to drive sensibly!
  32. Check the battery voltage while engine is being cranked - likely that voltage is dropping too low during engine crank.
