DarinL joined the community
Skoda Karoq 2.0 TDI - SE-L, 4x4 - manual
I have a guaranteed trade payout locked in for 11:00 AM tomorrow. Offering this to a private buyer or enthusiast first for £6900 firm. Car is fully packed, cleaned, and documents ready. If you want a clean 2019 Karoq at trade valuation before it goes to a dealer, message me before 10:00 AM. I have also 2 extra tyres for it. Finance was cleared. Will take a few days to clear with HPI.
Yeti - When to sell ... Or keep?
My 2.0 lt TDi has achieved 84K and seems to be doing well, no DPF/EGR issues (so far) apart from the usual belt and water pump, it's required nothing beyond the usual consumables. I don't go for dealer servicing, MOT covers most things in a service ( as a service is mostly check/inspect xyz) and I always get an annual oil change with the MOT. filters are about the only thing that doesn't require a computer that I can still fix. I'm not changing mine until repairs exceed value, it's a shame they didn't make a mark II instead of becoming one of the look alike sheep with the subsequent Yeti replacements
Stevejd58 started following Yeti - When to sell ... Or keep?
Fuse Box Under Bonnet Help
Does the stud go down and connect to the thick black wire below? The one that goes out at the bottom left of your first photo. If so does that go to the positive battery terminal? Thanks. AG Falco
AGFalco started following Fuse Box Under Bonnet Help
Thanks for the tip but none of the fuse boxes match my Elroq one. I would be very grateful if another Elroq owner would pop the bonnet open and take a sneaky look and see if they too have a missing nut not? Just trying to avoid driving 50 miles to the dealer to look at another Elroq myself. Fingers crossed it's the same as mine
The Epiq is a similar size. Decent boot, good value, quick enough, good range. Might have a look later in the year at the bigger battery one.
PSA Re traveling to Ireland
Soon you'll need a full passport to travel to Ireland on the ferry. NI unaffected but advice is to check when booking. https://www.itv.com/news/wales/2026-08-26/new-passport-rule-for-uk-ireland-ferry-passengers
Hi, This is the version I currently have. Thanks for explaining how to find it. 🙂 I´ll check for the rest of the week, but I fear the MMI of my Kodiaq Mk1 still downloads repeatedly the same updates… 🫤
Requesting some help for updating from v1664
Hello, The 03A7 recall campaign relates to the changeover in 1989. Why not try this free recall at the dealership? Also, if you visit this page, you may see other outstanding recalls at the bottom. https://www.octavia-rs.eu/rueckrufaktionen-feldmassnahmen/
BeaverRS started following Requesting some help for updating from v1664
Oil level...
In an earlier posting you said "My dipstick is exactly the same as the manual describes BUT there is not ANY treatment at the marked area as shown in S19-0760 picture - it is just plain steel." Is that actually the case, or does your car's dipstick have the raised 'dotted' section shown in the image in my last posting? This Toyota Tacoma-related Facebook entry discussed reading the oil level on a dipstick when thin oil is being used in a vehicle https://www.facebook.com/groups/4870321056422088/posts/6768461309941377/ and the following three 'tricks' were suggested 1) Use a brand new or extremely sharp hacksaw blade or metal file to “scratch” up both sides of the dipstick with a crosshatch pattern. Be certain to wipe all metal powder/dust before inserting into the engine. If this doesn’t work then add the following to #1. 2) Use a piece of regular stick chalk to rub on the cross hatches when the stick is completely wiped off. Insert dipstick and pull out to see where the level shows on the chalk. Clean off all chalk before reinserting after level is viewed. If you don’t want to do #1 and # 2 then try #3. 3) Have a piece of absorbent white paper towel or absorbent tissue paper. When the dipstick is pulled out quickly then slowly slide the paper towel or tissue edge held tight on the metal from top down toward full mark. When first sight of oil shows on the towel that’s the level. Holding a powerful light close during either of these methods also helps especially if you are in shade or dark conditions. My 2009 Skoda Roomster's dipstick has a single O-ring seal, but my 2024 Fabia's dipstick has two O-rings (image attached) and - as its 'handle' is angled - it is only practicable to fully insert the dipstick in one orientation. Engine hot or engine cold, the two O-rings mean that a good upwards pull is needed to remove the dipstick.
oil filter 3v5 DTUA
Hello, I have a 2021 Superb 2.0 TDI DTUA 200hp and it has part nr "05L 115 562 A" for oil filter, which is the 161mm one.
SlawekPetke joined the community
VAG_DPF application - log analysis and plots
VAG_DPF_Diagnostics_Manual_2026-08-25_09-57-22.pdf
vgoctav started following VAG_DPF application - log analysis and plots
Meurtz joined the community
2015 VRS TDI - Coolant loss from expansion tank
On oil consumption, I’ve now had the car back a week and while not done massive miles I’ve driven it everyday and cover maybe 30miles everyday at least, so far no noticeable drop in oil. I’m doing a couple of longer drives over the weekend so will feedback again but I’d say it’s definitely improved.
Vesko_1 joined the community
Venus joined the community
Another Oil Consumption Topic
Measured mine recently. Im burning 1 litre of oil to every 650 miles. Its also regenning more often than not, which takes me back to my original post. Is the mid range oil which is mainly used on services good enough for the Cupa/Cuna engine? The oil is getting too hot, too often, due to the regens, and the oil is breaking down faster and making its way past the rings. Makes me wonder if thats why some swear by Ravenol/Liquid Moly with Ceratec. As they may have better heat resistance. Obviously doesn't take away the fact the piston rings were never good to start with. But can it be slowed down by better quality oils, and a DPF/EGR delete?
Odin515 joined the community
- Battery discharging very quickly
I have similar issue but i have done fair bit of mileage, mine is a 66 plate 2.0 TDI and clocked 180k. Lately its been consuming too much oil, i do about 20 to 25k miles a year, but this is my 3rd oil top up of about 500ml within this year. I never used to do it then i did once a year then two and this time its three. i might have done 4 to 5k miles between the topups. looking at forum it looks like its not abnormal.
bret started following Another Oil Consumption Topic
bret joined the community
I found out that on Obd11 you have to go to 4B module, switch to raw binary view(click bytes icon). Then find byte 11 and deselect bit 0. Important to reset headlights after - go to main module 4B main screen and select Basic Settings, run Headlights Basic Settings routine and then run Acknowledge Headlight Basic routine -that should do the job. Let me know if that worked for you. I don't have obd 11 and using Car Scanner, that's why I had to get some help. Hope it will go well!
Coolant tank replacement - Should I be worried?
Thanks all for the advice. As I said I am overdue on the water pump, so I will change to the G12 evo when I fill the coolant back up.
Fog light comes on with headlamps + missing bumper cover
Do the fog lights actually come on with headlights or just the dash symbol. Had foglight symbol on dash when headlights were on but fog lights as far as I can remember were off (cant actually remeber if I checked) until switched on. It turned out to be a bad connection at rear of cluster. I removed cluster and cleaned and reseated it. Had a few dim lights on dash as well including DPF. Same car as yours 1.9bxe so no dpf which made me think cluster was problem not wiring. If your removing cluster disconnect battery first. Alasdair
This thread may help. Third post down https://www.briskoda.net/forums/topic/515242-fuse-help/
Almost certainly this. Other end looks to be riveted in, so standard part of box whether used or not.
its not mentioned in the book, it may be wrong or just an unused fitting, I need to know what other peoples Elroqs'look like to know, but your right it does look wrong. Maybe something is supposed to bolt to it, but its not fitted to my car??
Warrior193 started following Battery discharging very quickly
the truth about electric cars
Best selling car (not just EVs) in China, about half million, which is by far largest car market in the world. That looks very good value and would probably suit a lot of people...
I'm not convinced; they were imported in multiple container loads at a time, so they weren't low-value imports. Most of them in my area were destined for a large warehouse in Essex and a couple in East London. They were going to huge wholesalers who had set themselves up as suppliers to smaller independent wholesalers who were not large enough, or had poor credit ratings. Meaning main large-name UK and European manufacturers would not supply them. Often these smaller wholesalers would operate from a shopfront and would sell to the general public,, who would not be allowed to use a proper wholesaler.
Good afternoon Dave, is the 80Amp fuse link under where the nylon fuse extractor is? That missing terminal post nut clearly looks wrong - what does that fuse protect?
