Coasting
I turned it off on my 2023 280tsi via the Gateway module using VCDS as above.
Photography Thread
What are they?
3rd agree, should be attached to the exhaust as they look like dampers to me. Also there is no tray, they go into a cross member between the subframe. Thats without looking at a parts list.
Another Oil Consumption Topic
Hmm, with the dpf deleted wouldnt the car smoke a lot and blow big black clouds of exhaust fumes out the back, with that kind of oil consumption. Personally wouldnt want to be driving behind your car...the exhaust fumes would smell really terrible and couldnt see **** for a while๐คฃ. A working dpf really makes a difference, the diesel exhaust stays clean and doesnt smell anything like the old diesels did. Also in my country its illegal to delete dpf, if you get caught, the fines you get from doing that are counted in thousands of euros.
- Skoda superb estate
Lost Tailgate Led lights animation when unlocking the car ๐
I put all the details in lightning adaptations in Leuchte23SL HLC10, Leuchte24SL HRA65 and Leuchte27NSL RC6. First unlocking the car successfull๐ animation worked as it should. Closing the same. Then when I unlocked the car again went back to static. Locking still OK-animation works OK. I'm not sure if there is other module than Lightning Adaptations where animation of tailgate lights is controlled.. I will try, thanks Cairus. This backup has a lot of useful information ๐๐ Obviously changes made with ignition on, engine off, bonet opened. After coding scanned for errors and cleared few archived ones, reset lights in car menu-factory reset-lights, infotainment reset and car left for 20 minutes with key away from it...
Is there an update to Infotainment System (5Q0035842A / H24) newer than 0241?
Hello. I need help. I would like to update my car, but i got NO idea how or where to get the software. I am quite a newbie in this lol Number is 5Q0035840A Hardware: H24 Software: 0245 Thank you!
vallhala joined the community
2014 Octavia MK3 Estate 1.6 TDI (110hp) - Front PDC factory options & retrofit?
Yes
Won't adding front parking sensors also require the PDC module to be changed from a 4 channel one to an 8 channel one?
enoktakenokta started following 2025 Skoda Superb Navigation Update
Hi. I am from Turkey. I want to make an expert install the navigation. I checked update portal to be sure that whether there is map update or not. I entered vin number but it showed that there is no new map data. Is there anybody to explain the problem.
2026 Sportline MHEV
On my early Mk4 (2020) there are options to change colour and brightness of the ambient lighting; I assume similar on the newer FL models so maybe check for the brightness settings.
SteveTheElder started following 2026 Sportline MHEV
Work?
DanHot joined the community
2026 Sportline MHEV
How do i activate my ambient lighting? I can get the spectrum to show up and I can change the screen background but there are no lights on the door strips or across the dashboard. I have the free month trial of Ambient Lighting Additional Colours and Ambient Lighting Additional Features installed from the My Skoda app and activated, but nothing lights up. Can I get rid of or change the red ring around the 2 circular dashboard dials?
YMe started following 2026 Sportline MHEV
What are they?
Agreed... They are the exhaust hangers (or in this case they are 'inverted' hangers
Electric boot Struts
Thanks.. the only real issue I had was getting the rubber boot back over my repair, but I did it and the boot operates as it should..How long for who knows...
- What are they?
MikeTheThinker started following Wheel Caps
- Cruise control. Mine stopped working. Eventually I discovered that I had switched off the skid control, by pressing the button,
paul1973 joined the community
What are they?
Unless I'm missing something, aren't they supports for the exhaust rather than pipes?
rabbituk started following What are they?
Wheel Caps
I have the following wheel caps on my MY20 Mk3 Octavia. The chrome finish is prone to corroding and I am already on a second set. At ยฃ18 each, ยฃ72 for the set is a bit steep however, I will be getting my Geminis refurbished imminently and begrudge putting the old caps back on in their current state. Wings SKODASKODA Decorative centrepiece of the wheel SKODAEven your SKODA deserves to be elegant at all times. In case you ever loose it, SKODA Genuine Accessories offers you a decorative wheel centrepiece with new company badge, which is perfectly identicalThe following are the โlatest styleโ wheel caps, available at a far more reasonable ยฃ20 a set. The MY20 Mk3 Octavia isnโt listed as a compatible vehicle however. Has anybody fitted these to a Mk3 Octavia or able to advise on how the finish holds up? Iโll probably give Wings a call to clarify the compatibility and report back. Wings SKODASKODA Decorative Wheel Caps - Latest StyleBy using the wide range of ล koda Genuine Accessories you can draw individual style of your car to perfection. Fit the already attractive light alloy wheels of your car with wheel center caps. Plastic
CookieMonster87 started following Wheel Caps
RNS 315 Fabia mk2 Retrofit
All sounds perfectly fine. The radio will go into standby when you take the key out. Yes, you can still turn it back on as it's on a permanent live, but while it's off, it's drawing next to nothing. I did the same retrofit to my mum's (now mine) Fabia II Combi in 2014, 12 years later, both the car and the RNS-315 have been fine with no flat battery issues. However, that said I finally removed it about two weeks ago and replaced it with an RCD 360. As map support for the RNS-315 ended years ago, I wanted more functional sat-nav in the car, so the CarPlay support of the 360 - and its factory look - has worked well. I just need someone with VCDS to hemp me code out the reversing camera setting on it.
chrisgreen started following RNS 315 Fabia mk2 Retrofit
SD cards and the Amundsen infotainment system.
The CID in ASCII simple "MIBSTD"
Windows, Mirrors and Doors Issues
Hi all, Looking at purchasing a 2010 Superb 2.0l SE at 160,000miles. Engine history looks confidence inspiring but it has a few electrical issues that are either a common fix, or a big deal, and I'm trying to work out if its worth taking the project on. Drivers (right hand) door only opens using key manually in lock. All other central locking works ok. Rear o/s door does not open from in or out (deadlocked) Both front windows and mirrors temperamental. Looks like the cables through the drivers door have a had small solder/fix at some point. Is this likely a simple DIY job with a new wiring harness, or a quick fix for an auto electrician, or might something larger be at play here? ordering a full loom? I have read the many similar threads on here, but its a bit of mission trying to decipher them all, so any advice much appreciated.
dashupgrade started following Windows, Mirrors and Doors Issues
Look AliExpress
