Advice on new (to me) 25-plate Scala SE 116 TSI
Don’t get obsessed with the voltmeter, when you first start up does the voltage raise over 13 volts?:- A)When you unlock the car and open the door even before you get anywhere turning it on the car will have fired up systems and the fuel pump ready for action which will effectively show a lower voltage. B)Modern stop / start charging systems are designed to save the odd bit of petrol by turning down charging after a while (On my Superb my voltage sensitive cool box used to shut down!) but overcharging when on the overrun to recoup energy (down hill etc). That’s why you need a better stop/start battery (EFB or AGM etc) as a traditional wet battery would struggle and fail prematurely. Stop/start errors are common - (eg you’ve only driven short journeys) but could be related to the gear indicator issue mentioned. Only unless your battery is in good fettle, car warmed up etc will stop start work. RE buggy infotainment system, it’s well documented on this forum that it’s buggy. Might need a firmware update - again well documented. Re Cruise control, to some extent surging a bit up hill or braking downhill is normal as the car is trying to maintain a constant speed. Sometimes the effect of this can be tweaked in the car settings?
2011 Octavia 2.0TDI 140 CFHC Fuel Filter Confusion
Had similar problems with my 12 plate. Part number on canister is the part number for actual canister which I assumed was filter number. Local motor factors looked it up and got the correct filter for me. Alasdair
Alasdair1 started following 2011 Octavia 2.0TDI 140 CFHC Fuel Filter Confusion
- Fitting rear wheel arch liners - my experience
DGW started following skoda superb 2.0tdi not reaching operating temprature
@andreas joined the community
Axle stand location
Intuitively that makes sense, but the workshop manual is very strict about not lifting it anywhere else! Which is why I've come here. 9.3 Raise vehicle Raise vehicle with a lift platform or a workshop jack The vehicle must only be raised with a workshop jack in the indi‐ cated jacking points -arrow A- and -arrow B-. a = 12 cm b = 24 cm The jacking points are located at the stiff joints of the bottom side rail.
- Activating SmartLink on Swing 3
Deny joined the community
Update: All of the problems have persisted and some new ones have emerged: under downhill braking with a full load (three people plus luggage) the whole car was vibrating the infotainment system is very buggy, often freezing or generating random characters when entering an address into the SatNav or sometimes activating a different random function when pressing an icon on the menu "Stop/Start system error" messages occurring on the dash display The Stop/Start often doesn't even attempt to activate (with the crossed-out A icon showing on the dash display) Cruise control often surges/brakes (feels like I've changed down to 2nd and briefly got massive engine braking) Tacho display showing nonsense gear suggestions, e.g. 6 -> 1 @rum4mo I've bought a 12V plug-in voltmeter. I tested it against a multi-meter on an external power supply and in the car against a multi-meter connected directly to the battery terminals - both times it was within 0.1V, so I know it is accurate. When the car has been sitting for a few hours or overnight, the voltage is ~ 11.7-11.9V and after a journey - even a long motorway run - it is usually ~ 12.3-12.4V. This seems a bit low to me. The car has been back to the dealer twice now. The second time I discussed all of the issues in detail with the Workshop Controller when booking the car in. The first time they said they had "updated and reset all of the software" and the second time they said they had "done some more software updates". To be fair, the brakes are a lot better, but the other problems are just the same. I'm considering my next steps. Should I... buy an OBD2 scanner - is this likely to show anything useful? take the car to my local garage, where I have had previous vehicles serviced for many years, and get an independent assessment go back to the dealer and try to get some redress under the Consumer Rights Act 2015, i.e. a replacement vehicle or a partial refund be done with it and sell the car Anyone got any wisdom to share? Thanks, Andrew
vagfranko started following Activating SmartLink on Swing 3
- The state of early mk4's in 2026?
Jaguar, will it survive?
This is interesting. Maybe Jaguar does have a plan after all? It is a shame if traditional buyers are effectively frozen out by this divisive design, but as I said many times before, nobody was buying Jaguars. I'm also taking this article with a pinch of salt, but there's no smoke without fire, I reckon... https://www.motor1.com/news/811711/jaguar-ev-50000-people-interested/
- skoda superb 2.0tdi not reaching operating temprature
- Yesterday
Hello at last!
Hi JN12 Need to find a fabulous independent myself. Sounds like you are a problem solver. Useful asset to all
Hortiguy started following Hello at last!
Head Unit not starting up
My head unit (central screen) is completely black and not responding at all. The screen between dials on instrument panel is however, fine. Have I bricked the head unit, or does it just need a re-code? I did take it out, as needed to clean the space behind it. Not wanting it to dangle, I did disconnect it. Recently changed the battery, but that was weeks ago, and didn't cause any problems. I've found that the cabin filter only has foam on two sides, not four, so dirt was taking the easy route instead of going *through* the filter 🙄 I have ODBII, or would i need VCDS?
zeta_91 started following Head Unit not starting up
Any difference between diesel and petrol airbox on mk3 vrs?
It does indeed replacing the factory intake system. On the TDI. The EA288 and EA888 are totally different engines. The actual intake duct is probably very similar, but the airboxes themselves are not. You can, from what I've seen, potentially modify the TSI intake to fit the TDI, although I've no idea why you wouldn't just get a TSI intake to begin with. There's no shortage of Racingline/Forge examples.
OccyVRS started following My car's in a bad way , Any difference between diesel and petrol airbox on mk3 vrs? and Axle stand location
Axle stand location
Just to add - the jacking point on the sill is actually only for emergency use. The car isn't designed to be lifted here, if at all possible. Absolutely get a decent jack pad.
Well, this thread was a bit of a rollercoaster. I've given my car all it needs, and more, yet it keeps throwing up issues. I've now got an issue with the steering system (probably the rack, unless the drop links have decided to suddenly go), and having just spent over £800 getting some jacking point damage on the sills fixed, it''s pretty gutting. What are you thinking of next?
- My car's in a bad way
Car Shudders Various Lights Come On Goes Into Limp Mode
Fingers crossed. Interesting - on old BMW E36 forums it used to be: Car idling rough - camshaft position sensor Car idling rough and stalling - crankshaft position sensor.
Axle stand location
Hi, the below shows what you described and with a nice chunk of wood to ensure you won’t damage anything I would say this seems fine.
Cyco started following Axle stand location
AutoKULTUR joined the community
Cheers Pete
P176F00 "Clutch 2 closes unintentionally", returns after clearing. Sensor or mechatronic?
And what do you expect after 65,000 miles without an oil and filter change? The manufacturer claims 80,000 miles without service—lol, that’s advice for the gullible. As a rule, transmission fluid in these models should be changed every 60,000 km (35,000 miles). Sure, the service schedule says engine oil gets changed every two years... lol. Of course, the engine will last as long as the warranty holds, but afterwards—you'll be left wondering, "What was I thinking?" For RS models—and especially TDI models—the engine oil should be changed every 10,000 km, and the transmission is a whole other story. RS models are driven much harder and pushed to the limit—you really need to change the transmission fluid every 35,000 miles.
Long life servicing
all true
Use my part number in ebay with word genuine, and you get item number 277634634997 New genuine at about half price compared with dealership if you use the coupon.
maonus joined the community
John202020 joined the community
Brochure download
so do you have myskoda app? when you register you have all the brochures there .
I had 2 rs tsi 2021 and 2022 year. the problem is not so much in the software, as the problem is in the mib, those devices were assembled with old processors where procurement was in chaos due to covid. there were no chips, so they used old chips. only octaves from November 2023 use new chips and a stronger processor. that with old models is a lottery.
