  2. If theres no leaks I doubt pump will have failed at 15k but you never know. Any sign of Head gasket failure/bubbles in coolant etc. Could be exhaust gases that are causing an airlock somewhere. Are there electric pumps on yours as well as the main one. Alasdair
  3. Could be, the cold weather is hard on a battery. It could also be that certain sensors are a bit slow to respond during very cold weather hence the 2-3secs delay. My Octavia mk2 idle revs during the last cold spell were high but seem to have returned to normal now its above freezing. Alasdair
  4. Just got the Octavia back from the dealer after a sw update which took all of 3 days. Things are working much the same as before with the exception of the phone tethering which doesn't seem to work. I'm also seeing things like this - Carplay is visible- And at the same time... How can both of these appear at the same time? At this stage I am just so confused by all the connectivity options, many of which don't seem reliable. I am willing to accept that it may be a how to use issue but the manuals are pretty baffling as well. I find the myriad of connection options very baffling and there seem to be many dependencies and things that can go wrong. Does anyone have a block diagram of how it all links together including Bluetooth WiFi tethering Smartlink etc? And even better is there a start to finish guide on how to set all this up on a Skoda with an iPhone?
  5. What indications are you getting that it's overheating?
  6. Leave the a/c on and in auto mode. When you use the recirc mode it automatically turns on the a/c which will clear any condensation
  7. I was playing with the MySkoda app and discovered that with the latest version if you go to the manual section it takes you to a web site with an option to download the pdf! At last. So I now have a pdf manual downloaded.
  8. Today
  9. I was thinking along these lines the other day. If I bought another Superb now, what would be my essential changes based on what I have done to this one? I came up with - Fix anything broken/tatty, Interior and exterior LED bulbs, Aluminium pedals, MIB2.5 upgrade (if not already), Start/stop deactivation module, Branded puddle lights, Spare wheel and tool kit (if not already present), Decent floor mats, some coding - especially accelerator response, reversing camera (If not already), washer bottle funnel, USB lead to arm rest, wireless carplay adaptor. From there its then a slippery slope of more expensive upgrades which is the point I'm at now and currently resisting....
  10. Mine has that, plus the extra position for pulling the mirrors in. I wonder if the switch could perhaps only partly connect,so 12V appears but not the current capacity?
  11. Hi all For about a week or so the temperatures have dropped significantly (from 10-15 degrees C during the day down to negative values during the night). When I start my car for the first time in the day either in the morning or later I switch on the ignition, wait a few secs and then press the brake and start the engine and at that moment I get a warning such as ACC unavailable, manoeuvre braking unavailable and they disappear in 1-2 seconds and everything is working. The car is starting normally, the battery is an original VW 75Ah battery fitted brand new 2 years ago by an authorized dealer. My question is could this be a momentary drop in voltage and should I be worried since I have some trips lined up in the next couple of weeks?
  12. specturow started following Battery issue or?
  13. Try doing a heater flap reset... press and hold the A/C and face vent buttons at the same time for a few seconds and the lights on both with start flashing in turn and the flaps will go through a learning procedure to reset their baseline positions.
  14. Does your mirror adjustment switch have a position marked with a little heated mirror symbol? Easy to leave that switch on L or R if you've been adjusting them.
  15. Bet
    Bet posted a topic in Skoda Fabia Mk4 (2021 > )
    I've fluid runs down my glove box and dripping onto the mat, any ideas where it could be coming from? 2023 tsi
  16. Bet started following Bet
  17. Bet joined the community
  18. SW17 joined the community
  19. Fixed servicing I’m assuming going by the mileage data
  20. Hi folks, anyone got any ideas on this? I think my heated door mirrors were working last winter, assume so but can't honestly remember. Pretty sure I would have noticed if not. With the recent cold snap I've noticed they're not heating up, same both sides. I've had both doors apart to test, and in each case I'm getting 12V on the black/red output pin of the door module and earth continuity on the black/blue pin. Wires are continuous, and mirror elements read a useful number of Ohms, somewhere around 5-6 iirc which fits the 27W power consumption. Connecting the mirrors direct to a 12V battery they both work nicely. All the other mirror functions - motors, lights - work as normal. I found a Reset button in VCDS for the door electronics modules, so did that.. no change. Sadly, gone are the days of fuse>wire>switch>mirror, and now there's at least two computers involved(!) which is way above my pay grade, but it seems unlikely for both door modules to have packed in simultaneously (or at least within a very short space of time). For the time being I've wired the mirrors out to a 12V supply with fuse and switch, which works fine but means extra wires running around, but does this ring any bells with anyone?
  21. What would you caption the part you have photographed?
  22. Ahhh. I did wonder if it would be compatible if it was from a different car. But as long as the numbers match I suppose it should be fine. Cheers Still hoping to find an axle with haldex fitted for easier/cheaper fitting but thank you for the very useful info 👍
  23. x128 joined the community
  24. Is that a record of each and every service item carried out? Not just showing annual serviced carried out?. Was it on fixed oil and filter changed or flexible / variable serviced?
  25. Unfortunately I suspect you'll find pretty much every manufacturer has been taken over by the beancounters and the main priority of the manufacturer is now shareholder value, not product or even profit.
  26. Last winter, I noticed that the windscreen was not demisting so quickly as it used to. This car always impressed me by how quickly it would clear the windscreen, but now I had to have the heater on quite a high temperature and high flow (and turn off the flow to the footwell and to the face) to do any good at all. The inside of the car would also get quite humid, with condensation on the windows. Some time later I found that the heater worked much better if I put it onto the recirculation mode. I could hear the airflow increase, and the heat would also build up quicker, clearing the windscreen. However, the system always switches it off recirculation a few seconds after I switch it on for the first time in a journey. I have to press the button again to get it to come on again, but this time it stays on. It's as thought he car thinks I should not be using recirculation. There are no dashboard warnings though. Put it back to normal and the airflow sound would reduce again. I've just had a look at the pollen filter behind the glove box, in case that was blocking the flow. To me, it looks OK. No debris in there, but a few patches where the white cloth looks a bit darker. I gave it a vacuum just in case. I can try getting a new filter, but I think that's not the cause. I now think there's a blockage at the air intake, but have no idea where to look next. Is there another filter to check, elsewhere in the air system?
  27. I am also charging it every month and it works okay.
  28. Knuddi joined the community
  29. Joni5629 started following Coolant overflows
  30. I have problem with my 2015 octavia 2.0tdi 184hv. I can drive the car normally for how long ever I want, but when I floor it a couple of times, the coolant reservior is empty. So the car shoots the coolant from the overflow of the reservior when floored couple of times. Already done: changed reservior cap, changed main waterpump, changed thermostat, checked for combustion gasses in reservior with co2 test and the liquid didnt change color so no co2 there, changed the intercooler, bleeded the system. Tested the electric waterpumps and both seems to work. Car blows hot air on both sides. Ehen floored couple of times, dagbostics says the coolant temperature climbs to 105celsius but it comes down to 92celsius in like five to ten seconds. I did pressure test while it was cool and there was no leakage. Should I just change the HG or could it be radiator or gearbox thermostat or something?
  31. well, normally "5 years later..." means no reply, but in this case i can report that this fix of resoldering the dry solder joints was 100% effective - the car was passed from my wife to my son and he still uses it daily, so after five cold winters and approx 50k further miles the fault has not re-occurred at all 👍
  32. the same here about the battery. my octy vrs 12/2023 , 47100 km --- battery is very weak. i have ctek cs the best on market. charged 20x but now its not possible. EfB is ****ty battery . u need to buy AGM yuassa or exide is the best . maybe it is the problem with ECU. i dont know that . service dealers in croatia are not willing to check anything . they just say u have power . its fine. but its not when i have to charge every month
  33. It has a comprehensive service record . Just seems to be lacking a record of the first box service.
  34. If it works OK then that is all that matters. Were Spark Plugs changed each 40,000 miles or so? Brake fluid changed a couple of times? Check the Air Filter and pollen filter and see if clean / changed or needing done.
