- Constant creaking / rattling from the doors of my Kodiaq Mk2
Ridex Parts any Good?
Premium Ridex parts (as opposed to base range) are certainly good in so far as I have used them. I have 2 steel brake discs (zinc coated) and an airco condenser/dryer on my Mk3 Octavia vRS for some years now. Have not used any parts in their base range, so cannot comment on those. On the particular topic of zinc coated brake discs, Ridex ones were 40% price of the ECP ones at the time ....
Wheel spacers?
I did before lowering etc. Forge 11mm front and rear with longer bolts in one set. Standard wheels and suspension at the time of those photos.
Rust around fuel filler door
It is not possible to talk directly to the Skoda warranty department, only the extended warranty department who can't help. Your only port of call is customer services but even when you reach management level they have no control over warranty claims. I have plenty if emails from customer services but you will not get one from warranties. They only deal direct with the dealership who can confirm things to you by email. They win, it's wrong, but they win and now that the ombudsman is on their side they always will.
You can only go by what is stipulated in the body protection warranty regards what you are required to do, which is report the corrosion as soon as it is found (to a dealer in the network). Nothing changes the fact that your warranty is with Skoda. Skoda can contract out aspects of its business to third parties if it wishes. However, you don't have a decision until you have the decision in writing from Skoda. Email Skoda and get a response by email if necessary, don't phone. In regards to the Motor Ombudsman, my experience is that after a year, you get a response from an Ombudsman understudy type. You do get a decision at that stage, but if you want an actual ombudsman to look at it, I am at 3 years total currently and still waiting.
Skoda enyaq 2022 full electric won’t start after crash
Hi Can anybody help? I have a Skoda and enyaq 22 plate full Electric car was involved in accident repaired the car. I changed the fuse at the battery underneath the car had an electrician look at it but couldn’t start it. I changed the two Roofer bags. Seat bag got the seatbelt reconditioned. Only thing I haven’t changed is the Airbag module the electrician said that there’s no communication to get it started. I am quite stuck. Don’t know what to do. Can anyone help?
Jay787763 started following Skoda enyaq 2022 full electric won’t start after crash
Jay787763 joined the community
- Dashcams on Elroq
blackpioter joined the community
Odd loss of power / 1.0TSI (DLAA) 81kW / 90 000km
Update: Since I've been using E5 fuel no issues whatsoever. Thanks for advice everyone.
barn find felicia pickup.
Been a minute, sorry. I got some mild confidence and tried to weld that patch in, but the sill is just tissue paper, I can't get any weld on it without it blowing itself to death. I'm going to cut my losses and buy two complete outer sills and go mental with the angle grinder. I do wonder if I need to brace anything first though. That job being trashed I figured I'd get it off axle stands for a bit. So my neighbour and I started bleeding the brakes, that's when we found out both rear wheel cylinders were seized, yay. Better than that, the bleeder on the back left just went PING and sheered off. Yay. The BESTESTS thing was that when we got the first drum off we found the hub nut was LOOSE (face palm emoji) but anyway the mess inside was like: Only ONE broken spring, heh. We got it all wrestled off but had to drill out the bolts for the brake cylinder. That's just crap on the axle thingy, it's not actually knackered. The process of trying to free the pistons from the second cylinder broke it but also look at the STATE of these things: Soooo crunchy We popped to the local motor factors and ordered a cylinder to see if it would match up, and got new shoes and springs, we left the old ones sprung up as references: In an effort to cheer up, I wired in the second VIBE BLACKAIR T12 sub and fired up the stereo. When it was just one it was ok but a bit borderline, two however has the ability to get slightly uncomfortable which means there's enough bass it gives me more enthusiasm to keep chucking money into this PIT in the hope I can drive it one year.
New Battery or Something Else?
Quick update.... I purchased a Varta A7 (E39) Dynamic AGM battery and installed it. After a couple of mis-steps due to a flat key battery all seems well; all warning lights extinguished and car starts and runs fine. No need for recoding (hopefully) and best of all the alarm isn't sounding all the time... it's VERY loud! Thanks everyone for your help.
ChrisPeters joined the community
Handbrake button came off
Sorry Dog with a bone, The parts catalogues show: Period Handbrake lever Early Mk3 5E0711301B — plastic handle Early leather version → 17 Aug 2015 5E0711301C From 17 Aug 2015 → 5E0711301D Clearly issue with pre Aug 2015 handbrakes. Those that had issue, was your Octavia built pre August 2015. Can any one who had issue post Aug 2015 build post please, so that I can discount it. Mine was registered Jan 2015, and yes only done 58k miles. Very really parked on hill.
MK4 DSG shifter switch upgrade from the cheap plastic oem job
Hi Unless im mistaken, golf mk8 lever (image below) is totally different to mk4 vrs lever, so it wouldn’t fit.
2011 Superb VR6 Starts then dies, Fuel Issue??
105 or 90 what? Is that 105 or 90 bar? Both are more than enough to keep the car running. My car had a failing HP fuel pump once (around 2015?). Without that HP fuel pump I could still drive the car to the garage, with only the fuel pressure of the pump in the tank, around 6 bar.... If you still have 90 bar, the fuel pressure is not your problem.
Ridex I believe are autodoc own brand they purchase from other manufacturers. They are budget/cheap parts. Fine if its to get it through an MOT etc but personally would fit something better. Try https://www.partsinmotion.co.uk/ been using them for a few years and prices are generally a lot cheaper than ECP plus delivery so far has been within 48hrs. Have had a couple of problems due to delivery surcharge to my address but normally ok. Alasdair
Alasdair1 started following Ridex Parts any Good?
Nordik joined the community
willschrst joined the community
I've used a couple of Ridex parts on my Fabia, mainly smaller items, and honestly haven't had any problems so far. Fit was good and they've been working fine. For £40 compared with £100, I'd probably give them a try for non-critical parts. I wouldn't necessarily choose them for brakes or other safety-related stuff though.
Fenix2121 started following Ridex Parts any Good?
Wheel spacers?
Anyone running standard suspension with wheel spacers, looking to do mine 10/12mm but wondering what it looks like non sports/lowered
tombee started following Wheel spacers?
the truth about electric cars
Seems to be planning that hold things up alot. Perhaps a different approach needed ie fast track for some project as national priority circumventing local permissions or different parameters which are automatically accepted.
Strange clutch issue
Hy, I have exactly the same symptoms with my Skoda Fabia. Everything works perfectly, and from time to time, the clutch pedal becomes completely soft and doesn’t disengage at all. It’s very strange because you think you’ve disengaged the clutch, but in fact the gear remains engaged and you often end up stalling. And strangely, after one or two poppies on the pedal, everything goes back to normal for hours... Did you get the explanation about your issue? Thank you in advance.
Vulcanjibe started following Strange clutch issue
Vulcanjibe joined the community
Doing own service!
I’ve used Ridex parts from Autodoc a few times and honestly haven’t had any problems. Had a service kit from them on an older car and everything fitted fine and worked as it should. For a Kodiaq with 100k on it I’d probably go for Mann or Bosch for the filters, or Ridex.
Fenix2121 started following Doing own service!
Fenix2121 joined the community
I was thinking of Smokey and the Bandit. Never a truer thing in a song. The UK needs to get a move on with things.
benros joined the community
Brake pads wear indicator does fabia colour edition have brake pads wear indicator light on dash ?
As it is just an location location location thing and usage. Maybe more necessary seaside or where winter salting is more common. And if you own cars as keepers and not rent / lease them and hand back or trade in every 3 years. Then lack of use or low miles might mean more surface rust on discs when they are moved. A manual hand / parking brake can mean user to get some rust off discs than cars with e-brakes. PS, untill 2019 Skoda UK servicing still showed 'remove wheels' remove Drums'. Some inspection of drum brake cars were done without wheels off. Right they used inspection hols on rear drum plate. Not. So mBy cars never had the alloys off in 3 or more years that it was an effort to get them off. Many a sad tale at puncture times.
brunt joined the community
- Skoda UK Customer Support are useless!
The bought-from-new cars owned by me and my wife have included 6 VWs and 2 Skodas. All of these (and the other makes of vehicle we've owned) were all serviced by their manufacturer's main dealerships and - to the best of my knowledge - none of their brakes were ever stripped down, pins greased etc. Brake pad thickness and brake disc condition were checked and reported on, but this was only using a visual inspection and without the road-wheels being removed from the car. That doesn't mean that our cars' brakes were never stripped down, as I used to do this myself on my cars and on my wife's last VW (a Golf diesel estate), but this was primarily when I was replacing the pads to try to improve the brakes' performance rather than me feeling a pressing need to do this. Do you know which car manufacturers have included (or now include) a brake strip-down as part of their standard servicing? I expect a VW/Skoda main dealership would include brake strip-down/pin greasing as a supplementary task during a service if an owner insisted (despite the pads' thickness being adequate) but current labour charges would bump up the cost significantly.
Non Return Valve?
The alarm code could be a failed siren but I assume the alarm is controlled via the BCM which I believe also controls priming of fuel pump. Apart from that i dont think they are related in any other way unless they share an earth? Did the indicators flash but no alarm siren? Alasdair
Alasdair1 started following Non Return Valve?
Startup stumble/chugging when engine is already warm (Octavia VRS TFSI MK2)
Been using https://www.partsinmotion.co.uk There prices and delivery are pretty good apart from random things that incur a delivery surcharge as I am in Inverness. If its skoda genuine parts then probably dealer or there is https://www.skoda-parts.com/ as well as https://www.lllparts.co.uk/ who also have original manufacturer parts diagrams and you can narrow it down with VIN. Alasdair
