waze through bluetooth
I`ve attached pics of the unit and as you can see when you look at the second pic, the bluetooth audio is greyed out and press it as much as you like that doesn`t change. When paired with the car andI check the phone settings it`s set to play blutooth audio through the skoda pairing so I really am at a loss to undestand why this won`t work..
SteveF joined the community
Richmond Skoda Portsmouth (Brake fluid change)
@nbramwel Is that a place that is not VAT registered you use? Fluid & a very very low hourly rate, very low if there is VAT included and only £35.
Range Rover Velar D300 V6 to Superb L&K - Guidance, Advice and Opinions
@Coral-C Dundee has a Courtesy Transport Driver, or a Courtesy Car. Victoria Garage good for a stay over and maybe a Courtesy car.
Hmm, this may be the issue then as although the option is there to play bluetooth media the button is always "greyed" out?
That's another option. Maud looks excellent, but Dundee is probably easier for public transport if I need to leave the car with them for any length of time.
John Clark Skoda Dundee are considered by some including me much better for Customer services than they are in Aberdeen or Perth.
That's not a million miles away 😀 I'll check them out. Thanks, @Evolution13
@Coral-C Are you in a part of the Scottish Highlands too far from the excellent Victoria Garage Maud, Peterhead. (Skoda) Aberdeenshire? http://victoriagarage-maud.co.uk
Hi Arianne Just picking up on a sidebar comment in one of your posts... you mentioned that your dealership is "a smaller, family and privately owned franchise as I wanted to avoid the big car dealership groups like Arnold Clark or Lloyd Group". I'm also in Scotland (Highlands rather than the Borders) and have to suffer with a national dealership that is, shall we say, "not excellent". Can you share who your dealer is? Best wishes for Rosie 2 - not long to wait now until you have somewhere to put that USB stick 😉. I recently moved to a 2025 L&K 4x4 and the drive is perfect for me. Rosie will be a joy for your long-haul trans-Europe journeys; Superbs are magnificent on the motorway. I wasn't sure about the massage seats on the L&K, but after a 600-mile-in-a-day run, I wouldn't want to be without them now. And I enjoy the understated power on the rare occasions when you need it: sub-6 seconds to 60mph leaves the boy racers open-jawed at the lights.
MarkoD85 joined the community
I can totally understand why you want to do it. I'm a bit of a sucker for all the latest bells and whistles myself, and if there's a way of making the car do something that a higher-spec model does, I'm usually the first to start wondering how it can be done! 😄 Having looked at what would potentially be involved with the Mk4 though, I'm not sure I'd actually go ahead with this one. The thing is, what you've already got isn't really a "lesser" TPMS system in terms of what it's there to do. It uses the ABS/wheel-speed sensors to monitor for a loss of pressure and, if it detects one, it tells you about it. So the important bit — knowing you've got a tyre that's losing pressure — is already covered. To get the actual numbers on the screen, you're potentially looking at four direct TPMS sensors, a receiver and possibly another module/wiring, plus fitting, coding etc. And then, at some point down the line, you've got four little batteries in the wheels that are going to run out and need dealing with. All of that just to change the information from: "There's a problem with this tyre" to: "This tyre is currently at 2.1 bar." And I completely get why you'd want the second one! 😂 It's just that I'm not sure I'd want to spend potentially quite a bit of money and introduce extra hardware into an otherwise perfectly happy car purely to get that information. A decent digital pressure gauge will give you the actual figures whenever you want them, and you can check all four tyres in a couple of minutes before a long journey. If I'd been speccing the car from new and direct TPMS was an option, I'd definitely have ticked the box. But as a retrofit, I'd probably put this one in the "nice to have" column and keep it on the bucket list for the next car. Then when the next Superb comes along, you can tick the box for direct TPMS from the factory or make sure thee used car has it and enjoy watching all four pressures appear on the screen without having to retrofit half the car to make it happen! 😁 That's just my take on it though — if seeing those four numbers on the OEM screen every time you get in the car is going to make you happy, then I completely understand why you'd want to do it. Sometimes that's reason enough!
Kodiaq Seven seater and space saver spare wheel ?
I bought a new Kodiaq SE L 7 seater in February this year. Like you, I wanted a space saver wheel. I found the 2 best sources were Skoda Parts Direct and Caffyns Parts. Decided to go with Caffyns. Bought the space saver wheel and the foam kit on their ebay site because delivery was only £12 on eBay but more than £30 if I bought direct from Caffyns!! Fitted everything myself although some parts are a bit tricky. Guess you won’t have that problem with a factory order.
Onyir started following Kodiaq Seven seater and space saver spare wheel ?
Broken Key
Thanks for reply. Yes, that does look straight forward. But video doesn’t quite show how the old key fits into the new hinge though.
JD52 started following 2018 Octavia vRS 245 EA888.3 spark plugs
Broken Key
Does this help? - looks like you might only need the chromed hinge corner piece: Appreciate it's a different style, but if your key blade isn't broken it looks relatively straightforward to me. Gaz
Is there anyone who knows the exact number of tire pressure monitor sensor that i should buy?
Broken Key
Thanks for reply. It doesn’t seem the actual key is broken, it’s the metal casing the key goes into, where there is a crack in it, hence the key falling out. So not sure how you go replacing that, do you just get a new fob and the key slides in from the inside going outside somehow maybe?
- Octavia RS 65/100 WRC Edition
Scala SE L 2024 Infotainment unit updates
I can access the user settings, though at least once it has reverted back to guest from my own profile during an application update. One way to stop the updates is to set the user profile privacy to high which stops the esim from connecting except for the sos function. On the Karoq Facebook group someone with the same problem has received an email from skoda saying that they know it is a technical problem and will be fixed by an OTA update they are working on.......
Skoda UK Customer Support are useless!
I completely agree, we have experienced the extremely dangerous braking problem twice and now always turn it off. I raised several complaints with Skoda UK, including the above; the rest relate to the customer service at the branch I purchased from, and I have had generic responses to all. I imagine that a neutral answer avoids any potential liability, but it also avoids actually addressing the problem. At some point, some road users are going to get seriously injured (or worse) under an emergency braking scenario, and I very much doubt my "Customer Relations Manager" will be able to use generics at a formal inquest. Luckily, my local branch, Trancity, is very customer-focused and have just serviced the car and resolved a few problems. But they did say the braking scenarios are as expected from the position of the sensors. Like you, I would have hoped Skoda UK would be collating customer reports for researching and eventually releasing a software improvement or update? I would look closely at the reliability of the Honda; not so sure it is what it was in the pre-electric days? Another contender for me has been Toyota, 'dull but dependable", if they release a plug-in Corolla estate, I personally would seriously consider that instead. They also have the extended warranty periods for the car, 10 years and 15 on the hybrid system (if you service it annually with Toyota). Toyota GBToyota Warranty | Toyota Car Warranty | Toyota UKAt Toyota, we take great pride in the quality and reliability of our vehicles. Discover Toyota Relax - up to 10 years (100,000 miles) Toyota warranty.
It's so annoying that they don't give spare wheels on cars, where possible. Those foam kits are a waste of time. I have a Sportline TDI 4x4 with the 20" wheels, and I use the 19inch spare wheel that I'd bought for my previous Octavia VRS. It'd picked it up as a kit off of eBay, including a jack and wheel brace. Only bit I had to buy then was the genuine Skoda plastic locking screw that holds the wheel in position. You can lever the rear sets up after releasing them to get to the original foam insert that has some of the tools, inflator and foam kit. I stored that in the attic and laid the spare wheel in there, and the jack/tools in the centre wrapped in bubble wrap. Works fine for me. I'm sure you can get a genuine kit it'll include the proper foam insert that surrounds the wheel and holds the tool. Some links you might find useful: https://skodapartsdirect.co.uk/product-category/spare-wheel-and-toolkit/ https://shop.wingsskoda.co.uk/products/skoda-spare-wheel-kodiaq-2024 https://shop.parks.uk.com/products/skoda-spare-wheel-kodiaq
buaan started following Kodiaq Seven seater and space saver spare wheel ?
Inexplicable tyre deflation - no puncture, valve OK
Not on my Yeti, but I have a Fiat Ducato campervan with Michelin Agilis camper rated (CP) tyres. After a holiday journey of 100 miles at up to 65 mph, I discovered that one front tyre had only 25 PSI rather than the usual 60. Tried pumping up with a brand new 12 volt powered inflator, but after 10 minutes this only got to 35 PSI before noisily failing (overheated ?). Finished off with a bicycle pump which took forever but got to 60 PSI eventually. Next morning, back down to 25 PSI so out with the bicycle pump then off to the nearest tyre dealer. They found a small nail in the tread, I guess it only leaked when the pressure was higher than 25 PSI. Tyre removed, checked, repaired and balanced then on my way for just £25. I am amazed that the tyre took this punishment, reinforced sidewalls must have helped. I will probably replace it soon as it's coming up to 10 years old.
Thank you. The problem is not totally about OTA updates. The system itself is subject to non-OTA updates. These have to be carried out at the dealership. My system is still on the original update - 0278. Customers are not informed if an update is needed. It is only carried out if problems linked to it are reported. I had no problems until the car was out of warranty, therefore it is chargeable. As for the MyScala app, yes I have it but it won’t authorise me to access the user settings system. The dealer thinks this may be the problem why the OTAs aren’t updating
sebc joined the community
Broken Key
If your metal 'blade' in the key is broken, you should have it remade by any key specialist shop, is only the machining needed. The electronic part of the key is separated from it. I would advise against homemade attempts to "glue" this together, if your lucky you it will break in your pocket and you will lose the metal blade part, if you are unlucky it will snap when the key is in the door lock .. and you can guess how that saga would continue 😁
leolito started following Broken Key
Timcooper55 started following Broken Key
Broken Key
On my 2016 Superb Mk 111 2.0 the key has come detached. I noticed a crack in the casing. Do I have to get a replacement from a dealer, or is it something I can fix myself. I’ve done a quick google, where it seems to can get replacement fob cases, but can’t see how you would insert your original key. Fortunately I have a spare, but for peace of mind would like to have a spare again. Thank you.
1.4TSI - lambda 1 stuck rich
Fix was to replace both lambda sensors. After replacing lambda1 (pre cat, B1S1), it started to throw active codes for lambda2 (post cat, B1S2). After replacing both sensors the fault (codes or MIL) hasn't come back. My guess is that the car had a missfire problem and lambda sensors problem - both of which are long gone now.
MrAB joined the community
Update applications Kamiq
Yes, see https://www.skoda.co.uk/owners/over-the-air-update-restrictions
