Hello Sportline Estate
Skoda dealer will definitely be able to print you off the build sheet from Erwin. I used to have access but my account got revoked as they don’t allow private people access anymore. I did manage to download all the workshop manuals for superb if you need any. Won’t have your engine and gearbox but all the rest will be relevant.
That’s mad. I was speaking to Skoda HQ today. Trying to find out all the build specs for it. Not sure if the buckets are heated. Collect weds morning and can’t wait!
How to lock keys inside?
If the situation requires you not to take your electronic key, why would you take a tablet or smart phone with you?
Also. Fun fact. Your reg starting with K makes it likely it was a car of VAG management as it’s first owner.
Lowering Springs
How low are the springs? What’s your wheel specs for aftermarket. Looks what I’m after!
RogueFabia started following Lowering Springs
Crazy Fuel Consumption 1.6TDi Elegance 13plate
Hi I have the same problem here 40 mpg I’m expecting 60 mpg at least
kimo started following Crazy Fuel Consumption 1.6TDi Elegance 13plate
Every day’s a school day!!
I also see it makes sense, however it still came as a complete surprise. Bit like when I had a BMW 5 series and tried to reverse into a part of our drive, opened the door to lean out and look back and it slammed the brakes on. I’d been doing that trick for decades when it was needed, but not in the beemer! Will try that in Skippy when I get back from Morocco. 👍
I also upgraded from a Fabia although I that was a downgrade from a previous superb. Eibach pro kit is the go to for lowering. Have a search on this forum and there’s a table to choose the correct kit. Not done it to mine yet but it’s on the cards potentially. Lots of things you can do on a relatively small budget. Mostly mine has been fixing up issues plus some styling mods including all LED bulbs. Made my SE L into a sportline lookalike.
Binx1310 started following Hello Sportline Estate
caocongtien48 joined the community
Car Shudders Various Lights Come On Goes Into Limp Mode
UPDATE: 2 weeks on from the crankshaft sensor replacement and , touch wood, no sign of any issues. If things change, I will let you know. Thanks for all the advice and input, its much appreciated. Tony
I need Bolero Update :-)
@pab567 It looks like you’re the guy to help with possible CarPlay upgrades. here are photos of my hardware, software, and firmware packages. Is there an upgrade path for my 2016 Octavia Mk3? VIN <Removed>
Tondi007 started following I need Bolero Update :-)
Rogue Fabia - MK2 Fabia Monte Carlo
So I’m trading in my 2014 MK2 Skoda Fabia 1.2 TSi For a 2018 MK3 Superb Estate Sportline 1.5TSi 150 Fancied a bigger car from the fabia, didn’t want Octavia’s like most upgrade to, and always fancied an estate! I absolutely love the interior on it (unsure if my buckets are heated) And there’s about 5000 toys I’m going to need to get used to! Do plan some mods Aftermarket wheels Remap And workout best way to lower it. Honestly I can’t wait now Show me your estates 👌
RogueFabia started following Hello Sportline Estate
Tondi007 joined the community
Hello, looking forward to an Epiq journey!
Hello all. Have taken advantage of my employers salary sacrifice scheme via Octopus to order a new Skoda Epiq on a 3-year lease. It's a 55 Edition, in Black (only colour available unfortunately), due sometime in December. Currently have a 14 plate Mazda 6 estate which I really like, but Mrs X_CAB has never got on with. We don't need the volume anymore, but still need a reasonable boot space for allotment tip runs. Also, we are restricted on driveway space, so balancing length, and more importantly, width, against load space. Looking forward to learning about this new hitec vehicle. I hear it has built in DAB 😄
X_CAB started following Hello, looking forward to an Epiq journey!
Aluminium Front Subframe and Wishbones
Thank you definitely would appreciate all you learned doing this and thanks for the link I will take a look.
Sportline 85
Ditto - but you ordered a few weeks before me. What colour did you order? I think there is going to be at least a few weeks delay though due to supply issues. Not bothered though as hopefully by then the softwares experienced by many recent MY27 owners may have been resolved?
Happy to share knowledge and lessons learned. It’s amazing when you do two sides how slow and cumbersome the first side and how you do the second side so quickly and easily. BTW just saw these on a Facebook MQB Classified post: Whiteline front droplinks for sale
Octawia started following How to lock keys inside?
Ianhar started following DSG issues ?
DSG issues ?
On 18000 miles ish now and maybe a gearbox issue, had a few times when it seems to be unsure of what gear to be in, and on one occasion pulling out pf a junction, no drive at all, engine revs rise but no forward motion, then it started to pull away. Anyone else had issues ? Car will be in for a service soon and will mention it then, but without them experiencing it i doubt they will investigate anything.
Code out Lane assist on a 2026 se Edition
Thank you everybody, sorted now.
Official Briskoda Fabia II Monte Carlo Register
2011 Red Monte Carlo 1.6 cr tdi (105) Reg 23rd November 2011 New to me 3rd June 2026 Standard just now with options of Full Size Spare Wheel and Cruise Control Planned Team Heko Wind Deflectors, New badges, Amundsen, Lowering Springs, Rear Anti Roll Bar, Wheel Refurb and new Rubber. Only done 61k with full Skoda Service History. Few wee bits of paint to sort out but pretty clean and goes quite well.
macmacvrs started following Official Briskoda Fabia II Monte Carlo Register
Ah that makes sense. Had it in my head it was a safety thing. Alasdair
I did it on my 2025 Monte Carlo Edition with OBDELEVEN. It's one of the pre coded options in the app and you can select either start off or on or alternatively you can set it to remember the last setting, which is the one I chose. I then turned it off from the steering wheel and it remains off until I choose to change it.
atasoy34 joined the community
George10529 joined the community
Sportline 85
Also queued up for an 85 Sportline, from Marriott Ipswich. Ordered 7 August, build started week 40, but no news yet. Was originally quoted end November, so in line with your dates. Added a Maxx pack, Winter pack and Towbar.
I believe the feature is to prevent the wipers catching on the hood lip when it's open.
T3Bla joined the community
- Digital Speedometer Coding
