Button panel adding functions
Skoda Octavia 2019 MK 3.5
the truth about electric cars
Not the 5 kwh battery with 6 kw supply but the little sub 20 kg power supplies, only longer journeys, no problem, don't take up much space, make sure one has the tyre pressures pumped up but one is only adding 1% or so to the weight as most EVs are already in the 1.5T to 2T zone. Not like the days when my mini, ford escort etc weight less than half the current vehicle weights. Would only be on those odd months I do a 200 miles plus journey having learnt that public chargers are still nowhere near 99% reliable.
P200200 Particulate Trap Bank 1 Efficiency Below Threshold on 2.0TDI CUNA 184HP Scout.
Hi all, I'm getting intermittent P200200 fault codes and occasional CEL that resets with Torque or OBDEleven apps for a couple of regens. From what I can tell online, this indicates a EGR blockage/fault issue rather than DPF itself. VAG DPF app shows that measured soot climbs faster than calculated soot in the DPF - the measured often going negative after a proper DPF regen. Soot mass is <60% according to the app, so seems like DPF doesn't imminently need work. Car is at ~110k miles and no plans to change in the next couple of years - the sensible answer is to keep it as long as it's a reliable workhorse. What I'm pondering over is how much money to sink into resolution. New EGR valve/cooler? Cleaned EGR/cooler (s this a thing?) New EGR and new/cleaned DPF. I'm happy to spend money on what actually needs fixing, but I have trust issues with unnecessary fixes, and snake-oil "DPF cleaning" salesmen, and so on... Does anyone have any experience, thoughts or wisdom? I use a small local garage for general servicing, but not a specialist - so any recommendations near Nottingham are also welcome. BW, Jono
I can't believe you are suggesting the average person will carry that lot about... What a load of tosh
Robbroketheskoda joined the community
Having been let down by Gridserve twice last Sunday, chargers said payment verified, took my ten pound deposit then said not playing, very poor service. They are suppose, like all CSPs, to be 99% reliable but they clearly are not. Whwether it is Grid overload or Russian hacking or too much local load to take on another EV on that bank of chargers it is a mystery as to what happens when the DC charger shout not playing. 5 days later these £10 deposits are showing pending or processing. Crap. Should have gone to the Tesla chargers at Frankley, even at peak time they are only 66p per KWh, 34P at the 10 pm to 7:59 am period. Made several charging mistakes that day but at least I know the real limti of my Urban 40 Kwh R5 which proved to be just over 20 miles past 0% SoC being shown. Got going again thanks to my VTOMAN 2200W which supplied 8A on my granny charger ie just under 2 KW supply for about 20 minutes which, presumably with a bit of chemical recovery in the depleted battery got me the last half mile home no problem. Did not even bother to put in the VTOMAN 2200 slave battery which would give me a total of 3 KWh and as each weights less than 18 Kgs are easyish to carry. Their day job is saving money on downstairs larger electricity consuming devices ie TV, my computer setup but not the Sky, BT or router as they are low powered but good to be able to pop them in the boot, even the Mini's boot, and take that power out to where it is needed. Need power units which are atleast half as big again ie with more than 3 KW stable output and a 2 KWh battery capacity so over 4KWh in total. Hopefully not over 22 Kgs in weight plus more solar than the VTOMAN 2200W one which can only take 400W of solar. Expect there will be megadeals for the Black Friday and Cyber Monday sales. Wpould also like to add a portable ie on wheel but probably 50 Kgs or so home battery to add to my smaller one already have. The Aferiy PH062 looks a bit of kit... Should pay for itself in a few years and give me peace of mind if we actually get the blackouts we got close to this summer. Not too difficult to move to a new house. I could genuinely charge the EVs with gathered solar electricity with this and even at 3.7 KW or maybe more. 5.12kWh LiFePO4 battery with up to 6,000 charge cycles for long-lasting performance 6200W AC output power to support high-power home appliances and backup needs Up to 6500W PV input with built-in 120A MPPT solar charge controller for efficient solar charging Dual AC outputs with pure sine wave inverter for stable and reliable power supply Portable design with built-in handles and universal wheels for easy movement Smart BMS provides comprehensive protection for the battery and entire system Supports WiFi & GPRS connectivity with smart app control Wide PV input voltage range (60–500V DC) for flexible solar system integration Dust protection kit included, suitable for harsh outdoor environments RGB lights clearly indicate different operating modes Dimensions (H × W × D): 780 × 440 × 230mm; Net weight: 58.5kg
carxoil started following The Superb II & FL Picture thread
carxoil joined the community
IPG7 joined the community
Andyt1 joined the community
What a load of total guff IMHO, unless maybe doing some world travelling in a region that is not the UK. Scotland just happens to have 32 local authorities and many of these have no commitment to helping get to net zero with the upkeep of public ev chargers. £5 minimum charge here and i am at £6 after nearly 3 hours. Now 12 kWh of a charge. The other car must have unplugged and now i am getting 6 kW i expect.
fsec changed their profile photo
StephenC66 joined the community
Getting economic and logical to carry a power station and ones own solar panels perhaps. With the right battery ie one that can supply 3.7 kws, and granny cable doing 16A and maybe some foldout portable solar panels one can have an onboard backup in the boot. Also versions of onboard software coming out every few months and updated battery packs every 2 years the problem goes away.
Kamiq arrived at last! 2027 model...
I think they went a bit mad and stripped stuff out in the 24 model year facelift - our late 23 SEL has front parking sensors and I recall there was other stuff missing from the facelift version. I forget what now - did they come down a level in the digital dash? I was surprised the Kamiq SEL came with one as standard that was a hefty upgrade cost in Karoq SEL. So I guess they've gradually brought stuff back.
Which Octavia Scout would you choose?
To be fair, you’d be able to check the oil on any flat surface, be it the cargo hold of a 747 or the deck of an aircraft carrier.
That is not what you want to see is it, so further delays in getting a decent charge
Startup stumble/chugging when engine is already warm (Octavia VRS TFSI MK2)
I'm trying to troubleshoot a niggle with my 2006 Octavia VRS, that only happens when starting the car after it's already warm. I'll try get a decent video/audio of the symptoms as soon as I can, but wondered/hoped if anyone would recognise the problem from a brief description. Octavia VRS 2.0 TFSI / MK2 2006 / EA113 / BWA / Manual / 123k miles / Stage 1 remap. 2-3 second stumble/chugging sound when engine is started whilst already being warm/recently used. Sounds like the engine is either getting too much or not enough of something, before sorting itself out and settling. Normal cold starts are generally fine. Normal running/driving is fine and still pulls strongly. Symptoms first occurred in May 2026 - the first day of the really hot weather (I'd spent around four hours throughout the day driving mostly short journeys, some fairly "spirited" driving). No relevant error codes. Work already done in the last 12 months (some required, some preventative maintenance): cam belt and water pump, four new injectors, cam follower, PCV, intake carbon clean, spark plugs, coil packs, stage 1 remap and diverter valve (GFB DV+), new battery, EVAP valve checked and clear, vacuum system passed a smoke test. Other minor niggles: throttle lift-off/overrun feels a little rough/jerky sometimes; temp gauge sometimes drops to 70-80 on motorway journeys. My local garage have had the car in twice for diagnostics and couldn't identify the problem. Had it earlier this week, after I asked them to check for the thermostat sticking/failing, to double-check the EVAP valve, and to check that the GFB DV+ diverter valve wasn't sticking (all suggestions from forum research, and ChatGPT/Gemini), but the garage couldn't find anything obviously wrong. I was very tempted to get them to replace the thermostat and EVAP/N80 valve anyway, since they're fairly inexpensive (parts and labour), but they advised that unless I want a full engine rebuild, it's probably best to stop chasing little niggles if the car generally runs fine. A separate VW/Skoda/Audi specialist also had the car for a week (a couple of months ago, to replace the fuel injectors and perform a carbon clean/walnut blast) and couldn't replicate the chugging sound either. Presumably because they didn't restart the car after it was already warm. They also mentioned that the intake manifold motor/actuator was sticking a bit, so they took it out, cleaned it up, lubricated, etc and put it back in (doing whatever reset/coding was necessary too), and said to keep an eye on any related error codes popping back up. So far, nothing. Does this startup chugging sound familiar to anyone? I'm trying to not just throw parts at it and hope for the best, as I've spent enough already. I'd just like to get these last few niggles sorted out, then I can relax a bit - until the next time, haha! Thanks in advance. I'm very much not a mechanic - just stuff I've read online. Any help is greatly appreciated.
jb_0151 joined the community
SinisterKid97 joined the community
PS. So 45 minutes & it had charged 2.2 kWh. The other car plugged in is a 28 kW 2020 Hyundai Ionic and with 22 kW charger is only giving us 3 kW each not even 6 kW each. So likely in 5 hours plugged in max I get is 15 kW at 55 pence a kWh. I will be heading 4 miles to the Farm Shop to get a charge in the DC @ 55 pence a kWh.
PHEV radiator fan starts after engine shutdown
You have two. One for ICE and second for HV. HV one is connected to AC circuit via heat exchanger and dumping heat there.
Girvan harbour DC charger only 1 in town and 5 weeks I have been reporting out of service. Today I was there early before some teacher would put on AC charger all day even though max 5 hours. Car get charged and stays plugged in locked in. Not even moved at lunch time. So one car charging on B. Post A fails to start. I try 3 times. Then 3 times with electroverse. Then call CPS. Poor mobile reception area. Get the usual script. A fault with your card. I used it yesterday. Close windows and lock doors. I tell him that makes no difference and never ever has. He tells me charger working and he can not start remotely. I told him he can he is on a mobile to me and he is in Broughty Ferry and the SIM in the charger gets a signal. Phone goes dead. Charger starts. I try calling back as I want to report the big charger. No signal. Then he calls me. I give him charger number and he says he will check. He says out if service 4 weeks. I said 6 and 5 since I first reported. Line went dead. Got a call to do satisfaction survey just now.
SRIXONZX4 joined the community
Hi! Yes it was normal to behave like this, the ECU won't turn on the fan every single occasion to save battery but if connected to charger will use this opportunity to cool down. I understood there are complex cooling mechanisms which involve different conditions like HV battery level, outside temperature, etc. There are three cooling circuits if I am not wrong, one for battery, one for ICE and a third one (smaller radiator in front of the big one) for hybrid system. Once I also noticed the cooling agent was circulating while the car was stopped for a while. No issues since then, except an intermittent coolant sensor wire that ocasionally started the cooling fan but this issue was different from my first observation.
Rear left brake dust shield escaped, killed abs sensor?
I would replace sensor as there not that expensive and chances are if you have to change rear bearing the old sensor will be seized in and get ruined trying to remove. Cant see a crack. Soak sensor in penetrating oil for a day or two before trying to remove. Did the splash guard hit the sensor or cable or was it just wrapped round disc. It may have cracked sensor Alasdair
Alasdair1 started following Rear left brake dust shield escaped, killed abs sensor?
Fareed joined the community
Sorry to post again, I've just looked at the images I took again, and I a) can see what I believe is some damage to the ring in this image but more concerning b) Is that a crack between the metalwork there or is it just the way I took the photo? Sorry to be a pain, thanks again.
ATE Ceramic Front Brake Pads - Skoda and Other VAG
@GREEBO_22 Thanks very much for that; I didn’t know that was an option and I’m sure many others didn’t either. 🙏 This was user error at the time and I’ve now sourced the correct pads at a cheaper price than Autodoc from Spareto in Estonia. They have very good feedback on Trustpilot. We’ll see how that turns out.
Hi all, Wondering if any of you could offer any advice? My partner on her return home from a night shift heard a noise and then was greeted by the traction control and abs lights on the dashboard. When I went out and removed the wheel to take a look, the brake dust shield (or what was left of it) had wrapped itself in around the disc. I've removed this and tried to clear the fault but it returns after a short while so I believe the ABS sensor is at fault (or at least I hope, because I guess the only other thing could be the reluctor ring being damaged), I've checked the voltage at the connector and it stays at battery voltage no matter how much I wiggle on the loom so I think the loom is okay. I went out and logged the wheel speeds reported and the rear left wheel dipped or deviated every so often from the other three wheels, but not rhythmically which makes me believe the reluctor is probably okay? (Please see attached graph image). The green lines are for the rear left ABS sensor. If anyone could offer any advice, or let me know if my thinking is sound I'd really appreciate it. Thanks so much for your time.
-mike- started following Rear left brake dust shield escaped, killed abs sensor?
- Yesterday
Amundsen MiB1 Firmware Update process
Hi good people, Anyone here kind enough to share a working download link for the MSTD_EU_SK_P6230.zip firmware file? Thanks for any respone :)
iblis started following Amundsen MiB1 Firmware Update process
I managed to create a new Skoda ID and My Skoda app account (for the buyer) and indeed it let me activate again the 3 Month Free subscriptions for both Care Connect and Infotainment Online. (good to know, if you really need for a period of time the functions, basically they are free if you create a new account, activating the 3 months trial). Secondly, you were right! I managed to go back to initial charging times with the subscription by de-activating the ‘reduced charging current’ in the app. Thank you very much for the tip!
- Columbus Map Update 2026-2027 (MIB2 HIGH)
Skoda tow bar for vRS Combo
I can’t help with third party sorry, it’s not something we’ve ever gotten involved with aside from removing them due to warranty issues
exterior lighting showing on info screen
Curious feature this - can't find even a mention online - for Skoda to remove it on the latest vehicles does seem rather petty, can't imagine it saves anything.....? AI even gives this dismissal: "The Škoda infotainment system does not provide a real-time, active 3D visualization showing your bulbs physically illuminating."
- It's arrived!
