  2. DogBook replied to BlueDun's topic in Skoda Yeti
    3rd agree, should be attached to the exhaust as they look like dampers to me. Also there is no tray, they go into a cross member between the subframe. Thats without looking at a parts list.
  3. Hmm, with the dpf deleted wouldnt the car smoke a lot and blow big black clouds of exhaust fumes out the back, with that kind of oil consumption. Personally wouldnt want to be driving behind your car...the exhaust fumes would smell really terrible and couldnt see **** for a while🤣. A working dpf really makes a difference, the diesel exhaust stays clean and doesnt smell anything like the old diesels did. Also in my country its illegal to delete dpf, if you get caught, the fines you get from doing that are counted in thousands of euros.
  4. Great stuff. That is pretty damn new and by the sounds of it has an impressive spec list... I'm sure you'll enjoy your ownership.. Nicely done.
  5. I put all the details in lightning adaptations in Leuchte23SL HLC10, Leuchte24SL HRA65 and Leuchte27NSL RC6. First unlocking the car successfull😊 animation worked as it should. Closing the same. Then when I unlocked the car again went back to static. Locking still OK-animation works OK. I'm not sure if there is other module than Lightning Adaptations where animation of tailgate lights is controlled.. I will try, thanks Cairus. This backup has a lot of useful information 👌🙏 Obviously changes made with ignition on, engine off, bonet opened. After coding scanned for errors and cleared few archived ones, reset lights in car menu-factory reset-lights, infotainment reset and car left for 20 minutes with key away from it...
  6. Today
  7. Hello. I need help. I would like to update my car, but i got NO idea how or where to get the software. I am quite a newbie in this lol Number is 5Q0035840A Hardware: H24 Software: 0245 Thank you!
  8. vallhala joined the community
  9. Won't adding front parking sensors also require the PDC module to be changed from a 4 channel one to an 8 channel one?
  10. Hi. I am from Turkey. I want to make an expert install the navigation. I checked update portal to be sure that whether there is map update or not. I entered vin number but it showed that there is no new map data. Is there anybody to explain the problem.
  11. On my early Mk4 (2020) there are options to change colour and brightness of the ambient lighting; I assume similar on the newer FL models so maybe check for the brightness settings.
  12. DanHot joined the community
  13. How do i activate my ambient lighting? I can get the spectrum to show up and I can change the screen background but there are no lights on the door strips or across the dashboard. I have the free month trial of Ambient Lighting Additional Colours and Ambient Lighting Additional Features installed from the My Skoda app and activated, but nothing lights up. Can I get rid of or change the red ring around the 2 circular dashboard dials?
  14. YMe started following 2026 Sportline MHEV
  15. 2024 Skoda Superb 1.5 Tsi Se Dsg Estate
  16. skomaz replied to BlueDun's topic in Skoda Yeti
    Agreed... They are the exhaust hangers (or in this case they are 'inverted' hangers
  17. Thanks.. the only real issue I had was getting the rubber boot back over my repair, but I did it and the boot operates as it should..How long for who knows...
  18. Correct.
  19. MikeTheThinker started following Wheel Caps
  20. Hmmm.....I'm sure I get a dash light showing a car skidding.......? I'll check tomorrow......
  21. paul1973 joined the community
  22. rabbituk replied to BlueDun's topic in Skoda Yeti
    Unless I'm missing something, aren't they supports for the exhaust rather than pipes?
  23. rabbituk started following What are they?
  24. I have the following wheel caps on my MY20 Mk3 Octavia. The chrome finish is prone to corroding and I am already on a second set. At £18 each, £72 for the set is a bit steep however, I will be getting my Geminis refurbished imminently and begrudge putting the old caps back on in their current state. Wings SKODASKODA Decorative centrepiece of the wheel SKODAEven your SKODA deserves to be elegant at all times. In case you ever loose it, SKODA Genuine Accessories offers you a decorative wheel centrepiece with new company badge, which is perfectly identicalThe following are the “latest style” wheel caps, available at a far more reasonable £20 a set. The MY20 Mk3 Octavia isn’t listed as a compatible vehicle however. Has anybody fitted these to a Mk3 Octavia or able to advise on how the finish holds up? I’ll probably give Wings a call to clarify the compatibility and report back. Wings SKODASKODA Decorative Wheel Caps - Latest StyleBy using the wide range of Škoda Genuine Accessories you can draw individual style of your car to perfection. Fit the already attractive light alloy wheels of your car with wheel center caps. Plastic
  25. CookieMonster87 started following Wheel Caps
  26. All sounds perfectly fine. The radio will go into standby when you take the key out. Yes, you can still turn it back on as it's on a permanent live, but while it's off, it's drawing next to nothing. I did the same retrofit to my mum's (now mine) Fabia II Combi in 2014, 12 years later, both the car and the RNS-315 have been fine with no flat battery issues. However, that said I finally removed it about two weeks ago and replaced it with an RCD 360. As map support for the RNS-315 ended years ago, I wanted more functional sat-nav in the car, so the CarPlay support of the 360 - and its factory look - has worked well. I just need someone with VCDS to hemp me code out the reversing camera setting on it.
  27. Hi all, Looking at purchasing a 2010 Superb 2.0l SE at 160,000miles. Engine history looks confidence inspiring but it has a few electrical issues that are either a common fix, or a big deal, and I'm trying to work out if its worth taking the project on. Drivers (right hand) door only opens using key manually in lock. All other central locking works ok. Rear o/s door does not open from in or out (deadlocked) Both front windows and mirrors temperamental. Looks like the cables through the drivers door have a had small solder/fix at some point. Is this likely a simple DIY job with a new wiring harness, or a quick fix for an auto electrician, or might something larger be at play here? ordering a full loom? I have read the many similar threads on here, but its a bit of mission trying to decipher them all, so any advice much appreciated.
  28. Hi all, Looking at purchasing a 2010 Superb 2.0l SE at 160,000miles. Engine history looks confidence inspiring but it has a few electrical issues that are either a common fix, or a big deal, and I'm trying to work out if its worth taking the project on. Drivers (right hand) door only opens using key manually in lock. All other central locking works ok. Rear o/s door does not open from in or out (deadlocked) Both front windows and mirrors temperamental. Looks like the cables through the drivers door have a had small solder/fix at some point. Is this likely a simple DIY job with a new wiring harness, or a quick fix for an auto electrician, or might something larger be at play here? ordering a full loom? I have read the many similar threads on here, but its a bit of mission trying to decipher them all, so any advice much appreciated.
  29. Hello, i recently purchased a RNS 315 with DAB and Bluetooth for a decent price to upgrade from the standard SWING radio that came with my 2011 fabia elegance. I have read about the CANBUS issues and how incompatibility would lead to a power draw issue that could lead to a flat battery, I scanned the CANBUS using VCDS and my version is 6N0 909 901 which i think is the older part and has issues with the RNS 315. When i install the RNS 315 it does seem to turn off when i take the key out of ignition, or atleast the screen turns off as i can still turn it on after using the power button, the MAXI-DOT screen does seem to recognise is as i can access navigation and phonebook tabs, the Bluetooth connection to my phone also turns off when the ignition key is taken out. I am not sure however if i can keep it installed as i fear a flat battery happening from a power draw problem as the radio does not recognise the car being off. I have purchased a "1.6- 2.0 CANBUS quadlock emulator" to hopefully test it out and prevent it from causing a flat battery hopefully. Has anyone had experience in this subject and can offer any information or help it would be appreciated.
  30. dashupgrade joined the community
  31. OldMahogany joined the community
  32. Amundsen maps need to be on an SD card that had the correct ID so it is (or looks like) a genuine Skoda card (or it appears you can hack the Amundsen to accept maps any card) - I use a 32GB genuine card I got off eBay. Amundsen music can be on any SD card - I use a 256GB SD card.
