Hi from a sort of newbie!
I am thinking 1.5 but seem to do lots of short drives at the minute. Some suggest the 1.0 as a better option. I will looking at an estate over the weekend - i need space for the dog!
Kodiaq steering wheel vibration
Mine is january 2025. I am waiting for next week inspection.
Jaguar, will it survive?
Is it Motorway or Highway / Freeway as they are talking US EPA ESTIMATE figures, so if it is tested. Has it not been tested for the EPA results? with no emissions and no difference of a US or Imperial gallon. Highway / Freeway Speeds. Estimated to achieve 400 miles under EPA test and 450 under WLTP test. Well the World Wide Harmonised Light Vehicle testing matters not one bit in the majority of the world. It is designed to allow European vehicles to have fictional test results. Simple will be to run the Jag, Rolls Royce , BMW, Mercedes, Lucid, Tesla etc in convoy. So a Jag 01 & a 118 kW/h battery. getting 400 miles. = 3.4 miles to the kWh. *Mercedes EQS Saloon battery 122 kW/h usable.*
Matt's 2017 FL Scout
Yeah, figured it wasn't a simple job 😅. No garage and scandinavian weather tells me this is a job for the summer season, probably doing this next year!
kilos26 started following My 2021 RS in final form
Whats your production date? I have much less vibrations after both dcc and top strut mounts change. But my car still feels more pathholes than normal i think - it could be ball joint that will be changed
MikeTheThinker started following Hi from a sort of newbie!
Auto Start-Stop not functioning
My less than a year old battery (and car) would makes a very big meal of trying to reach 85% SOC (don't even mention 100%), you can see below that it took 7.5hrs (smart charging) to get a tiny increases in SOC by 2% and a usable battery charge increase of 1AH, the battery energy counter shows a increase of a average of 2.8A over 7.5hrs, 0.37A per hour. My M.meter, in series with the charger showed a charging rate of < 0.2A for the majority of the 7.5 hr charging period. Also, later, on a 25 minute non stop run under varying driving conditions, the DVM showed that the charging voltage never went higher than 13.4V even on overrun and spent most of its time charging at 12.8V. Maybe a "smarter" smart charger than mine would get the SOC up to 100% eventually, if so, I'd like to see it confirmed by someone with VCDS. MAS16744-IDE01836 12-volt battery-Battery current -8.825 A MAS16744-IDE01839 12-volt battery-Battery charge status 75 % MAS16744-IDE01841 12-volt battery-Battery internal resistance 7.4 mOhm MAS16744-IDE01842 12-volt battery-Usable battery charge 26 Ah MAS16744-MAS06086 12-volt battery-Total re-charge 592.4 Ah MAS16744-MAS06087 12-volt battery-Entire energy throughput 598.1 Ah MAS16745-IDE01843 Quiescent current management-Battery voltage at rest 12.5 V After a further 7.5 hrs charging at 12.7, occasionally 13.4V. Charger is a Ultimate Speed ULGD 5.0 C1, (a 5.0A charger) MAS16744-IDE01836 12-volt battery-Battery current -6.729 A MAS16744-IDE01839 12-volt battery-Battery charge status 77 % MAS16744-IDE01841 12-volt battery-Battery internal resistance 7.4 mOhm MAS16744-IDE01842 12-volt battery-Usable battery charge 27 Ah MAS16744-MAS06086 12-volt battery-Total re-charge 594.3 Ah MAS16744-MAS06087 12-volt battery-Entire energy throughput 599.0 Ah MAS16745-IDE01843 Quiescent current management-Battery voltage at rest 12.5 V
Rear washer and heated rear window
Re the clogged rear wash. Lift up the plastic cover on end of the wiper arm and remove the plastic spray head from the top of rear wash discharge tube; it’s on tight but it will come off. Get a 16cm (6in) length of thin welding rod and push this gently down the tube til you reach the bottom and gently twist it whilst moving it up and down. That should clear the crystallised screen wash which is clogging the outlet. Leave the spray head off and engage the wash cycle and hopefully you should have a 2m jet of washer fluid flying out of the tube! If not, repeat the cleaning process. Also, I suggest you put the detached head in a solution of kettle descaler (citric acid) to descale the jets before you refit it to the discharge tube.
Octaviaman19 joined the community
I like the way Jaguar has quoted an alleged real-world motorway style mileage range figure, rather than just the nonsense fairyland numbers EVs often give.
I did ask for clarification on where they inserted their nozzle! I also asked if their warranty dept could ring me the next day.
mihaitam joined the community
- Yesterday
the truth about electric cars
Charger cables have been stolen for a while and as the price of copper goes up, and faster charges introduced, they need larger cables which become more attractive to thieves. It's a vicious circle really.
Thanks, so that's why Ofgem are posting those messages. I looked on some of the news channels and there was nothing there about it. So it was not scaremonging but there could be problems on the horizon. Maybe they worried because it has been really cold the last couple of days and people are turning the heating on?
World changing rapidly and things the UK had presumed it could rely on ie regular electricity from France's 50 odd nuclear power stations look more fragile now with low river levels providing insufficient cooling water and it is the same over much of Europe. Many EV owners from UK to New Zealand, South America and much of Asia have learnt better to trust one's own power generation at a country and personal level. The hundreds of millions who now gave their own solar panels, most on a small scale of a few panels andmaybe car batteries are learning to survive without power generation from coal, gas and oil. If we many multiple and long backups it will be interesting to see if those of us witb batteries and panels get left alone to use the resources we have inveztdx in over the past years. We have seen bad aspects of society with thousands of public charger cables cut. Some of use could go a week without mains power. Our cars can act as big support batteries as well as our home batteries. These messages of government warning of potential energy and food shortages gave been kicking around for a few weeks and The Survivalist cult gave been round for decades. I have been following it since my teenage times. Only one of our 3 EVs has V2L but I am expecting that when the other 2 are changed V2L is a must have.
Karoq 2021 front assist emergency braking
Greetings from Singapore. I am looking at getting a five year old Karoq in Singapore and have been reading horror stories elsewhere about the Front Assist making dangerous phantom emergency braking in other forums and chatgpt. However, I can’t seem to find any reports on this forum. How have your experience been with this regulation tech in your Karoq, any advice would be greatly appreciated. I had a terrible experience driving a rental Subaru in Japan with this kind of braking and I hope to find a way to reduce or prevent another one, although it is a good way of using tech to increase safety. Thanks Mike
mikeng started following Karoq 2021 front assist emergency braking
How odd and weird that they have only just suddenly started posting this then, as we head into winter, just saying.
- Exhaust warning light
What’s the error on OBD11? Driving at high revs heats up the exhaust and helps cause a passive regen (burning off the soot) but if that’s not the key issue then it’s not the solution to the problem. You could have a sensor breaking down which is sometimes causing an implausible signal - driving at high revs does nothing for that.
RufusOost joined the community
Bottom of rear bumper popped out (fixed)
I couldn't find any suitable tools to use the same approach as OP, so after work today I removed the rear bumper completely, reconnected the valance / under tray with the bumper off the car and reassembled. Probably took 30 to 45 minutes in total, and was quite straight forward. I took the valance / under tray off in the first place to allow access to replace a faulty parking sensor, but doing it that way was a complete pain. If I ever have to replace a another sensor I will absolutely just remove the bumper from the outset. As an aside, my local Skoda dealership wanted 2 or 3 hundred quid just to investigate the parking sensor issue I had, and another independent garage I went to refused to change the faulty sensor for me as their scan for faults didn't show an issue with the parking distance control system, even though I was convinced one sensor in particular was broken. I bought a new sensor from eBay for 35 quid and changed it myself, and all is now working perfectly. Just glad I pushed through my apprehension and did it myself for minimal cost and a whole load of satisfaction 👍🏻
Any petrol model Octavia would be better than a second hand out of warranty PHEV.
Hortiguy started following Hi from a sort of newbie!
'Energy regulator posts advice on social media shocker' Reaaaad awrabahhhhht it.
Cinch engineer visited as promised. Couldn't find anything out of spec with either the battery or alternator. Although didn't put a charger on to boost the storage. Other than visiting a main dealer not much else I can do. But prior to that I've a couple of lengthy runs (100miles each way) so will have a see if that makes a difference when compared to the short ones I've being doing.
The national grid does not look to be very robust; Ofgem have started to post the following advice on social media.
I need Bolero Update :-)
@Adenauer unfortunately this is NOT possible, you have to replace infotainment reader to either full version of Bolero or Amundsen. Pls let me know if you want me to prepare the offer. @Keew62 I sent you in PM link to download MST2_EU_SK_ZR_P0369T
- EPC Light On During Drive Home From Purchase Of Car
Hi @pab567 Kevin from Denmark here. I just bought a Skoda Octavia 3 combo 5E5 and I was woundering if there are any updates to my unit. I am running bolero. Part number: 5Q0035840B Hardware: H30 Software: 0353 Media Codec: 3101.0.0.9 I believe there might be an update with the file name MST2_EU_SK_ZR_P0367T (according to gpt) I’m am crossing my fingers. Best regards!
Keew62 started following I need Bolero Update :-)
I think at this point I'd be concerned where they put it, rather than presume it being a case of administrative ineptitude 🤔
