Last nights petrol versus electric documentary
I happen to live in a terraced house, with a garden that in theory I could dig out and park a car but it doesn't end there, this area is over-run with students and rentals, hence the reason for 'no guaranteed parking place' and for people undertaking higher education in our Uni they do not appear to have many grey cells when it comes to car parking, the chance of being blocked in or out is remarkably high. To go electric would also mean moving house and area, I'm not rich enough
There's also a new twist (to me, anyway) in that the Scrotery has taken to chopping off and departing with the flexible charging cables used to plug in the vehicle. Perhaps they think it's less hazardous than robbing railway signal and power cables?
Exhaust Backbox
MikeTheThinker started following Last nights petrol versus electric documentary
Exhaust Backbox
- No crank no start
Alasdair1 started following No crank no start
Windows
That's because they probably wanted you to take the car in and pay them to investigate the fault! I've had the same issue but with using the global closing rather than opening. It happened a couple of times during the hot spells when I was trying to close the windows in the evening having left them open during the day. In my case it was one of the rear windows and a quick use of the reset sequence sorted it!
Very little energy is used in traffic jams in an BEV. Best try driving one. I do and know, regularly through Glasgow it can be 40 minutes or so covering 5 miles. & you can switch the car off as you might in an ICE vehicle. Even in the coldest of weather i doubt you will keep everything running, and heating from 0*oC outside to 16*oC inside is not using much energy. not like it is a 2kW fan heater. I have my windows open a bit, wind deflectors fitted, stops steaming up. Heated seats have very little affect on the efficiency / range of a BEV. I have mine on for a few minutes at the most if the car is not pre-heated. My arse would be on fire even at the low setting. Yes you get power cuts, weather, road closure diversions. (A 60 mile one on Skye just now) Snow gates closed etc etc. Filling stations without power as well. No card usage being a use, people without cash. Public Charging might not be cheap. The last trip i did cost £3.50 for 160 miles charged at home, then the next 200 miles was £27. That was not Rapid or Ultra Rapid charging. Doing Rapid or Ultra Rapid Charging for the 360 miles could have cost anything from £60 - £92 depending on Location / Charger providers. Business / Commercial drivers getting BIK and maybe charging paid for & even if no Home / Work charging are in a whole different position from a Private Driver with no Home or Work Charging.
Evolution13 started following Last nights petrol versus electric documentary
Glove box lock/latch replacement
Hi guys - I'd really appreciate some help on this please Main glovebox - the one on the passenger side. A while back the bit that you press in the open the glovebox 'exploded'. There is an inner part and then the actuator itself which has the button, a spring and when pressed in pushes the sideways spring to open the glovebox. This is the bit which exploded, the spring disappeared and the assembly looks like it is glued to the inner part. I've bought a replacement assembly to replace it but have no idea how to remove the rest of the existing one or to fit the new one. It doesn't appear to just pull out. I've attached a photo Any help or guidance very much appreciated. Thanks
VictorMeldrew started following Glove box lock/latch replacement
Windows
How easy was that. Problem solved. Many Thanks. Wonder why the Skoda dealer never mentioned the reset??????
Photography Thread
Stone Cross windmill looking rather splendid in this afternoon's Sun: And on the way back I counted 67 Coot and two Great Crested Grebe on Shinewater Lake: Oh and not forgetting these two: Didn't expect to see them, otherwise I'd have taken some food as they came over to me, so seemed interested. Gaz
Firstly why were the only two comparisons made between top of the range supercars, Mercs, it went to great lengths waving the 'go electric' banner but never touched on the real-world issues that are raising doubt about electrics [1] the everyday charging, I imagine the majority of drivers reside in terraced houses or possibly in flats, not all having a garden, being confined to street parking, not necessarily in exactly the same location each time means for them the petrol car wins hands down for convenience [2] I have never seen a program that reveals how range is effected according to weather conditions, cold, wet, dark etc, wipers, heating, air-con, lights, lets throw in heated seats, all tests I have seen are in perfect daylight conditions. Tell you what, lets add a motorway traffic jam where all the above are operational but no distance is being achieved, could be for hours ! [3] Its rare but not unknown to experience power cuts, stormy weather, fallen trees, over demand as we are being pushed into an all electric future
johnnie47 started following Last nights petrol versus electric documentary
Amazed Skoda has become so BAD..
I gave mine a tankfull of Tesco Momentum a little while ago and honestly I didn't notice any difference, either in performance or fuel economy!
Wheel refurb colour change
didn't think about grey even harder to choose now lol.
aboenaam joined the community
I seem to like grey, ie gun metal grey, it tends to suit many body colours. My car is Deep Sea Blue Pearlescent - which means that it looks black most of the time, and its winter wheels are gun metal grey nowadays.
Are some folks using super-unleaded petrol? I put a tank of the Costco stuff in ours and I honestly think it went a bit mental - the throttle response seemed so much sharper. I switched back to ordinary fuel and it took a while to calm down again. I can't say I noticed (or remember) gear shift points changing though.
Hey everyone I need to refurb my alloys, but I don't know if should stay Black or change to Silver? any feedback is helpful thank you.
Exhaust Backbox
Cool I have standard diffuser so sportline or l&k would be an upgrade for me! It would have to be dechromed of course! @tombee and myself can fight it out who gets which one and perhaps we can go half’s on postage!
Superb Matrix Headlight
Hi guys! Quick question. I have a 2020 Matrix headlight and the numbers are 3V1941015D 3V1941016D. Sadly in an incident both are cracked and i want to buy used one. Hardly i found both and it was made in 2024 but the letters are not the same. (3V1941015E, 3V1941016E) Is it plug and play if i buy the 2024 or do i need to code something? Thank you!
Rubaj started following Superb Matrix Headlight
Exhaust Backbox
I can't see any difference between the L&K and Sportline - are there differences you expect to see and I can go looking for them? I just thought it was just down to accents and colours (i.e. black pack on Sportline, Chrome on L&K). Certainly the towbar cut out is just a hole in the area you wave your foot for virtual pedal. Literally have to lay on the floor to see it and wouldn't be able to tell otherwise.
MUSAB@1990 joined the community
200ps Diesel vs 190ps Petrol - Superb mk3 facelift post 2021
Hi, My googling suggests the 190ps EA888 is very different internally and externally from the other versions, being focused on efficiency rather than power. Are all post 2021 using the 7 speed DSG?
Traditionally, diesels are for higher miles but the gearing on the DQ381 will be decent for longer journeys. If you were on the 7-speed DQ381 then no change. If you were on the DQ250 6 speed, it was required to be serviced every 40k miles and the 7 speed is officially every 80k miles but most stick to the 40k service period. The 190bhp I presume is an EA888 engine which is a decent block. Waterpump issues are a known fault but there are some decent replacements. Not sure on the the remap potential but the turbo only looks to peak around 230/240bhp.
Advice on/Experience with engine replacement 2.0 TDi
Hi defsix. (Real capital acknowledged!) Thanks for info. Sounds like an excellent outcome for you with that fresh engine. Did you do yourself?
Windows
One (or more) of the windows needs its 'one-touch' operation resetting. This should reset it Close the window: Pull the window switch all the way up to the second detent until the window is completely closed. Keep holding the switch up for about 2 to 3 seconds after it shuts. Open the window: Push the switch all the way down to fully open the window, and hold the switch down for 2 to 3 seconds once it is fully open. Repeat closure: Pull the switch up once more to fully close the window and hold it for 2 to 3 seconds at the top.
Exhaust Backbox
Are they similar to the sport line shape? Or more like standard? I’m local to @tombee so perhaps they could serve us both depending on how they look!
Exhaust Backbox
I did check the donor bumper - and took me a while to notice that although its off a pre-FL L&K it doesn't have the cutouts so not from a 280. you're welcome to my old one with the tow-bar cut out. You'd never notice unless you lay down under the car. Either that or you can have them both - the one without the cut-outs you can use as a test for trimming and my old one for a fallback. I'll be swapping the parts over this weekend so aside from the 3-week delay, a mountain of swearing and grazed knuckles and then having to get someone capable of doing it, it'll be free from the car pretty soon.
