Where can I find free VAG vehicle data, databases or APIs for my app?
Translation; Hello everyone! I am currently developing an automotive application focused on Volkswagen Group vehicles (VW, Audi, Škoda, SEAT, and CUPRA). I am looking for free or open-source vehicle data that I could use for my project. I am particularly interested in: VIN decoding and vehicle identification Factory equipment and PR codes Vehicle specifications and engine codes OEM parts and compatibility information Service and maintenance data Technical and diagnostic information Does anyone know of any free databases, APIs, GitHub projects, or other publicly available resources that provide this type of information? I am also curious about how other developers obtain VAG vehicle data for their applications. Ideally, I am looking for data that can be used legally within an application—including, if possible, for commercial use. I would be very grateful for any suggestions or advice! Thanks in advance! @hebi123 Please be aware that the default language on Briskoda is English. Please use an online translation tool to post in English. Thank you. Pamiętaj, że domyślnym językiem na forum Briskoda jest angielski. Prosimy o korzystanie z narzędzia do tłumaczeń online, aby publikować posty w języku angielskim. Dziękujemy.
Adaptive grille ahutter
While that will happen, Skoda's stated reason for having fitted adaptive cooling shutters to the Fabia when the Mk4 version was introduced in 2021 was (as I highlighted in my posting of October 17 above) to improve the car's aerodynamics and reduce its fuel consumption - the same reason for Skoda fitting 'aero' trims to some Fabia Mk 4 wheels. My late-2023-built Fabia Mk4 SE L car's standard specification included the aero wheel trims, but the trims were dropped from the specification for the following model-year. My car does not have the cooling shutters and, apparently, neither does the 2025 Monte Carlo Fabia owned by @Alvin600 This May 2026 article compares the Skoda Fabia Mk4 with the Mazda 2 https://carvago.com/articles/car-battle/mazda-2-vs-skoda-fabia Active cooling shutters are mentioned in the "Aerodynamics and innovation" section of the Fabia review, but I suspect that this is an assumption based on Skoda's press releases rather than the reviewer knowing it to be true. (Perhaps @BACUPIAN could check if his Fabia has the shutters?)
1.0 TSI manual: difficult to pull away smoothly
Today, I dropped off my Fabia (1.0 TSI – 110 PS, DLAA engine, 6-speed manual) for its scheduled 4-year service, even though the mileage is quite low at 35,000 km. I had noticed that, quite often, the car struggled to pull away smoothly and gently when applying a little throttle, but I didn't consider it a significant enough issue to address. So, taking the opportunity today, I mentioned it to the technician. He performed a few short test starts inside the workshop and suggested that there might be an issue with the clutch slave cylinder. He’s going to verify this, and if that is indeed the case, it will be replaced under warranty. Once I get the car back, I’ll provide an update on whether a replacement was actually necessary and if that was, in fact, the root cause of the problem.
fabiamk4man started following 1.0 TSI manual: difficult to pull away smoothly
Activating SmartLink on Swing 3
Hello all, I've managed to activate smartlink, thanks for sharing all the steps. Now I have another problem, maybe someone else has a solution. connecting the phone with cable, all good, androind auto is working, no problems there. when I try to connect a wireless adapter in the car's USB port, connects with the infotainment, but when I pair the adapter with my phone via bluetooth, the infotainment gives a USB error end keeps resetting. It could be that the cars's USB port is low on amperage and keeps getting errors? Any advice or suggestions would be greatly appreciated. Thanks
Cześć wszystkim! Obecnie opracowuję własną aplikację motoryzacyjną skupiającą się na pojazdach Grupy Volkswagen (VW, Audi, Škoda, SEAT i CUPRA). Szukam bezpłatnych lub otwartych źródeł danych o pojazdach, które mógłbym wykorzystać w moim projekcie. Szczególnie interesują mnie: Dekodowanie VIN i identyfikacja pojazdu Wyposażenie fabryczne i kody PR Specyfikacje pojazdu i kody silników Części OEM i informacje o kompatybilności Dane serwisowe i konserwacyjne Informacje techniczne i diagnostyczne Czy ktoś zna jakieś bezpłatne bazy danych, interfejsy API, projekty GitHub lub inne publicznie dostępne zasoby, które dostarczają tego rodzaju informacji? Interesuje mnie również, w jaki sposób inni programiści uzyskują dane pojazdów VAG dla swoich aplikacji. W idealnym przypadku szukam danych, które można legalnie wykorzystać w aplikacji, w tym, jeśli to możliwe, do użytku komercyjnego. Będę bardzo wdzięczny za wszelkie sugestie i porady! Dziękuję z góry!
hebi123 started following Where can I find free VAG vehicle data, databases or APIs for my app?
hebi123 joined the community
No fluid in hybrid coolant header tank
Just take it to an Skoda/VW independant, it'll be a lot cheaper
Enabling extended tail light/drl (combi)
Hi! It’s still working perfectly! No error codes or anything like that!
Manoeuvre Braking
I experienced this neck-whiplash inducing emergency braking several times before I learned to manage it and now I only rarely encounter it. To my experience the trick is to constantly have some pressure on brake pedal and this prevents the emergency braking. If you let go the brake pedal even momentarily the car is going to take over. In my 265hp 4x4 the reverse gear is too tall anyway so I really do not mind reversing with constant brake application so that the clutch is slipping during the whole reversing motion and the car moves slower. I keep auto-hold enabled all the time but start reversing from so far away that slight blip on the loud pedal is not a problem. The same trick works also driving forward preventing the annoying collision alarm. If there is some car turning to side road and it would otherwise cause big beep you can prevent this by applying some constant slight brake pedal yourself the whole time when distance to this turning car shortens but because you are braking the car thinks you have situation under control.
JuSko started following Manoeuvre Braking
I need Bolero Update :-)
I have never heard about such firmware. Moreover, I have never found installation files for any newer software than MST2_EU_SK_P0359T. The solution you can use is to: Patch swdownload to enable installation of different firmware. Install VW firmware MST2_EU_VW_P0480T (metainfo2.txt must be adjusted to enable installation on your unit). Install patch to enable VW FEC/SWaP codes. Enable VW FEC/SWaP codes. Install modifed SKODA HMI.
Thank you!
Enyaq 85 sel 2026 tyre pressures
Where is my oil light!?
Back in 1991 when my mk2 Golf was built it had two pressure switches, one that covered the bottom end of the rpm spectrum, the other covered everything above that. I think some recent Skoda engines have gone back to having multiple switches, but only because oil pressure is being actively controlled to minimise wasted pumping effort. So that needs monitoring to know if the control system has failed.
- Where is my oil light!?
Hello @Krisz-III-FL ! I am looking for a solution for my 2018 Skoda-Superb and I have read here what you achieved. I will Try also on mine. How did your solution go so far? Thank you !
Superb2018Ambition started following Enabling extended tail light/drl (combi)
Thank you so much! Donated
Michal319 joined the community
Warrior193 started following Where is my oil light!?
My Android auto has stopped working because of the 00:00 bug. I believe I need SK_PQ_P0369T - is anyone able to help please? Many thanks!
iamstu1 joined the community
it is for cold winter, where thermostat dont open at all. so airflow thru cooler is not needed. with this blocage engine warms up more quickly.
imart143 started following Adaptive grille ahutter
Pd170 Injector seals.
The main things to watch on the BMN, going by the workshop procedure for that engine: - **Get the right bits before you start.** The seal kit (heat shield/washer and O-rings), plus new clamp bolt and rocker shaft bolts, because they're stretch bolts. Worth getting new ball studs and adjusting screws for the rockers as well, as the procedure says to replace them. - **Before you take anything apart,** if you have VCDS, record the injector balance values (measuring block 013) so you can compare afterwards. - **Getting them out:** the rocker shaft needs to come off evenly, and a stuck injector needs the proper slide hammer puller. Don't lever on the solenoid or the connector. Suck the fuel out of the bore before the new one goes in. - **O-rings:** lubricate lightly and fit them without rolling or twisting, otherwise you'll get fuel in the oil later. - **Refitting:** the injector has to be pushed square into its seat with the clamp while you tighten. If it isn't, it won't seal properly. - **Rocker adjustment:** this is the bit people get wrong. The adjusting screw is set with a dial gauge against the injector after fitting, and the procedure is specific to the engine. Get the workshop data for the BMN for this step and the torque figures, and don't copy figures from the 8v PD or the common rail engines, as they're different. Afterwards, prime the fuel, check for leaks, check the balance values again, and keep an eye on the oil level for the first few hundred miles in case an O-ring is leaking fuel into the oil.
SparePartAlam started following Pd170 Injector seals.
Octavia VRS Mk4 - real life MPG
Thanks CKO that's good to know. Your best figure is basically what Skoda give as an average mpg . I'll just have to live with petrol MPG now given the demise of the good old diesel VRS. Thanks again - Ian.
My colour edition also have fancy wheel trim inserts ( removable ) fitted to reduce the air flow 🤔
BACUPIAN started following Adaptive grille ahutter
SuperB II PQ device prototype for monitoring logging
1. Where to put the display (Web Interface): No external display needs to be mounted on the dashboard – the screenshot you see is taken directly from a web browser. The CarKit1 box itself is hidden wherever the Comfort CAN-BUS is accessible, for example under the dashboard next to the Gateway. It features built-in Wi-Fi and its own web server. You can view the data directly on your phone, tablet, or on an Android head unit (if you have one installed in your Superb II) simply by opening a web browser. 2. What the Lite version can do & Price: The Lite version is a purely local Wi-Fi variant (without an LTE modem or SIM card). It reads live data from the bus (fuel consumption, driving parameters, battery voltage, central locking and door statuses) and saves a local trip logbook / driving statistics into its internal memory. The target price for the Lite version would be around £75. 3. How the Active Alarm works (PRO version): The PRO version has its own built-in 4G/LTE modem. When the car is locked, the module monitors the CAN-BUS for the status of all doors, bonnet, boot, and ignition. If an unauthorized door opening or ignition turn-on is detected while the car is locked, the unit immediately calls your phone and sends a warning SMS specifying the exact reason the alarm was triggered. Also, if you have MQTT configured, the alert information is sent there as well.
Engine mount play
i put new hidraulic mount, Lemforder, and on lower mount i put powerflex yellow insert. now engine runs in idle like a diesel, but i think it will settle down more after a while. hidraulic mount had bad play, new one have almost not play at all.. https://photos.app.goo.gl/4hDEtQ2Q3wDCwcx7A
Hi all. Just seeking advice on injector seal change on my pd170. Bmn engine. Im handy with tools so not worried in that respect. Im just asking if there is anything to be wary of before I venture into changing them or if there is any guides on how to do them for my specific engine
mark_amus started following Pd170 Injector seals.
Pedro joined the community
So how much would lite version be and what can it do ? What is the alarm function ? Where would you put the display on a mk2 superb ?
