Past hour
campaign
When I started the car this morning. It came up on the screen that there were 2 campaign messages.. I pressed the first one and I was told to scan the QR code that appeared then press ok. The same with the second message. Then the screen went to normal. Does anyone know what this is about . The only thing that I can see different is in the Skoda app you can click on smart home and generate a key. How you use it I don't know
Jim1556 started following Potential new owner
Potential new owner
Hi all, I've been more than happy with my bought from new 2011 Octavia VRS TDI hatch, but it's now getting on a little at nearly 200k. So, I've placed a deposit on a 2024 VRS TSI estate as I no longer need a diesel. It's one of the last manuals built with only 16k on it. Anything common problems I need to look out for? It's coming from a main dealer, so comes with 12 months warranty (unless I go the PCP route) but I hate finance - although it gives an extra £400 off so... Any advice appreciated! TIA.
Could VCDS be used remotely?
I was recently out of town and needed to get my vehicle diagnosed pretty urgently. My situation was a little different, though. I used an OBD scanner, and a technician was able to run the diagnostics remotely while I was sitting in the car. You can read more about how that works here: https://www.flexihub.com/remote-vehicle-diagnostics/ In your case, though, you’ll still need someone on-site to connect a laptop to the car
Fred started following Could VCDS be used remotely?
luka2113 joined the community
mauska joined the community
L&K Front Fog light Bulb access?
I took my ill fitting R/H trim piece back off again today. It came off a lot easier the 2nd time around. Straight pull with two hands & gloves on did the trick. Seems one of the locating barbs had bent over preventing the trim from fully seating. I bent the barb gently back out & refitted it. It's fine now. As D402 said above, dropping the front underside tray is another option to get access from the back. Not easy scratching around on the floor trying to find all the retaining screws for the tray unless the car is jacked up or on a ramp but, it's doable as an alternative option.
- Hello from Sydney!
minsy started following Hello from Sydney!
Airbag light. codes 00532 and 01221 Mk1 Octavia
I'm wondering if anyone can point me in the right direction. Airbag light is on the dash. cleared it but it comes straight back. research so far has pointed me towards checking the wiring where it goes through the rubber boot in the door opening. I've looked in there and I can't see anything obvious. however it's so tight that even if something was broken I cant imagine getting enough slack to solder in a new bit. many thanks.
Samisit started following Airbag light. codes 00532 and 01221 Mk1 Octavia
Today
A 70 mph pheasant impact did the removal stage for me 😬 I think it might help to remove the undertray and access the clips from behind. If you need to replace the trim part, don't waste your money on aftermarket versions. The one I bought was a very poor fit and the chrome strip deteriorated quickly.
mcwieger joined the community
Skoda Kamiq Dashcam – Don’t make my mistake!
Every VAG car I've owned since 1999 has a permanently live 12V socket, which I find really useful for a coolbox. Apparently in non-UK vehicles the fuse can be moved to make the 12V socket ignition switched...
Headlights out ( dipped. & Main beam ) fuse and bulbs OK !!!
Dear all, yesterday noticed the headlights didn't come on. Main beam and dipped. Fuse OK, and I checked one of the bulbs and it looks OK. All other electrics seem OK. Can anyone help. MOT coming up All help/advice appreciated. Thank you
Fitting a 1.4 8V MPI (78mm) crankshaft into a Favorit 1.3 block?
The block itself should fit. Flywheel - this article mentions that you can use the Fabia flywheel in Estelle with a 5.5mm spacer, so it should fit Favorit, too. However, it mentions that to use Estelle's starter ring, the flywheel needs to be ground to a smaller diameter. I'm not sure if the starter ring itself is the same as Felicia or not. skoda-virt.cz/cz/clanky/motor/7994-par-tipu-na-upravu-motoru-1-4-mpi-do-742-3/ There was user on Briskoda, who fitted Fabia engine to Felicia, but they swapped flywheel, too. You'll also need to figure out engine mount, on the pump, as Fabia has different pump and V-belt closer to the block. It also lacks output for the distributor, but according to the article above, you cannot just swap the timing chain cover, because it contains oil pump, and the older oil pump is not sufficient to pressurise Fabia's hydraulic tappets. In any case, the rebuild will always require some form of mixing the parts of the 1.3 and 1.4 engine.
Matt1988 joined the community
A week after I took delivery of my 2023 Kamiq SE Drive TSI DSG, after a night of snow and heavy rain, I turned the ignition to start the car and nothing! The dash lit up but there was no noise from anywhere. Having run the car for a few days on very short trips, the breakdown guy suggested the extreme cold, snow and the short trips had combined to flatten the battery. He said power drain from the dashcam was something and nothing. The only thing I had done to the car since purchase was to fit and power a dashcam from the 12 volt socket. Every car I have ever had in 60 years has always turned off power to the 12 volt socket, after the ignition is switched off, but NOT Skoda/VW! After reading online contradicting statements and testing it for myself, the 12V socket is permanently live and the dashcam had drained my battery which I was on the point of replacing. I will now power the dashcam from the usb-c socket but the cable or one of any 2 cables coupled together needs to be the data blocker type to stop attempted data transfer warning. USB-c socket goes dead 1 to 2 minutes after switching off the ignition.
Geoff123 started following Skoda Kamiq Dashcam – Don’t make my mistake!
Elroq Vrs Road tax.
It was first registered November 2025. £40,000 Luxury VED. Change came April 2026 as being £50,000
Evolution13 started following Elroq Vrs Road tax.
Mk3 Fabia subwoofer install
As you know, there has NEVER been an OEM option of subwoofer in Fabia Mk3. However, in VAG environment you can find subwoofer in similar small cars, e.eg. VW Polo - see the picture below. Being in your shoes, I would go for similar setup - with subwooger installed in the spare wheel. I don't know part number of your infotainment reader but it if you have Bolero or Amundsen then it's possible to replace it with SEAT version that can drive subwoofer directly (no external power amplifier needed) and gives you possibility to adjust subwoofer level directly from the infotainment unit display (it must be patched and reworked to support SKODA HMI - I have already done it couple of times).
Simonm1012 started following 2011 lights
2011 lights
Hi all is it possible to change bulbs/ lights on a mk2 as they are terrible looking to modern white beam? Regards
Simonm1012 started following Skoda Fabia Mk2 (2007-2014)
Elroq Vrs Road tax.
Both numbers can be right, they're just answering different questions. From GOV.UK's vehicle tax tables: after the first year every car pays the standard rate, £200 a year. On top of that there's an extra £440 a year if the list price was over £50,000 for an electric car, and that's where Vertu's £640 comes from. For EVs that applies to cars registered from 1 April 2025, so a 75 plate is in scope if, and only if, its list price was over £50k. It's charged for 5 years, starting from the second time the car is taxed. So it all comes down to the list price when new, not what it's for sale at now. GOV.UK defines it as the published price before the car was first registered, before any discounts. Skoda launched the vRS at £46,560 OTR, so a car with no options would be under the line, but individual cars were ordered with extras like the Hyper Green paint and 21 inch wheels, so you can't tell from the model name alone. Depending on when in the 75 plate period it was registered, it may not have reached its second tax payment yet, so the £200 you saw on the DVLA site doesn't settle it on its own. I'd ask Vertu in writing where their £640 comes from and what list price they have for that exact car. GOV.UK's own advice is to check the list price with the dealer. If they can't show it, a Skoda dealer can look the car up from the VIN.
Elroq Vrs Road tax.
Provided you have entered all the correct details into the DVLA website, I'd believe that figure.
skoda octavia 2025 tsi 1.5 manual
I would like to know if any skoda /vw garage has managed to fix the 1.5 tsi evo engine cut out problem when braking at traffic lights or going slow?
Red 2017 Skoda Superb Sportline TDI DSG hatchback
Updated mileage is 85218. Here are a few additional pics of the interior that I took at the weekend.
Stevio joined the community
Constant creaking / rattling from the doors of my Kodiaq Mk2
They put grease on and it cured it for about 24hrs and then breaking is slowly starting to come back. Question - what colour are peoples cars who have this issue? Mine is Meteor Grey. Also has anyone had a ceramic coating put on? I have an AutoGlym ceramic polish on and I’m wondering if that is the issue.
DCC Slider adjustment option mod
provided u have the 3Q0 gateway and 5Q0 suspension modules. MIB (infotainment) doesn't matter.
Elroq Vrs Road tax.
I'm thinking about a used Elroq vrs and spotted this one near me. https://www.vertumotors.com/used-cars/used-skoda/used-skoda-elroq/4265139/skoda-elroq-250kw-vrs-84kwh-4x4-5dr-auto-electric-estate/?queryID=1ad92f010545444b1403ad43a2ad5817 According to the info on the Vertu website, the car is £640 a year road tax!!! (reg KP75EHS) Surely it wasn't over £50k new. When I put the reg in the Gov.uk website it says it is £200 per year. Who is right? Any help appreciated.
- Servicing my serpentine/auxiliary belt, what brands should I get? (CGPA)
Yesterday
MIB3 Preh – VCRN Showing 1234 on All FECs – What Could Be the Cause?
Please do not confuse MIB2 with MIB3. SWaP/FEC has nothing to do with the way the display/interface is implemented—that is something VW handled differently. MIB3 has a completely different architecture, though it does still make use of SWaP/FEC.
I have an MIB2.5 unit, which uses the same principal as MIB3 for FECs and SWaP codes. This is how it shows on mine the Infotainment Service Menu..... apologies for the screen glare.
