Amundsen MIB2 Firmware Update
Thanks - what is the key?
Most upset, my V3 L&K written off after a cretin drove into me.
Fair one. Such a shame when someone’s incompetence causes so much hassle!
3.4 GB file on MEGANo warrenty
No time, no inclination. I need a car to do my job, so i need to buy a replacement to keep me mobile.
Last speaker swapped out this evening. I thought I was doing it preventatively but one tap from the hammer on the punch to knock out the centre of a pop rivet and the magnet fell off the speaker! Hopefully these will last a good while now but I have a spare just in case and have got it to less than 30 minutes to swap them out. Even in the dark with a head torch!
Not worth writing off and buying back to repair?
MIB3 map update
That's saying 26.10 so you have an update ahead of the file one so it won't degrade. That's an over the air one.
Probably... Trouble is insurance will have worked on new parts and you'd be looking at about half that just for the bonnet... It's a rip off if you can't choose where it gets repaired and how and I'm sure they prefer to write them off as it's cheaper for them. Means decent cars get written off for small amounts of damage.
Engine sounds like old transit van after timing belt change --- 2020 Octavia 2.0 TDI ( DSTA / EA288 EVO )
In the UK, my Mk4 was registered in September 2020
The first step is to get the 0334 update for the infotainment which then allows the other applications to update successfully... You can wait for the OTA to be offered with you but it seems this can take a long time and there's no way to force it. You can ask the dealer to start the update for you but it's probably not free unless your car is still in warranty. Or you can follow the instructions from PeterTr above to do the update manually yourself. Gabbo
Everything other than the village names works OK. Using the same map data on the same Skoda SD card shows the villages on a similar unit in a friends Golf but not in my Octavia. On that basis there must be a difference between the two Amundsen units, and the firmware might be the difference? I don't think the firmware on my unit has ever been updated, so I think it is worth trying an update from version P0241T to P0253T. Can anyone help me in obtaining the files for the update?
Admunsun sat nav UK towns and village names missing on screen
Kodiaq 2017 - Strange 9 errors from nowhere
Hi! As the warning lights on your 2019 Škoda Kodiaq 2.0 TDI come on as soon as you start the engine, before the car moves, I would consider a wheel-speed sensor failure to be less likely. I would start by checking the battery, as a weak 12 V battery or a voltage drop when starting could generate similar errors. Could you check the battery voltage? It should be at least 12 V; when the engine is running, it should reach up to 14.5 V depending on the state of the battery and the smart charging system. WBR Primoz
2017 diesel 150 DSG 4x4 fuel filter identification
If you don't have this kind of tool. You can proceed this way: 1. Set ignition ON (without starting the engine) for 10s. 2. Set ignition Off for 15s 3. Repeat 1 & 2 4 or 5 times 4. Start the engine (if it stalls, start again from the beginning) 5. Rev the engine around 1500 rpm for 30s to get rid of potential air bubbles in the fuel system I've done this about 10 times on several TDI engines over last 20 years. Never had any problem.
Thanks, but in not after a leggy car, looking at les than 40k miles 😀 Insurers rarely use second hand spares, must quote on new parts.
Thank you, I've done it for a few years now. I don't get the actual money back (~£1500) but it changes my tax code upwards. Not as good as getting 55p/ mile expenses......
Hi @zer081, We're not talking about the same SW version. See the explanations above to check the infotainment SW version. ;)
There’s a few iV L&k on Autotrader currently for less than your payout. E.g https://www.autotrader.co.uk/car-details/202610207160878?utm_source=share&utm_medium=ios-app
If your company pays you less than the maximum permissible HMRC figure, you can claim for tax relief on the rest. Just need logs and can claim up to 4 years in the past. https://www.gov.uk/tax-relief-for-employees/vehicles-you-use-for-work
glow plugs
sorry forgot to update, i managed to get a set of 4x genuine vag ones at a good price, and thankfully the mechanic at the garage i use got all 4x glow plugs out and replaced them with no problems. thanks kev!
CactusFruitJuice started following Skoda Octavia Mk3 (2013 - 2020)
Bumper, wing, headlight, wheel, bonnet. I reckon £2k max in second hand spares?
Binx1310 started following Most upset, my V3 L&K written off after a cretin drove into me.
Guten Tag, ich suche einen Spezialisten für einen bislang ungelösten Elektronikfehler an meinem Škoda Kodiaq 2.0 TDI, 150 PS, DSG 4×4, Baujahr 2019, 210.000 km. Direkt nach dem Motorstart erscheinen dauerhaft fünf Meldungen: ESC, Berganfahrassistent, Front Assist, Verkehrszeichenerkennung und Reifenkontrollanzeige. Eine andere Werkstatt hat bereits alle Steuergeräte ausgelesen, konnte aber keine Ursache feststellen. Kann jemand helfen? Dankeschön und liebe Grüße Hello, I am looking for a specialist to help with an unresolved electronic fault in my Škoda Kodiaq 2.0 TDI (150 hp, DSG, 4x4, 2019 model, 210,000 km). Immediately after starting the engine, five warning messages appear and remain on: ESC, Hill Start Assist, Front Assist, Traffic Sign Recognition, and the Tire Pressure Monitoring System. Another workshop has already scanned all the control units but was unable to identify the cause. Can anyone help? Thank you, and best regards. Auf English bitte @Kiawisnseppl The default language on Briskoda is English. Thank you.
Kiawisnseppl started following Kodiaq 2017 - Strange 9 errors from nowhere
CactusFruitJuice joined the community
Kiawisnseppl joined the community
fuel filer panel
hi, can anyone point me in the right direction just recently the fuel filer panel has got a bit temperamental when you give it the little push to click it open it isn't opening, so i thought i had better look into it before it stops altogether and i cant get any fuel in. 1st question is there a way of opening the flap manually ? 2nd any advice on what the problem could be? 3rd is there some kind of tutorial on how to take it apart without braking it? many thanks kev!
Superb MK3 Matrix Headlight changed
Hi guys! So i had to replace my 2020's matrix headlights because of an incident. The newer ones are made in 2023 with a new oem number. After the replacement i noticed that my right one is not doing the calibration when i start the engine. ( I mean there it goes a bit down than goes back in that place when i started the engine.) After this, i changed the control modules of the headlights back to the previous one but symptom is the same. There is not a single error message, in vcds too.. Can someone help me with it? Thank you!
