Columbus Infotainment System
Hey there Chaps, I am getting the same issue . Skoda Superb Elegance 2012 plate. "Software Download- Source Activated, Searching for SWL Image" Would it be possible to send over the software link so I can burn it onto a CD. Many thanks
SKODA_SUPERB started following Columbus Infotainment System
DPF Problem SS II
in video, this chemisist removed all, first soot and then ash with 25% HCL. listen him again.
Enyaq iV Owners Register
Hi all, after my lovely Superb L&K hybrid was written off by a myopic cretin that couldn't hit the ar5e end of a cow (but managed to find the front of my car) I decided to go full electric. My Mrs had an Enyaq before, so it was a natural choice for me. I now have an Enyaq Coupe vRS (2024). This was a pic at the dealer, the wheel covers have since come off.....
SKODA_SUPERB joined the community
DPF Problem SS II
Worth a go for soot, but bear in mind a flush or DIY clean won't shift much of the ash at 230,000 km. If you do clean it, reset the DPF ash/soot learned values with a diagnostic tool afterwards, or the ECU will keep calculating it as blocked.
Seat Heating/Cooling
Anyone else using the auto function for heating and ventilating? Just today I noticed a setting to increase the intensity of both in the seat and back of both front seats and also the auto function. I didn't even know you could have heat and ventilate at the same time!
Dubb3rz started following Seat Heating/Cooling
DPF Problem SS II
no need to open dpf, many people cleaned them by therirselves. look for this video, you ill get all answers.
imart143 started following DPF Problem SS II
- Hi Briskoda!
Amundsen MIB2 Firmware Update
here, you have latest 480T firmware, also your 235T https://mibvault.com/files/MST2%20-TechniSat%20Preh/Firmware/SKODA_ZR/EU
- Hi Briskoda!
Davidonthecoast started following Hi Briskoda!
samg098 joined the community
Davidonthecoast joined the community
Epiq Sportline!
And there's now a Sportline trim that looks far better in my opinion. You can see it on the Skoda UK configurator, and the International brochure at Skoda-Auto.com has details. (The UK brochure hasn't been updated yet.)
Stopping chain noise
Read it. Anytime you like. Search. VW recommendation of VW 502 00 oil euro 5 tsi engines 5 years and over.
No hurry. 🙂
I can not link it just now, but a man of your ability can read it easily. Do a key word search. If i could link it because on a very poor internet connection. I have to keep reposting. Or maybe someone will link it for you @Lee might help me out.
Waiting for link or doc.
Timing stuck at 38
I'm still stuck with engine timing of 38 on VCDS, which won't change no matter what I do with the pump (retard or advance). It still drives though but totally lacking power and hesitates. Things I've tried so far are: "Hammer mod" to get the injection quantity adjusted so the car would idle nicely. Re-checked timing marks which are still lined up. Changed crank sensor. Check resistance on the #3 injector needle lift connector. Used AI and VCDS to check the #3 injector needle lift sensor. Used AI and VCDS to check the N108 sensor New fuel temp sensor. Turbo was off and cleaned and I have re-checked the the shaft spins freely. Does anyone know if I should check the static timing with a dial gauge? The 6mm locking pin lines up but I wonder if that could be out? (so the IP is out of the correct timing when the 6mm locking pin is in place) I'm getting desperate as I need a car and winter is here. Any other suggestions? Cheers for any help
Well you will understand way the made that recommendation within a few years of introducing the Euro 5 TSI,s and having so many issues. 1.2, 1.4, 1.8 & 2.0 TSI,s. Issues with higher than acceptable oil use with some, timing chain issues a premature expiring engines especially 1.4 TSI Twin chargers and 1.8 / 2.0 TSI,s. Long Life Oil, lots of short life engines.
I don't use AI. I just understand how VW group specify oils. If there's an official VW group document you're referring to, I'm sure you'll manage to post it or link to it in due course.
Do not use AI mode. Use the key words VW recommendation euro 5 tsi,s oil 5 years +. VW 502 00 'Usually 5w 40 full synthetic. & they explain why. And that has been the case since 2014.
Tyre recommendations
The ZE320 is a replacement for the ZE310 Ecorun that I've had on my Suzuki Swift for a few years and have been very happy with and that are infinitely better than the Bridgestones it was originally supplied with. The 320's are an improvement in that they have a slightly lower noise rating and slightly better (lower) rolling resistance, so you should be more than happy with them.
Where was that recommendation, and for which cars/engines?
^^^ That is good, but VW specifically recommended the 40. 40 for the HIGHER STABILITY. so really the 0w 30 FS III is neither hear nor there. But the 0w 40 meets what they said. VW not me.
Nope, even back in 2024 (last saved list I could find) it could also be 0W40, 0W30 and 5W30, here's just the first few oils listed as 502/505 approved.
Crank but no start 2.0TDi
So the latest update on this, turns out cylinder 1 is over fueling which is causing the ticking, all other injectors have been inspected and appear to be in good shape, looks like I will eventually have to do the other 2 injectors
Power steering (Rapid)
No reservoir is a good clue. Here's a pic of the hydraulic installation; the pipe connections to the steering unit should be obvious, too.
I need Bolero Update :-)
sent in PM
