  2. I had to google 'axial bearing', which appears to be the crankshaft thrust washers. Have they established how much play there is and if there is any damage to the crankshaft?
  3. There’s two different fuses depending on side of car, but yeah it’s not that unfortunately
  4. I have seen this before. It seems to be very hit and miss for coding this. I tried exactly the same as I did on @AL2772 's car using my module and app and it just kept saying bad OBD2 module. I think it is very dependent on your OEM dataset version. Does carscanner and your module work for other coding ok?
  5. use solution posted one post above, v1.31.70 loads with it
  6. JStyles joined the community
  7. I installed Bevinsee LED headlight bulbs to replace the bixenons and they are great. Passed MOT no issue too. Highly recommend them. https://www.ebay.co.uk/itm/298188805629 £28 a set with the coupon code currently. But both sides you have to jack up car, take wheel off and arch liner out to get to them. I managed to get one bulb out from above but couldnt get the new one back in.
  8. Hello @Gizmo Will it be the only one able to sort coding? Any links recommendation please? My 2 obd2 not able to do and showing faulty wondering cos car not able to do no matter what as showings my diagnostic tool faulty Please read my new respond in here Are you able if so change dataset and what with?
  9. Yep I would concur with that. The new fog bulbs are looking much more like the main beams now, if not a bit brighter / whiter. Close up inspection of the original Bi-Xenon main headlight inner lenses shows that they do look a bit cloudy. Need a clean perhaps? I'm wondering whether I should consider changing the Bi-Xenon's for LED's or, leave well alone? Looks like changing the drivers side is fairly straight forward but the passenger side involves removing front wheel & wheel arch liner to get to the back of the headlamp unit as under bonnet access is very tight😒. I think I will leave alone until the weather gets a bit warmer. Not the time of year to be messing about in the cold on my drive.🥶 For reference below is a Ali Express link for the replacement Fog LED bulbs I used. Fairly cheap at £9 but so far so good. The car is in for it's 8th MOT today @71.5k🤞 https://www.aliexpress.com/item/1005006840794986.html?spm=a2g0o.tm1000027143.appPushSupportRecommend.3.71cc6a77QFScA6&gps-id=appPushSupportRecommend&scm=1007.67346.516855.0&scm_id=1007.67346.516855.0&scm-url=1007.67346.516855.0&pvid=0fd4b796-753d-4d2d-8e4d-cf5800ec5718&_t=gps-id%3AappPushSupportRecommend%2Cscm-url%3A1007.67346.516855.0%2Cpvid%3A0fd4b796-753d-4d2d-8e4d-cf5800ec5718%2Ctpp_buckets%3A668%232846%238110%231995&pdp_ext_f=%7B%22order%22%3A%2271%22%2C%22eval%22%3A%221%22%2C%22sceneId%22%3A%2257346%22%2C%22fromPage%22%3A%22recommend%22%7D&pdp_npi=6%40dis%21GBP%218.13%218.13%21%21%2110.37%2110.37%21%402103849717951015968395942e0ef6%2112000038479188887%21rec%21UK%213413154159%21XZ%211%210%21n_tag%3A-29919%3Bd%3Addd822d5%3Bm03_new_user%3A-29895&utparam-url=scene%3AappPushSupportRecommend%7Cquery_from%3A%7Cx_object_id%3A1005006840794986%7C_p_origin_prod%3A
  10. Doesn't dim as its been replaced with standard glass when I broke it but will give the heating a go. The puddle light that side still works. Will try the adjustment too. I would have thought if it was fuse would both mirrors be affected?
  11. Hello So I have tried many times yesterday Don’t work at all. My control module is 5Q0959107L I got obd2 as follow Vgate vLinker MC+ Bluetooth 4.0 OBD2 Car Diagnostic Scanner Also MUCAR BT200 Max Automotive OBD2 Code Reader Lifetime Free AI Diagnostic Scanner also vcds I know vcds won’t work But with above every time try do something saying’s that my obd2 are faulty They are genuine btw. Also im using car scanner pro ( paid for full version) Anyone able please direct me in the right direction? I have read all 9 pages but would love someone go through again perhaps some more new updates etc Thank you in advance
  12. today I received a letter from VAG Croatia, regarding the replacement of one bolt of the steering rack. I won't go now because many rushed to the service stations and created crowds because they think their steering wheel will fall off. when the situation calms down, I will go. in our country, insurance companies supervise this service action and it is changed on literally every car on these platforms, because in the event of a collision, an accident or a bolt breaking, great damage and life-threatening damage can occur, so the action is not optional but mandatory. or your insurance will not pay compensation if they estimate that the bolt is to blame for anything. I translated it into Eng.
  13. Shine a torch at the interior mirror, is it wing still dimming? Could also try heated function too Just wondering if motor is dying and it’s tripped a fuse or so Edit: Just checked and that’s fuse 39, looks like if that went you’d have issues with central looking on passenger side Still be worth checking the dimming and heating works though, does the mirror movement still work? If all good guess it’s just the motors had enough Must admit mine sounds a bit “dry” sometimes like it needs more lube, but never bothered to look
  14. Today
  15. It was the bulbs. Thought it was something more serious as they both went at the same time.
  16. Hello everyone Would like introduce myself and say hello everyone. Based Hereford Vag man Skoda Superb MK3 Estate 2016 2.0Tdi 190bhp Dsg DQ250 As you can imagine this car it’s absolutely Superb
  17. Went out to the car this afternoon to pick the kids up from school and the passenger side mirror didn’t unfold. Flicked the switch a few times and no joy. Tried gently pushing it as unlocking the car to see if it could help it and and it seems it doesn’t try to open up at all. It can be moved by hand but it’s not moving the motor, just moving it off its position. If that makes sense. Anyone had anything similar or is it terminal?
  18. Also pics of both umbrellas and the boot:
  19. As far as I know (not a Fabia owner) the numbers relate to the number of unread messages that you have received on your phone since it was connected to the car (eg Whatsapp or text).
  20. Anyone have any idea what the numbers mean in the photos below? Obviously the blue symbol indicates Bluetooth but why the two numbers 1 and 2 in the other photos? The Bluetooth symbol and the others appear seemingly random regardless of what the phone is doing. There is only one phone linked to the car and most of the time it is just sat in the cubby hole or my coat pocket. There's nothing in the manual to indicate the difference, and it's pointless trying to ask the dealer! FP
  21. I have had mine out a few times now after changing the bulbs for various reasons, and they seem to come out quite easily now. I think once you have removed it once, it tthey are much easier from then on. I hope you like the bulbs and it was worth the effort!
  22. HI All, 2 fault codes picked up on my car, not effecting any driving or performance P2002 "Particulate filter efficiency below threshold" and P0474 Exhaust Pressure sensor A Circuit Intermittent/Erratic. From what I have been advised it can be one of 3 sensors. Car has passed all emission tests and runs like a dream even with 220K on the clock, ad blu has been bypassed. Before I go through swapping the sensors 1 by 1 to find its the last one and spend too much doing so, would any of you legends know which sensor is more than likely to cause these errors and bring the engine warning light on. Thanks all Dan
  23. Hiya, new poster here. Just back from getting my car looked at, I had an occasional yellow engine light and rough idle at cold, garage has identified play in the axial bearing. According to their source in a Skoda dealership, it's a new engine job - is this right? TIA
  24. SecretSam joined the community
  25. Thanks @k00ks , appreciate your help! @CrazySkoda @varooom @andreiro221 I've investigated the firmware packages further and found something interesting: Both 0469 and 1800 have exactly the same Variant (FM3-E2-*-*-SK-MQB-PA-*) in their main.mnf manifests. Both also have identical BlockedTrains lists, which don't include my current MEN3_EU_SK370_P9305P. The 1800 emmc_device manifest doesn't explicitly restrict HW 033 either. This suggests the P/L suffix doesn't necessarily indicate hardware compatibility, although matching manifests alone don't guarantee a safe update. Has anyone successfully upgraded an HW 033 unit to 1790/1798/1800? I'd particularly appreciate confirmation before risking my infotainment unit. My main objective is fixing Android Auto connectivity with my Samsung Galaxy S23+. Thanks.
  26. I have a Superb with the same issue. It got really bad over the summer and I booked it in with the dealer a week ago. The night before I gave it a quick wash at the local jet wash. That stopped it creaking! So the dealer had nothing to go on. They dismantled the door card and window regulator. Then reassembled,greasing the mating parts. So far it hasn't come back but it has rained a bit so I doubt the seal has dried out. I agree that it seems likely it comes from the felt seal at the top of the door. That would explain why hosing it down with the jet wash cures it. If it comes back I'll investigate some of anti squeak tape suck alopng the body where the felt rubs. I've seen this used on a BMW forum for a similar problem. https://f30.bimmerpost.com/forums/showthread/1210175/fix-annoying-door-creaking-bmw-3m-tape-solution https://www.babybmw.net/threads/creaking-doors-update-resolved.65299/
  27. @pervp Have a look at my last post. Godspeed!
  28. Cheers man. I have the swing/swing+ information screen So how easy is it to install this subwoofer? And what wires do I need?
  29. I'd echo @Nick_H's experience - brake discs and pads, shocks, springs and top mounts; and add the battery and air quality sensor. Read the fault codes if you can to pick up any hidden problems. I think the Superb is hard on the basic wear and tear parts because it uses Golf sized components on a much larger car.
