Past hour
Skoda Superb Combi 3V539Z suspencion
One way to lift the car is to fit tyres with slightly more sidewall height than standard. such as 215/65R16 6.5Jx16 ET41 or 215/60R17 6.5Jx17 ET41. Notice in the chart below, that going up 5% in the aspect ratio of either 215 tyre size increases the outside diameter of the tyre by 21.5mm which adds 10.75mm in height to the vehicle. Outside diameter of tyres 215/60R16 664.4mm 215/65R16 685.9mm 215/55R17 668.3mm 215/60R17 689.8mm
12V low, can I charge it up with a charger?
Thank you.
Dashcam Switched Power
I turned I turned off my stop/start by raising the threshold of the voltage at which point it comes into play. The car now behaves as if is not fitted with the system. The minute amount of fuel it uses is way cheaper than the cost of replacing the battery, starter motor and alternator, which work harder with the system activated, and the camera switches off and on all the time. This is a better solution I think, especially if you drive in a town or city a lot as it exposes you to a higher risk of not video evidence at times of increased risk.
Penguinpete joined the community
Karoq useless Satnav
What about a multi waypoint route through small towns and villages. How do you plot that ? Do you guess which brown blob is the village you want. If Google Waze and others can do it why not Skoda. Smarty.
Today
Yeti 5L: byte 18 changed, need BCM light config (VCP) - halogen
Thank you, that’s very clear and reassuring! My rear lights are halogen (P21W bulbs). Does anyone here have VAGHelper and could check the Skoda Yeti 2014 halogen scheme (halogen headlights, front fogs, halogen rear lights)? A screenshot of the outputs or the .bcm1 file would help me a lot. Thanks!
As far as I know, if byte 18 was 00 then no byte 18 value is correct for that vehicle. Some might be close enough that everything seems to work but there will be a difference that an engineer in VAG thought was important. Byte 18 mostly deals with lighting channels that aren't the headlights or front fog lights. As long as the example you find from VAGhelper has the same rear lights (halogen or LED) then I think you have a very good chance.
Zachy64 joined the community
Neil.R started following Bluetooth/Phone problem.
I’m at the tearing my hair out stage with a problem using my iPhone SE via Bluetooth, if I dial a landline (home for instance) then it says “there was a problem” on the info screen & doesn't connect it also says “this contact is not on WhatsApp” but if I dial a contact via a mobile No it connects. I’ve tried everything that search engines can come up with to no avail, & it’s far to cold to sit in the car unpairing & pairing Bluetooth 😀😀 TIA))
@langers2k Thanks a lot! I’ll have a VCP user write a config in January, starting from the Yeti config in VAGHelper and adapting it to halogen + front fogs + headlight washers (byte 18 stays at 00, current config saved first). Two quick questions, if you don’t mind: On an Italian forum someone suggested writing 74 in byte 18 as “Yeti halogen facelift”, but in the tables I found 74 is “Superb (SK461) China, no DRL, LED SBBR”. Is there any byte 18 value that loads a halogen Yeti config on a 1K0937087AN, or is VCP the only proper way? In VAGHelper, is there anything specific to change from the default Yeti config for a halogen car? I’ll post the result here. Thanks again!
- Dashcam Switched Power
Heater Matrix Flush??
Three garages told me to replace matrix for heater working driver side only, had main rad replaced after it split, garage vacuum filled coolant system, heater has worked perfectly ever since (5 years ago) This was a French garage and they said the main issue was casting material, not the silicat bag, which holds very little material. Some time later had thermostat replaced, the pipes around that area were full of casting sand.
adg1 started following Heater Matrix Flush??
Bonnet support clip come away
That’s what I assumed, similar to the parcel shelves. But when I push the pin down it doesn’t spread the tabs out very much and it just falls out.
https://www.manualslib.com/manual/2187276/Skoda-Enyaq-Iv-2020.html?page=216
Stonekeeper started following 12V low, can I charge it up with a charger?
I’d guess, that it has an expanding pin fitted into it, so you fit the support down into the hole then press/punch the expanding pin fully down and that will lock the clip in place.
- L&K Front Fog light Bulb access?
Well done! I found with mine the first time was the hardest, and since then they come out easily, they could well have never been removed since factory! The chrome strips clip into the main part so may well have come out a tiny bit when you pulled them off. May just need a gentle push back into position, or the overall piece may need realigning to push home.Cemac joined the community- Bonnet support clip come away
The clip that holds the bonnet support pole has come away and will not go back in place. I bought a new one from Skoda for £3 and I can’t figure out what I’m doing wrong. Can anyone advise how I get this yellow clip to lock into place. Image below is a picture of the clip I’m having trouble with. It’s a library pic not my actual car.Jonop started following Bonnet support clip come awayiamwill joined the community- Change details.
How do I change my email and address Please?EJB started following Change details.- Autodoc - avoid!!!
I've actually had a pretty positive impression. They offer a huge range of parts at competitive prices.JackTurner started following Autodoc - avoid!!!- Can anyone diagnose what might be causing this noise?
Sounds like the cabin blower motor or debris trapped inside the fan. Since the noise changes with fan speed and disappears when switched off, I'd start by checking the pollen filter and blower fan behind the glovebox. Leaves or worn motor bearings can cause exactly this kind of clicking and whining. If the motor needs replacing, Ridex car parts could be one aftermarket option worth comparing.Fenix2121 started following Can anyone diagnose what might be causing this noise?- Can anyone diagnose what might be causing this noise?
Hmm. Not sure it’s a leaf. Had an explore under glove box - removed air filter and noise still audible. Definitely sounds like it’s coming from driver’s side in RHD set up. When I put fan on you can hear the initial noise in this clip. Sometimes it lasts a couple seconds. Sometimes it’s 5 seconds long. And then disappears. Could it be a bearing of some kind? IMG_1926.mov- Rear diffuser fins
Looks like it's HSK 3D who makes them in the UK. https://hsk3d.co.uk/store/skoda-octavia-mk3-rs-vrs-rear-diffuser-fins-3d-printed-bumper-splitter-styling https://www.ebay.co.uk/itm/318144171141langers2k started following Rear diffuser fins- New Rear Side Passenger Door - advice on where to get one?
Sanburn at Coventry are fairly cheap. They’re on the Bayton Road industrial estate. Other than that, eBay is fairly good for partsEmmz started following New Rear Side Passenger Door - advice on where to get one?- 12V low, can I charge it up with a charger?
We have been getting 12V low warnings from the car the last few days, and also it's been offline, so I know the 12v is in trouble. Reading around this topic there seems to be no definitive on whether or not mains charging or driving the car charges it back up, so my question....can I put my Noco battery charger on it " old school " if you like and charge it up? . If I do, will it mess up the cars electronics?- fuel filer panel
Try opening the car with the key fob at the same time as pressing the flap, works for me- L&K Front Fog light Bulb access?
Finally. After much cursing, swearing, copious amounts of WD40, plastic trim removal tool insertions / prodding & general faffing about for nearly 2hrs I managed to get the dam things off the car to access the fog light units. Surely it shouldn't have to be that hard? Installed LED bulbs which look great & now match factory headlights. However, one re-installed trim cover is not sitting quite right. The chrome strip is not flush with the corresponding piece on the lower bumper☹️. I'll leave it for now but my OCD will not allow it remain like that. More faffing required after I thaw out & have a cup of tea 🫖. - L&K Front Fog light Bulb access?
