ZSabo17 joined the community
The update they mention for the facelift versions is more that the infotainment unit - it's a package with software updates for many other ECUs on the car - called PV4RC. The update is worth doing - the general opinion is that it addresses several SW gremlins, even though I still have some issues trailing after the update. AFAIK the latest update for the infotainment unit is 2768 for Seat/Cupra - the Skoda one should have the last digit +/-1 - otherwise they are "labeled" the same for VAG siblings sharing the same hardware. There was no major version update for the infotainment over the past year, unless the new models coming out of the factory have a newer version that's still unreleased OTA.
Skoda Fabia 1.2TSI Monte Carlo 09/2011 - Electric Windows Fault
Pete, The Drivers Side Door Switches Illuminate with the lights. The driver side window controls don't operate either side at the moment. The passenger side window controls are not working either. Everything on the Drivers door works perfectly (i.e. Electric Mirror Controls, Electric Mirror, Central Locking & Door Switch For Interior Light.) The car has a full history and the previous owner has spent a fortune maintaining the car, which leads me to believe he has already had a garage look at it. This is why I'm trying to gather as much information as I can, as I expect the repair to be a little cumbersome and not straightforward, as he would have already resolved the issue if is was simple.
Skoda Felicia 1.6 how to replace part number 6U0711248
The ''feeling'' now is better when you change gears? My gear stick sense was very sloppy plus i has a problem in 3rd gear,it was shaking a bit and i always afraid that it will be disengage by itself. ๐
What summer tyres do you drive on 19'' wheels with your Kodiaq?
We have Maxxis Victra sport 6 suv on our 1.5tsi and never had any issue with them. Seem to grip well in the wet. Not having to handle about of power but we are very happy with them!
Binx1310 started following What summer tyres do you drive on 19'' wheels with your Kodiaq?
Matrix headlights with auto high beam
Do you have your headlights on "Auto"? If so, i think you can press the "Low beam" button, which will turn off the high beam without flashing other drivers
evilsheep started following Matrix headlights with auto high beam
I successfully replace this rubber and 2 pieces of o-rings.
- Strange Electric Window Behaviour - Passenger & Rear Windows Respond Incorrectly
2013 Superb 1.6 electrical issues
Udate, this issue has been traced to the wiring loom from the steering wheel, the column was in the lowest position and is causing an interruption in power to the dashboard kicking in the immobiliser circuit that momentarily cuts power to the engine causing a stall. With the steering wheel in the uppermost position the car runs perfectly. The job now is to have a look at the wiring loom for either a break in a cable, the loom catching when turning the steering wheel as while replacing the starter switch I may have caused the loom to be moved, or a loose plug. At least the car is now driveable again.
Kodiaq 1.5tsi mHev. Owners views? Update: Bought a PHEV Kodiaq Instead
Looking at a bigger car cos of twin grand kids coming next year. Brand new Kodiaq 1.5mHev at only A$49k drive away with 7 year warranty. (25k pounds) Economy at 6l/100 seems to good to be true for a 1700kg car. Anyone got experience on whether power is adequate and real world fuel use around town and on a run? The dealers dangled a PHEV in front of us and we fell for it hook, line and sinker
- Yesterday
Leaking coolant - Superb 2.0 Tsi 4x4 2019
Any signs of water on the oil filler cap (possibly white foam rather than droplets), or on the dipstick?
KenM started following Leaking coolant - Superb 2.0 Tsi 4x4 2019
redabout started following Software Update available for Bolero?
redabout joined the community
manosand joined the community
WINDSCREEN
Has anyone found a way to mask the millions of tiny craters in the outer glass of the front windscreen in high mileage cars? They cause a multitude of reflections in bright sunlight to the extent that I've had to almost stop once or twice recently when I couldn't see the road. I have had three Octavias since 2002 and all of them have suffered with this problem, the only way I have found is to replace the screen somehow but with all the electronical gubbins linked to the vRS screen, my insurance company won't guarantee that a replacement will have the same connectivity. i have the same problem with my 2000 BMW 740 which still has the original glass in it.....
SwallownAmazon started following WINDSCREEN
List of VCDS Owners (Previously known as VAG-COM) & VCP Owners
Anyone in south wales still active with VCDS? @Lightrofit
RogueWagon started following List of VCDS Owners (Previously known as VAG-COM) & VCP Owners
1.5 TSi - engine mods - intake / exhaust etc
Wonโt be chasing mega power Stage 1 map be enough
As above, the MQ250 gearbox is absolutely fine - Iโve seen 500nm plus put through it. The only limiting factor is the clutch, which is already happy at 250nm.
Reset tyre pressure monitor with broken screen in 2025 Kamiq
Fantastic, thank you!
Skoda karoq 2026 mag safe charger
You can buy magsafe cases or adhesive magnetic rings. Have a look on Amazon for your phone model.
Rbz5416 started following Skoda karoq 2026 mag safe charger
Ah yes.....good point....it's a Manuelle
I have seen it in my OBDEleven tool. Thanks. AG Falco
AGFalco started following Reset tyre pressure monitor with broken screen in 2025 Kamiq
MQ250 it is
This is a Manual according to first post. Would that still be a DQ250?
Doesnโt bother me about the boys getting it dirty. We do a lot of shows so itโs never clean all the time But the dog smell and hair is what I hate
Fabia ECU kit
Greetings all, hello Alasdair1 I'm glad you've managed to pass those hurdles, the 1.2's never came to Barbados, only the 1.4's in 3 variants, estate, hatch and sedan Anyhow good news all around
JackTurner changed their profile photo
Always good to have a fresh interior. Itโs nice to have the car looking shiny outside but with kids, itโs such a nice place to sit when pristine.
