Past hour
Elroq Vrs Road tax.
Transport Pack, which gives you an inverter, variable boot floor, net programme & other bits
Fabia 2024 SE comfort mpi fault
You are correct that taking on Skoda and a dealership is too stressful but don’t sell yourself short. I do think that the forum is of little help for such situations. The car is not safe for you and it’s not your fault. I suspect that for someone who commutes longer distances and lives in an area with free moving traffic the limp mode issue may never surface. Anybody who has experienced limp mode in heavy traffic would not downplay the seriousness of the matter. There's a lack of empathy by some on here. I live close to a major motorway junction and the motorway is frequently gridlocked. There is heavy traffic almost everywhere. The school run is horrendous and the roads are constantly subject to temporary traffic lights so potholes and small sections can be repaired. The Fabia 4 could achieve 40mph if I averaged over 16mph on a short run. In practice that rarely happens and not because I’m choosing to crawl along in low gears. I would move faster on an electric scooter. A few weeks without the limp mode issue is not grounds for thinking all is well. We are still very uncomfortable driving our Fabia despite the last such breakdown being months ago. We so hope that the software update has removed the problem. Realistically, nobody connected with Skoda is interested. I'd go further and say that our local dealership doesn't understand much about their cars. Sales staff are far more competent than the service dept. The question is what to replace your car with. Not easy to decide but I am sure that cars are no longer built well or with reliability in mind. They are too complicated. I’d keep well away from cars in the VAG group which includes Skoda. Maybe something like the Honda Jazz with a petrol engine is worth a look? Honda no longer produce the petrol version of the Jazz which now has a hybrid power train. The Jazz doesn’t come in 57 varieties like the cars in the VAG lineup. It's basically just one Jazz. Any issues will have been identified and sorted by Honda - unlike with Skoda.
Today
Parts & Accessories
On 14 November I made an online order for Mud Flaps. In SKODA packaging. Borská 3040/47a, 301 00 Plzeň 3, Czechia https://www.skoda-parts.com/ Box arrived today. Good service. Very easy. And most important, much cheaper than UK dealers. As test run worked OK, I've ordered a few more bits.
lazou started following Skoda Rapid 2018 - 5Q0035874C Carplay Setup possible?
Hey there, I've just bought a 2018 Rapid Spaceback with a 5Q0035874C headunit. I was hoping to get CarPlay set up on it but am not entirely sure whether the unit is compatible or whether my current USB port would support wired CarPlay. Has anyone had any success in getting it working with this specific headunit model? It's running SW train version MST2_EU_SK_ZR_P0468T and has 2 SD card slots. Have had a look for whether I can find out the USB port model based on the VIN but no luck. VIN is <Removed by Briskoda admin> Thanks in advance!
Winter roads, ice, snow and wet or dry driving in an EV..
The speed to De-ice, defrost & heat an EV,s interior is my favourite thing about EV,s. Also their ability in winter conditions when the appropriate tyres are fitted.
Lound chiming and flashing white car image
Good news, I've solved the problem! Following an internet search and an AI list of suggestions, I cleaned the boot catch (which didn't look dirty but I cleaned it anyway) and the boot seal (which had some moisture and leaves). Then I turned on the engine and magic! - the flashing and chiming had stopped. I've driven a few miles today with no recurrence.
Thermostat Pipe O Ring
Could you advise how you did it please? Some simple steps and what problems you hit please?
Faulty microswitch in the boot lock or wiring to it.
- Octavia Scout with emerging oil issues
Evolution13 started following Octavia Scout with emerging oil issues
Skoda Swing Firmware Update - MU 8755
Hi @pab567 could you help me with this please ?
Head unit death
Hi All My 2011 octy head unit just died Have a Columbus Been playing up a bit now dead. Been wanting an android up grade so now seems like the time What are these Facebook jobbies like? Android/GPS. Dab plus You see for about £300 Mate had a joying in another car and it was crap Recommendation please
Warrior193 started following Octavia Scout with emerging oil issues
Speed camera POIs in MIB3 maps
After uploading the latest available map version to our SIII I was wondering if anyone with lots of computer knowledge had ever tried to simply copying speed camera data to the raw files and let the car upload them off the USB stick. I am sure that idea would be far too simple.
26DIPP started following Speed camera POIs in MIB3 maps
Battery light 1.0 mpi 59bhp
Could be the wire from alternator. Its the smaller exciter wire. If it breaks (they are prone to) you get no light at preignition. If its broken then the alternator may not be charging properly and causing low battery causing random warning lights. On my old Octavia I had random warning lights some full brightness and others dim. It was the cluster connection that needed cleaned and reseated. Finally worked it out when DPF light came on and as it didnt have one realised it was electrical contact issue. Alasdair
Alasdair1 started following Battery light 1.0 mpi 59bhp
Welcome to the forum. The alternator indicator should light with ignition switched on - then immediately extinguish when the engine starts (alternator supplying power) If you have a multimeter, test the voltage at the battery terminals to check if the alternator is actually supplying power - should be significantly above 13 volts when engine running above idle speed. Lack of indicator light with ignition on, engine not running suggests the indicator itself may have failed.
Warrior193 started following Battery light 1.0 mpi 59bhp
Elroq Vrs Road tax.
Oh, it sure is. Race Blue with Winter Pack and whatever the boot junk kit is called. I wouldn’t have mentioned it otherwise.
barn find felicia pickup.
I get you, but this is so otherly broken in that it's completely functional now and will be replaced by a slightly probably longer lasting one in a few days. it's POSSIBLY the most useless thing I've ever done since being born. At least TRYING to fix something and failing, then buying something is just accepting loss and moving on. Maybe I'll mount the old fixed gear shifter on the garage wall as a testament to my idocy, but tbh the truck on the drive does that fine....
That's like trying to fix something but breaking it more then throwing it away and buying a new one anyway (which I have to admit is sometimes my modus operandi too).
Hi folks, I’m having issues with various warning lights popping up uninvited on the wife’s Fabia, but one is staying annoyingly dim - the battery light. I’m assuming like most cars this comes on during ignition and the goes out on start up normally? Only its not coming on at all. Any guidance much appreciated. Thanks
Tqm started following Battery light 1.0 mpi 59bhp
Enyaq Rattles (VRS) and Canton
I've had the car in today for it - I am about to go and pick it up - its very loud on bad roads and happens pretty much every drive, its really bad. I videoed it several times for the dealer, I have just been told they have done nothing about it and to bring it back when its worse! I'm about to loose my rag! I also have the same one in the drivers door as well.
Tqm joined the community
lazou joined the community
kenton59 started following OBD11 EPB Reset tip after new pads/rotors
I have the OBD11 device without pro subscription. It retracts/"opens" no problem. To reset, pump brakes before "closing" If the parking brake is still flashing try "close" again. It was obvious from short buzzing sound second time around that the first "close" had not quite made it.
Sigh, you're a genius, but I'm so next level I did BOTH
ok, 100% of this post is useless. I gave the snapped bit a tickle to make it shiny Hot snotted it to DEATH on 150A That's an in progress shot, it got a full messy bead all the way around, i didn't bother V grooving it to get full depth because it only needs to last a weekend. Wasted some grease on things: But we're FULLY REBULT! HAHA. That went back under the car and I used the old roll pin to re-attach it to the gearbox, no point wasting the spare I have. I tried using a push back tool on the caliper but it didn't want to do very much so a flat bar in the face of it and a couple of C clamps shoved it in sufficiently. I've not done the left hand side yet, or bled all the brakes properly but look, it drove out of its grave! At the VERY least I can clean that bit of drive now! There was no point doing ANY of this, because new parts will be here next week, BUT I've learned a bunch of stuff, experienced a bunch of stuff, solved some problems and actually fixed the truck. If I couldn't get parts for any reason it's great to know I COULD sort out the ones I have. Honestly the gear shift feels NICE now.
- 1.5TSI Axial bearing (2018 car)
campaign
I had one of those messages, along with the normal software update message (which I think is now solved, but that's another story!) I wasn't able to scan the QR code with my phone as I was driving, and then it went away. As you say, the only change in the app is the profile / smart home section which seems to be offering to link my car to my non-existent smart home app. No idea what this is about unless it is offering to warm the car up before you use it?
