  1. Yesterday
  2. Please do not confuse MIB2 with MIB3. SWaP/FEC has nothing to do with the way the display/interface is implemented—that is something VW handled differently. MIB3 has a completely different architecture, though it does still make use of SWaP/FEC.
  3. I have an MIB2.5 unit, which uses the same principal as MIB3 for FECs and SWaP codes. This is how it shows on mine the Infotainment Service Menu..... apologies for the screen glare.
  4. yep, figured it out from another post on here. just soldered a smalp wire across the contacts and it fixed it
  5. It will be the contact for the switch. It's a common fault. They burn out. I bought a good second hand unit and desoldered it and soldered back into mine ( good unit was white, mine is black)
  6. Kkchan joined the community
  7. Thank you so much for the quick reply, much appreciated 👍🏻
  8. Hello People I'm wondering how easy it would be to install a sub into the back of my Fabia. I understand the ignition live, positive and ground but I'm not 100 percent positive on the speaker wires That's where I would need guidance on. I would look at wiring diagrams but I wouldn't have a donkeys clue what I'm looking at. If any of you guys have done this before can you please tell me what wires id have to tap into that be much appreciated
  9. LucasD0001 joined the community
  10. https://drive.google.com/file/d/1ORlvWbCBzmSpvieLr0O6qrfbT2GVwdax/view?usp=drive_link
  11. Does anyone know if the mod can be undertaken on an early 2016 280? I’m sure it’ll need HW and SW changes but I’d really like to have the flexibility the mod gives.
  12. @CrazySkoda @varooom Hi, @k00ks has confirmed his successful upgrade to 1800 was on HW 040, whereas mine is HW 033. Do you know whether HW 033 supports firmware 1800, and whether your longer upgrade sequence is necessary? I'd really appreciate your advice before attempting anything. Thanks!
  13. @Rainesh @andreiro221 Hi, My car is a 2019 Škoda Scala with Panasonic Bolero MIB3: HW: 033 SW: 0463 SW Train: MEN3_EU_SK370_P9305P Part number: 654035871B I'm trying to fix Android Auto connectivity with my Samsung Galaxy S23+ through a firmware update. Any experience updating HW 033 to 1800? Thanks!
  14. I have exactly the same issue. I tried very hard to remove these boogers during the summer to replace the bulbs and even in 35c heat, they were having none of it. So I’ll try the trim tool, WD40 and two bloody hour trick! 😂
  15. Mine is 040, I can't say if that makes a difference. I'm sure it's no different than installing an OS on a desktop or a Laptop. I had a connectivity issue that was frustrating me, so went through the process. Good luck!
  16. @k00ks Thanks again. Just one final question before I attempt the update: was your unit HW 033 or HW 040? Mine is HW 033, currently on SW 0463. Also, could you confirm that your original SW Train was MEN3_EU_SK370_P9305P, exactly like mine? @CrazySkoda listed additional intermediate versions, whereas you successfully used 0463 → 0469 → 0741 → 0742 → 1790 → 1798 → 1800 Can I safely follow your shorter sequence on HW 033, or are the additional steps necessary? Thanks! @CrazySkoda, do you know whether the same upgrade path to 1800 is safe for HW 033? Really appreciate your help!
  17. Hi everyone, Does anyone happen to have a working Google Drive / MEGA mirror for MQB3_JND_Europe_v1.31.64.zip (or an earlier compatible 1.31.xx JND build)? I have a 2022 Škoda Karoq with the Amundsen MIB3 unit (Device part number: 3V0035820K, Hardware: H22, Software: 0306, current Radio database: 1.30.24). Since Phonostar pulled v1.31.64 from their direct download server, I tried installing v1.31.70 using a clean 16GB FAT32 USB-C stick formatted on Windows with only the extracted Data and Meta folders in the root. It recognises the update, starts checking it, and immediately throws "Software update interrupted" due to the older 0306 firmware signature block. If anyone still has MQB3_JND_Europe_v1.31.64.zip archived and wouldn't mind sharing a link, it would be hugely appreciated! Thanks in advance!
  18. Youngy76 joined the community
  19. Oh my god, I thought I was going crazy. This entire thread healed me but at same time made me mad as I now see this is a factory feature. I was really hoping there was somebody saying "the fix is just a ECU update, or a part replacement". My hope died. I didn't even knew the clutch had problem that needed fixing to begin with. This feature made me so mad I just hate the car at this point. I really do. The clutch and the engine feel like they live in different postal codes. To the people that say "it's just a question of driving it differently", didn't Steve Jobs say "Your holding you phone wrong" whe one of his phones was losing service when you held it differently than usual?
  20. YELLOWCOMBIVRS joined the community
  21. audacity6550 joined the community
  22. @pervp I assume safe to post this here... https://disk.yandex.ru/d/1V1uBTc8ssc3zA
  23. I am going to be looking to move on my 2012 Superb TDI Elegance Estate 4x4 in the next few months and was looking for some guidance regarding what might be a reasonable expectation for what it may be worth if sold privately. Two owners from new with a full service history with stamps and / or receipts for everything. Under 86000 miles - (85???) Key details : 16in REFURBISHED ALLOY WHEELS (WITH A COUPLE OF SCUFFS) 6 SPEED DSG WITH PADDLE SHIFT ON STEERING WHEEL ACOUSTIC FRONT & REAR PARKING SENSORS AND MAXIDOT AIRBAG CURTAIN AIRBAG DRIVER AIRBAG DRIVER KNEE AIRBAG FRONT PASSENGER (CAN BE DEACTIVATED) AIRBAG FRONT SIDE IMPACT ALARM WITH INTERIOR MONITORING AND TILT SENSOR ALL 4 TYRES REPLACED IN 2026 ANTI SLIP REGULATION ANTILOCK BRAKING SYSTEM AUTO DIMMING REAR VIEW MIRROR AUTO LIGHTS AUTOMATIC FUEL SUPPLY CUT OFF IN CASE OF ACCIDENT BODY COLOURED BUMPERS CHROME ROOF RAILS, COLOUR METALLIC GREY COLOUR TOUCHSCREEN MONITOR COLUMBUS RADIO WITH SD CARD READER UP TO 32GB, 6CD CHANGER, MP3 3.5mm AUX IN SOCKET & UPGRADED 10 SPEAKER SOUND SYSTEM CORNERING FOG LIGHTS CRUISE CONTROL CUP HOLDERS IN MID-CONSOLE DAYTIME RUNNING LIGHTS DUAL ZONE CLIMATE CONTROL ELECTRIC WINDOWS FRONT AND REAR WITH CHILD SAFETY SYSTEM ELECTRICALLY ADJUST ADJUSTABLE FRONT SEATS (DRIVERS SEAT WITH MEMORY) ELECTRICALLY ADJUSTABLE & FOLDABLE DOOR MIRRORS ELECTRICALLY OPERATED TAIL GATE WITH NEW STRUTS IN APRIL 2024 ELECTRONIC BRAKE CONTROL ELECTRONIC DIFFERENTIAL LOCK ELECTRONIC STABILITY PROGRAM ENGINE POWER 138 BHP FRONT AND REAR HEAD RESTRAINTS FULL HISTORY SERVICES BY MAIN AGENTS AND LOCAL GARAGES FULL SIZE ALLOY SPARE WHEEL WITH NEW TYRE GEARBOX SERVICED ON 24.02.2026 AT 78,252 MILES HALDEX 4x4 SYSTEM SERVICED ON 24.02.2026 AT 78,252 MILES HALOGEN HEADLIGHTS WITH ADAPTIVE SYSTEM HEATED QUICK CLEAR FRONT WINDSCREEN HEATED HEADLIGHT WASHERS, HEATED LEATHER SEARS FRONT & REAR HEATED REAR WINDOW HEATED WASHER NOZZLES HYDRAULIC BRAKE ASSIST INVOICES FOR PROOF OF ALL WORK ISOFIX (2 Outer Rear Seats) Rear Seatbelts with Pre - Tensioners, LAST SERVICED ON 21.05.2026 AT 80,842 MILES LUGGAGE COMPARTMENT ALUMINIUM SLIDING PARTITION & TETHER SYSTEM MULTI FUNCTION STEERING WHEEL NEW REAR BRAKE PADS AND OFFSIDE DISC NOV 2024 NEW TIMING BELT & WATER PUMP FITTED 04.08.2026 AT 83503 MILES Next MOT due JUNE 2027 PREMIUM GSM III TELEPHONE PREPARATION WITH BLUETOOTH RAIN SENSING WIPERS REMOTE CENTRAL LOCKING RETRACTABLE PARCEL SHELF SAT NAV WITH VOICE CONTROL SKODA SUPERB BESPOKE FLOOR MATS SPLIT FOLDING REAR SEATS WITH CENTRE REAR SEAT BELT SUNSET PRIVACY GLASS FROM B PILLAR THIRD BRAKE LIGHT TRIP COMPUTER MAXIDOT TYRE PRESSURE MONITOR VARIABLE BOOT FLOOR VERY TIDY CONDITION INSIDE AND OUT I would be grateful for genuine advice and considered opinion regarding it's value. Thank you Mark
  24. Brilliant! Was yours also HW 033? Could you please share the firmware download links you used? Thanks!!
  25. Mintynufc joined the community
  26. Hi @pervp , This is exactly where mine was the other day. Get the firmware's for each step. Put them onto a USB stick, one version at a time. (skip 0742 that I did) You should have one folder on your USB root - MEN_EU_SK370.... or similar, inside this you should have 2 folders - Data, and Meta. I used an old 16GB USB with a USBC to USBA adapter cable. Good luck!
  27. Quick update: My SW Train is MEN3_EU_SK370_P9305P. MIB-Helper lists MEN3_EU_SK370_P1185L (MU 1760) as the latest available firmware. Has anyone successfully updated this SW Train to 1760 or 1800?
  28. Ok, don't roast me, there's reasons. I tried butane heating the stuck thingy, dog bone whatsit and actually got the bolt to spin inside it, but somehow it would not come out. I tried beating on it with a hammer, and even shoving it in a vise with a socket over the bolt head and even raging on the vise handle whilst heating it with the torch did NOTHING, but weirdly once again the air hammer is a DEMON and BBBRT and out the bolt came. VERY BROWN. With the addition of a new bolt it's FIIIIXXXEEDDDD. lol All I need to do now is clean the rust off these two halves and hot snot them back together. Now, this is pointless, but the new shifter won't be here till next week and I want to unseize the front brakes. If I can get the sliders moving again (I've done one side already) then I should be able to put the front up on stands and spin the shafts to clean up the brake disks. But I need gears to do that, so here I lie. Also I just want to drive it up and down my drive again. I've really missed being able to do that little thing.
  29. Quick update: My SW Train is MEN3_EU_SK370_P9305P. MIB-Helper lists MEN3_EU_SK370_P1185L (MU 1760) as the latest available firmware. Has anyone successfully updated this SW Train to 1760 or 1800?
  30. Quick update: My SW Train is MEN3_EU_SK370_P9305P. MIB-Helper lists MEN3_EU_SK370_P1185L (MU 1760) as the latest available firmware. Has anyone successfully updated this SW Train to 1760 or 1800?
