Past hour
Ceratec diesel additive to Octavia mk3 2.0 tdi
Hello folks, I am planning to add ceratec engine additive with the engine oil during my next service. But, can I use the additive with Octavia 2.0 tdi mk3 which has a wet clutch? I was confused because Liqui moly website says that the additive is not suitable for wet clutch systems 1) Is the additive only not suitable with dsg gear oil and can be added to engine oil? 2) Is the additive not suitable even to engine oil with wet clutch dsg? 3) Does the engine oil come in contact with wet clutch or gear system? Please let me know if anyone has experience regarding this. Thanks!
Vishwas started following Ceratec diesel additive to Octavia mk3 2.0 tdi
My car's in a bad way
Sorry to hear of your belated issue and I have just scan read the responses but not sure if you have tried to buy a secondhand car privately in the last ten years but there seems to be a lot of unscrupulous people around that offload cars/vans like yours with a serious engine issues. Even heard of a guy who bought a van that had been patched up structural members with cardboard and then painted! Selling to a dealer and being upfront is the honorable thing to do although the buy my car companies are criminal in what they offer punters so I would have offloaded to them if at all possible :)
cello started following My car's in a bad way
A few questions regarding the Kodiaq – brake light, Start-Stop and Travel Assist
I see that many of them are not working good, so i think i’m gonna leave it like it is. Maybe i just buy the memory switch for start/stop so i dont have to push the button 😉
Rear diffuser fins
What a great design and well implemented using the existing diffuser and fasteners! If I didn’t have the Rieger diffuser to go on I’d certainly be in the market for a set. Currently ~£83 posted to the UK. Will keep an eye on these should I change my mind on the Rieger. I’d be keen to hear how they hold up long term. Thanks for highlighting them.
CookieMonster87 started following Rear diffuser fins
AliExpress, good Look That you finde one which good Work
Low remote battery at 2.97 V ?
Can anyone tell me the key fob battery number for my 24 reg kamiq
FERRERS started following Low remote battery at 2.97 V ?
P0078
Hello, 2014vrs tsi, 130000km, got new, always cared for and just got a p0078 code. Idl RPM jumps from 900 to 2000 Anybody already got this code? I hope it is not to expensive
nickytheshaft started following P0078
Ok, now i understand. So i would have to go to somebody who could modify the dataset. What do you think about KLR Emulator for MQB steering wheel? You get the mainboard and just switch it with the original one under the airbag ob steering wheel 🫣😅
Coming back to this because threads that hang around are, well, annoying. So I bought an electric Megane. It's not a hot hatch but it's surprisingly nimble on a back road (as much as a GTE anyway) and as well appointed inside. It's a far nicer cabin than an ID3. A Cupra Born was nice but that infotainment ruins it all. The Renault's cabin feels five years ahead of the VW Group's. I'm surprised how capable and balanced the chassis is. It's no Renaultsport product- it's not even close to VW Golf GTI or Skoda Octavia VRS- but there is some fun in there. Shame it never got a sporty version; I genuinely think it would have had merit.
Today
ahurak joined the community
P0078
@Admin I posted in the wrong section Can you move it to octavia mk3
Second Hand Car - Never been Update (Infotainment systems - 1803)
Where did you find and downloaded the firmware 1941?
RonToorn started following Second Hand Car - Never been Update (Infotainment systems - 1803)
Double act
Hi all , 2008 Fabia 1.4 tdi Coming home from work noticed I had a headlight out . 60 miles to get home so decided to change it with a spare . No luck , headlight still out . Then noticed the park light was also out . Getting suspicious had a look at rear & found the opposite rear lights also out . Indicators , brake , fog & front spot lights still working . Nearside headlight , park light & opposite rear tail light working . So in summary , drivers side headlight , park light & passenger side rear light out . Got home , checked all fuses , all good . Got thinking it must be related to the headlight switch ( 18 years old now so hopefully that ) , so have ordered a new pattern switch arriving tomorrow . However , knowing my luck it won't be that simple , so was wondering if anyone had any other ideas please .
Cheapas started following Double act
RonToorn joined the community
Fitting Towbar to 2023 Karoq
With regard to the cooling mods they vary from nothing required on the 2.0 TSI through a grill without blanking between the fins on some models to an additional cooling fan and the grill. The towing prep is the cable for the electrical socket for the trailer lights and totally unrelated to the cooling mods. The most important thing with any towbar fitted to a Karoq is the coding for thd CANBUS system. Much of the CANBUS system is now behind a security wall and many dealers are not willing to do changes. Karoqs built before 2024 can be coded successfully, as can 2024 Karoqs, for 2025 & 2026 Karoqs it is less clear. There are towbar fitters who will suggest a bypass relay. This might be acceptable for a towbar for use as a bike carrier mounting although parking sensors will still be active and may well detract the bike, but for actual towing will cause issues.
thamestrader started following Fitting Towbar to 2023 Karoq
P0078
Hello, 2014vrs tsi, 130000km and just got a p0078 code. Idl RPM jumps from 900 to 2000 Anybody already got this code? From my app torq, it could be the MAF sensor or throttle position sensor. I hope it is not to expensive
IJWS15 started following Snow socks
Snow socks
I know the ideal solution is a second set of rims, winter tyres and chains but we live in north Nottinghamshire so the ideal solution is overkill. We don’t work so they would be more an emergency get us home than travel 100 miles. Anyone any experience of them?
Merc E-Class E450D, just sayin'...
Was looking at 2/3 year old 220d estates before we found the deal on the superb. A used merc was less than a full price superb but about the same as we paid. What is frightening about the merc is the potential for engine issues, there is a series of videos on Dave’s Auto Centre You Tube channel about trying to fix an oil leak on a 2.0 diesel sprinter - ends up with engine out to do it.
Enyaq preventing charging and resetting charge level
Just wanted to thank everyone who supplied answers here. I've got a '22 Enyaq iV 60 and I was having huge problems with Octopus intelligent Go and an Ohme epod 7kW charger - immediate charging fine, but smart charging failed every time. The car never seemed to wake up for the smart charging times in the middle of the night, although the first smart session which charged for a few minutes on plug-in would work OK. Software version on my car was 3.8, but it was updated before I bought it. I went through the process described here, pulling out fuse 3 for a few minutes - I think I went for 10 minutes - and then replacing. I'm sure I heard an extra 'clunk' at about 6 minutes. Anyway, end result was that it now charges perfectly on smart charging, waking up in the night to charge with no problem. So thank you! that's why forums are great.
dr5urf joined the community
barn find felicia pickup.
It would NOT drive up the ramps, conjunction of dragging brakes and the slope made some GREAT clutch smells. The absolute limit of the jack's reach was enough to wedge a ramp under the front right wheel which gave me just enough room to go investigating. I won't bore you with a whole blog about it, but deblocker xs, a set of punches, and an air hammer were all ultimately successful, but I still feel beaten up. The problem ultimately was a bound up joint in the gear linkage which has been the case since this lump was delivered to me, around page two of this thread my neighbour punished the gear linkage into shifting which is what i think first cracked this bound up weak link, but it's finally gone full bluetooth: I think https://www.ebay.co.uk/itm/187384471604 will get us back on the road, but I'll try and get the existing parts apart before I order, in case I need to raid a breaker for a less rotten example. There's also this option which might be a better choice? https://www.autodoc.co.uk/vika/13157945#selector-shift-rod At least I know what the problem has always been, the root of today's oopsie, and ultimately will have a refreshed gear shifter which should feel like brand new. It does feel like everything is between me and this truck working, but this is actually the hobby I wanted, I may actually be SAD when this thing is 'fixed'
Sportline 85
Latest update is that there is still no build week (I am not concerned about that due to the many report software/infotainment issues) so I am now expecting a Feb or Mar delivery? My dealer guy said that on their internal skoda website there was something about new builds from now on that shouldnt be getting these issues but could not recall exact reason why, but it sounded like something different happening at build stage? Was a bit vague but hoping it is not just sales talk but something beneficial!
turbotoddl3r joined the community
Servicing intervals?
Nothing special with Castrol and it was 0W 20 FS IV that VW went to for 1.0 TSI,s with gpf,s for the WLTP. As it is dealers get Quantum from Fusch. If concerned about high heat stability go non Long Life so 5w 40 FS VW 502 00. As far as VW 504 00 /. 507 or VW 508 00 / 508 00 it matters not if from Comma, Asda, Tesco , Mobile, Miller etc etc just to the spec and approved.
Octavia 3 Haynes workshop manual
- Octavia 3 Haynes workshop manual
the Haynes manual for Fabia mk2 covered the 1.6 TDi 90 bhp CAYB engine in our 2012 Fabia Combi if that's any help.- Headlamp Help Please
No they weren't missing. I removed them to help with the dry out, I just wanted to check where the vent/breather holes were. Apparently, they should have some but no one knows where they are 🤔- Clutch won't disengage (but then it does)
@jonathan.tong Did you find the cause of the problem ?- Vrs rear banjo bolt sizing
