- Bolero firmware update request – 5Q0035840B, MST2_EU_SK_ZR_P0353T to P0369T
Recall on diesel cooling issue?
Thanks for the info, really helpful
- content items count
Nigel7625 joined the community
Permanent disabling of Start-Stop with VCDS - solution!
Best place to buy VCDS?
A TSB from Skoda on cold start behaviour with 1.2 TSI's. Something that Dealership Employees should be able to explain to customers.
Did you fix this problem?
wooliew joined the community
Coding of Steering Wheel controls
Interesting….
Skoda Fabia 1.2TSI Monte Carlo 09/2011 - Electric Windows Fault
Hi. If you need any help with insurance at all then please feel free to drop me a line. Regards, Dan.
Rear Window Heater doesn't stay on?
I have a similar problem, but mine is the fuse overheating. I have cleaned the contacts a few times to little and now to no avail. Any suggestions on how to bypass the allocated fuse or a fix?
Fuel leak from tank
Not sure if or how it might help, but here's an image from an ebay listing for a fuel tank that shows the fairly large array of pipework that may be involved. I guess the fuel feed from pump to filter and fuel return from filter are obvious, then I think the white one that goes past those and down the front of the tank must be the EVAP breather line from charcoal canister heading for the purge valve in the engine bay, and the two connections on the top appear to go to the filler neck fairly close to the filler flap, part of the tank venting system I suppose.
Yes
If it’s as flexible as he claims I wonder if you can code any buttons on standard steering wheel to act as dsg change on a wheel without dsg paddles 🤔
I don’t need but I thought it would be useful for others.
Can i make also
Fabia 2024 SE comfort mpi fault
Hi bazz2004 Thanks for the advice. I had been down the proper legal channels but because there is no solid physical evidence of the fault it's just my word, and I am just a woman! So they had my car in for a few days, gave me a courtesy car, and drove mine around for a couple of hundred of miles and eventually said they thought I was catching the speed limiter switch when flicking the indicator which was on 20mph and gave the same kind of feeling I described during limp mode......I had an awakening.....what am I doing trying to fight this big cooperation with no power behind me except advice from cab over the phone. I'd had enough I took the courtesy car back, was told if I have any more trouble to go back , I took my car and nothing has happened to the fabia in the 2 weeks since. I could not stand the pressure of it any longer, just not worth the stress....and that's exactly what they hope to happen!
As I’m always one to resurrect an old thread… Was browsing instagram the other day and came across a bloke who has made an open source lin to can/can to lin etc adaptor. Universal for any PQ/MQB steering wheel to any steering wheel. looks interesting. https://forbes-automotive.com/products/lin-mfsw-controller https://www.instagram.com/reel/DdR4JF5sBRx/?psln=MTFnbzJ1bjF2MjZzeA== Also doing some very interesting stuff with haldex controllers
Binx1310 started following Coding of Steering Wheel controls
walters407 started following Fuel leak from tank
Fuel leak from tank
Hi. First post here. Hoping someone can help My car is a 1.2 HTP mk 2 2010 Fabia estate. There is a leak from the fuel tank which happens when I am filling it. It only leaks when the tank is just about full. Petrol comes out under the car. Looks like it is emerging at the front of the tank. Looses a couple of litres then stops so the source must be quite high up. Some petrol pools in the well for the fuel pump but it’s definitely not leaking through the pump seal. That leaked petrol seems to get there through a small hole which is in the metal panel under the seat about 6 in back from the fuel pump. Hopefully someone can suggest what the problem. And how easy/difficult a fix it could be. Dropping the tank looks like a right pain….. Thanks!!
Radio cutting out new starter motor
I'd suggest having the battery properly tested first.
Unfortunately, there is little chance of you getting any resolution from a dealership - or Skoda themselves. The service department will run diagnostics which will pick up no faults and their excuse will be something along the lines of – there’s nothing showing as a fault so there’s nothing to fix. You have a low battery level showing on our equipment that may be causing your issues. Or, because you are making too many short journeys the car will have issues. I bought a start-stop CTEK charger and later replaced the battery with a top of the range AGM model. The frequent software and electronic glitches continued and finally another frightening limp mode breakdown. So, I spent a fair amount of money following “expert” advice from Johnson’s Skoda Wolverhampton and got nowhere apart from some pretty confrontational meetings with successive service managers who didn’t stay for very long. I’m pleased that I spent none of this extra money at the dealership. It was a mistake to replace a very old car with a model full of over complicated and glitchy electronics. We live and learn. I’d suggest getting rid of the Fabia in favour of an older low mileage car with basic tech which works. There are loads of cars in our neighbourhood that are about 10 years old and look in pristine condition. Manufacturers used to plug reliability and build quality but cars are no longer built to last. It’s three-year warranties to go with 3-year payment plans. After three years you are expected to “buy” a new car. Effectively it’s never-ending HP for a disposable vehicle. The alternative is to do battle with the dealer and Skoda which will be an exhausting process. The last couple of years were hell for us because the Fabia could have easily let us down in a tricky traffic situation. The size, speed and volume of HGVs on today’s roads is hard to believe. There’s much to be said for getting a car about 10 years old which isn’t riddled with twitchy electronics and software so long as it has a dry timing belt. Skoda did get that bit right with the Fabia. We did get a software update on the drive from an AA silver service technician following the last limp mode episode. So far, the limp mode issue hasn’t recurred. The update fixed an issue with the throttle body assembly and became available mid-2024. It seems that even Skoda trained staff, when servicing cars, fail to check that such updates are available and have been applied. Maybe they just don’t know what’s going on at Skoda or what updates are available for particular models. Our car still does things like changing the digital dash layout at random and giving nonsense guidance for changing gear at particular speeds. It’s hard to know how to proceed but doing nothing isn’t an acceptable option. If they can't fix the issue perhaps insist that the dealer changes the car. Nobody should have to drive a car that they believe has a potentialy lethal fault. Good luck.
Crank voltage across terminals dropped to 10.30V , that's in the 10 to 10.5V range that AI said aftermarket radios shut down. Earth connector - had a look diagonally across engine bay. Only thing I can think of is there is a circular washer that is crumpled / rippled. Might have put it on wrong way place reducing contact area? Other earth points don't have this. Order as follows nut - washer - starter earth cable contact - earth point. Maybe washer goes between last 2? I could add another earth cable between starter and earth point? Starter live wire spade - the starter has a smaller spade. Oddly
All in servicing
My Scala is 3 years old on the 13th,and I will be looking to take out the all in service plan so is it worth waiting until black Friday incase of any discount deals? Thanks Barry
Hello everyone!
I am set to take delivery of a Skoda Fabia Monte Carlo 1.5 TSI (150 hp); delivery is estimated for January 2027. I joined this forum to gather some preliminary information. Once I’ve put a few kilometers on the car, I’ll return to share my impressions—and perhaps ask a few questions.
Dedicated Wifi, which is wired into the main car loom.
Personally I’m not sure but there are plenty on here who would have more knowledge than I! Does it have dcc currently or just standard shocks?
I agree. Would you recommend any particular Bilstein part number for my Greenline Estate? Bearing in mind it sits a little bit lower than the standard car (for the fuel economy). And that it's a comfy spacious cruising car and not a performance model, with the 1.6 TDi engine.
How does the wiring for the new buttons get through the clockspring?
