HaleImp joined the community
Skoda Felicia consuming 250 mA when it is turned off
gagiuntoli replied to gagiuntoli's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanYes, I unmount every connector in the panel and was the main light switch (the one lighting in the picture above). It seems a bit burned on the other side.
Latest what is this collection of errors post
Update on this. Rear donk solved. Bottom droplink bolt on the passenger side wasn't tight (the one bottom right of the 2nd pic). Jacked up the hub so all under load and torqued it up properly. Checked the other side which was ok. As I jacked the hub up and compressed the spring, there was the donk sound but I tried it a couple of times and couldn't see what was moving to make the sound. Did the same after the work was done and silent. Test drive was silent too. Spring looked fine sat in the cup and looked fine under compression so not sure what was up. One thing sorted. Work booked for end of next week - helicoil my dogbone mess, front arb switched to H&R, front topmounts, check the wheel speed sensors then 4wa and hopefully that's it...
Rust around fuel filler door
I was sitting in the warranty managers office reading Skoda's reply to him with attachments from the ombudsman supporting the VW group's stance. They were recent rejections so VW have probably come up with a more robust "excuse" for not coughing up which the ombudsman now agrees with. Missing inspection reports weren't mentioned, purely the location. If it can be rubbed or collect dirt causing corrosion it's a no. He reconned if it was just the small bubble about a half inch into the panel it would have probably been ok but as you can see a small area where the edge of the rubber filler surround meets the bodywork they've decided it is "edge and fold". As you say it's cobblers. My only real option is the ombudsman which I have started but they quote a 6 month wait before they'll even look at it but it appears they'll side with VW anyway. I may have to bite the bullet and get it sorted myself.
Mk 2 Octavia - door strap replacement
It is necessary to drill out the rivets to get to almost everything in the door such as replacing the window winder or door lock - both have been done on mine. The window winder is mounted on that metal panel so you also have to be aware of how to connect and disconnect the glass. It is shown in the Haynes manual. The rivets are a large and non standard size but are easily available from motor factors who stock VAG parts. You may need a larger rivet gun than a diy tool. It may be better to pay a garage for 1 hour of labour. I used an auto electrician as they do this all the time on VAG cars but local garages may not have any experience.
- Skoda Felicia consuming 250 mA when it is turned off
MK4 DSG shifter switch upgrade from the cheap plastic oem job
Has anyone with a mk4 DSG upgraded their shifter switch from the cheap plastic one to somewthing like this? Black Forest IndustriesMK8 GS2 Air Leather (VW MQB Evo Auto/DSG)Get rid of your "chicken nugget" shifter and replace it with an actual knob! Since the introduction of the MK8 Golf platform, Volkswagen's choice of control surfaces has been a sore spot for many owne Would love to see what one looked like installed on a VRS mk4 DSG , shame they don't do a VRS badged version to match the car. They are designed for the Golf mk8 but should fit an octavia, how hard to install one and what will it look like? They do different colour options.
martinpix started following MK4 DSG shifter switch upgrade from the cheap plastic oem job
oajh23 joined the community
- Amundsen MIB1 Firmware update finally completed - MSTD_EU_SK_P6230 MU0490
IlyaKud joined the community
JonEm joined the community
It is cobblers. Not specified anyplace & whoever came up with the tripe needs to show where they come up with this. Skoda have covered nothing, they are at it. Have you seen the Final Decisions of the Ombudsman in writing concerning other claims. There are those that have successfully made claims under the warranty on exactly the same corrosion issue in exactly the same location on the car.
I now have a reason for the claim being rejected. It is corrosion caused by "edge and fold" not from the middle of a panel; if corrosion starts inside on a seam or edge it's tough. Sounds like cobblers to me and not specified in the warranty. I have also now discovered this has been the reason quoted to the motoring ombudsman which they have accepted and then rejected customer appeals. Seems Skoda have covered their backsides and have the ombudsman on their side.
Knocking noise/rattle from DCC - Sportline 2.0 Petrol
Skoda or whoever is telling this nonsense should know that there are vehicles out there that they failed to engineer into the 'Normal operational noise'. Where is this person based and are they an Automotive Engineer or a desk jokey?
Advice for buying a 2018 Karoq 2.0 TDI Edition DSG
Haldex is at 3 years / 30,000 miles. So i would be wanting it done know as well as the Brake Fluid change if not done in the past 2 years. As far as the DSG i would want that now and the Warranty covering it. Not left till 80,000 miles.
Evolution13 started following Advice for buying a 2018 Karoq 2.0 TDI Edition DSG
Fabia 1.4tdi Nightmare issues!
worth a shot. On mine it overboosted and randomly you just heard a very slight blow off sound. Almost like a blip of a siren in the distance then loss of power. Alasdair
Szaki joined the community
From MOT history up until 2022 was doing roughly 10k miles per year, from 2022 yearly mileage is roughly 7k per year, suggesting either a change in circumstances or change of owner. Modern diesels don't like low annual mileages, and the last 4 years between 5k and 8k per year is low, whilst DPF may be OK the EGR valves are prone to clogging with short journeys or low annual mileages, a more likely issue is Ad Blue problems due to crystalisation on the sensors and injector due to low use. Haldex is every 3 years - its nearly due again. more importantly is what were the dates of the previous Haldex services, should have had one in 2021. DSG ask for the oil to be changed and the oil filter to be cleaned - Skoda say every 80k miles - independent specialists advise 40k. Engine oil and filter changes - ideally every 12 months or 10k miles which ever is sooner, consider carefully if the vehicle has been on the Flexible service scheme which extends the intervals to 20k miles or 2 years, so should have had 8 service may only have had 3 or possibly 4. Brake fluid and Coolant should have been changed at least twice if they haven't been done then ask for then to be done. Check the rear tyres for uneven tread wear or an odd wear pattern, assuming the tyres have not been replaced - at around 80K miles the the rear suspension lower arm bushes may have worn - not enough to be an MOT advisory but sufficient to cause uneven tread wear. Cambelt ask for it to be changed along with any other rubber belts (the oil pump is driven by a separate wet belt) , tensioner and water pump if applicable. If they don't want to do this then ask for a warranty to cover the cambelt for the next 50,000 miles. If you are familiar with DSG gearboxes then you will know what it should drive like. If you are not familiar have a really long test drive with lots of stop start traffic, leave the Stop/Start switched ON - even if you don't like it this can expose issues with the DSG. Check Hill Hold and Auto Hold work properly without and with throttle. It should creep smoothly on tickover even up a slight incline in first and reverse.
thamestrader started following Advice for buying a 2018 Karoq 2.0 TDI Edition DSG
Advice on update 0334
Isn't that also known as 'running a business'?
zoe1981 joined the community
Try a factory reset of the infotainment & it should prompt you to set up from scratch. It's a PITA though as you'll lose all your setting, including radio stations & stored destinations in the SatNav. As for the secret solution sent to a dealer, I went through this recently for a different issue & the "fix" didn't work. At least it was covered by warranty. I wouldn't entertain writing the blank cheque being suggested to you.
Rbz5416 started following Advice on update 0334
Skoda dealers are all mercenaries - extract as much as possible from owners seems to be their main aim………
superpatate joined the community
Ja56 joined the community
mr_simon joined the community
Hi everyone! I’m new here, and following this thread with interest. My late-2024 1.5 MHEV (non-DCC) has the same hollow knocking noise. After numerous visits with various attempts to resolve the issue (including changing the top mounts and applying copious amounts of grease to the potential problem areas), the Skoda workshop replaced my steering rack. Like everyone here, the issue was only temporarily resolved, with the knocking sound returning after 2 weeks. Skoda is now saying that this is a ‘normal operational noise’. The Skoda dealership where I’m based (Singapore) is directly owned by the Volkswagen Group. I’d have expected much better technical competence and ability to rectify faults, but that is not the case at all!
For some reason the infotainment system started asking for a pin number. I couldn’t remember it and after 3 attempts I got locked out. Now I get the message no primary user. After trying numerous times to become primary user and following numerous hints on the internet I am no further forward. Every time I start the car I get an email saying that Skoda Connect services are deactivated as the vehicle is in private mode. Even though It is actually set to share my position. I contacted Skoda and was told that they have an update to solve the problems if I book the car into the dealer and let them know who the dealer is they will send an update to that dealer to sort out the problem. I visited the dealer to ask how much this would cost and was told that they would charge an initial Diagnostic charge of £185 plus a charge per hour for doing the update. As they don’t know how long the update would take they couldn’t give me a final cost. I have complained that the cost is extortionate to correct a problem with poorly written software that 100s of people all over the world are complaining about. I am hoping that the OTA update 0334 might solve the problems but there are conflicting reports on whether you only get the update if the car has a primary user registered. I am currently running version 0332.Any advice please.
Skoda News
Skoda boss on his way to Volvo. AutocarSkoda boss Klaus Zellmer named as new CEO of Volvo | AutocarVW Group lifer Zellmer will take over from long-serving Hakan Samuelsson by this time next year
Warrior193 replied to gagiuntoli's topic in Skoda Favorit, Skoda Felicia, Skoda Fun and Skoda FormanIf the ignition switch was fully switching off, I think it a little unlikely that an earth (mass) cable issue would be the cause. I suppose a welded-closed relay contact could be the cause if the ignition switch tests out as Ok - but I'd be testing that switch first.
We're downsizing from a 7 seater and are very interested in this: https://www.autotrader.co.uk/car-details/202609176139141 Dealer says Haldex was done in 2024. DSG is due in the next 5,000-10,000 miles apparently. He says the cambelt hasn't been done and based on Skoda official guidance shouldn't be done until 120,000-130,000. This sounded fishy to me. Is that the case? It's 8 years old so should surely have had at least one cambelt change by now? Any experts that could recommend what I do would be hugely appreciated.
portmanking started following Advice for buying a 2018 Karoq 2.0 TDI Edition DSG
portmanking joined the community
Error: selector lever...
My car now booked to Caffyns in Tunbridge Wells on 29th October, for diagnosis. It is under warranty, so why not?
OTA updates or the impossibility thereof
I keep receiving notices that updates are available, but only when driving and usually within about half mile of home. However, the road is a busy one and there are no areas where you can pull off other than field gateways. When I get home and park the car with the ignition on or engine running, more or less opposite where the router is in the house, I don't get any notices! I can have these updates installed by a dealer, but the last time I did this it cost £145! Any advice to solve these problems would be appreciated.
Seasider started following OTA updates or the impossibility thereof
Thanks mate. I'll get the actuator off or just replace it.
