Everything posted by ords
Rear wiper activating randomly
Scan it for codes.
Octavia Mk3 DPF problems
How old is the car & what engine?
Another strange noise from the front right of the car
OP says he checked it.
When to replace battery?
No hard and fast rule when it comes to batteries. Mines on the original battery, rated at 380A. Whether I'll get any warnings on the dash or stop start won't work or a sudden total failure I don't know. I'll find out one day As you only do short journeys are you able to charge it up now and then?
Did that include coding?
Interior light time-out set after lock
How long?
Can someone tell me if this is normal?
Manual or auto?
MK3 ESTATE Multifunction after loocking the car
What's the condition of the battery? Has it been tested?
2017 Octavia Standard Cruise Control fault
- Multi Function Display (MFD) keeps resetting
- Fan comes on every time I stop the car
Yes, it's doing a regen.- My Octavia and gremlins
Scan it for codes. Get the battery checked. Is it the original battery?- 2017 Octavia Standard Cruise Control fault
- Hands free phone on mute?
Which media system do you have?- Pathetic Rear Wash wipe
What engine do you have? The timing belt advisory replacement has been changed. It's no longer 5 years. There are threads on here about it. There is only one washer pump which does both ends. This is one of them.- 2015 Octavia Mk3 1.6tdi 4WD high mileage maintenance
Power steering is electric, no fluid needed.- Seat heater has BURNED through seat!!!
Maybe some circuits should have an RCB similar to what you get in your house.- Seat heater has BURNED through seat!!!
Doesn't say much for the fuses then.- Know this guage?
Makes sense, but OP says even starting from cold the line can be anywhere and move in either direction.- Engine head problem
Joking aside, I just cannot fault mine. Cambelt & pump are the only things its had done- Engine head problem
https://www.jandeengineering.co.uk/camshaftalignment.html- Opening the tailgate
As far as I know the configuration is with one press on the fob, it's either drivers door only or all five doors.- Gearbox (DQ381) in Emergency Mode
Do you mean you've had NO further problems?- SHOCK ABSORBERS DISASTER
I've done a conversion. can you open it? It's an mp4 file 20240207_172748.mp4.0dd7f48ed2a6b13f83a0479a27d22ce4_x264.mp4- DSG gearbox repair price
Suggest you get it scanned and see what the error codes are. - Multi Function Display (MFD) keeps resetting
