VCP / ODIS help required Suffolk UK
Drop me a PM Either here or on Ross-tech forums, same username.
RNS-510 Columbus Map Update Issue
The DVD drives can be a bit sketchy these days. There used to be an alternative method (Maptool) where you'd use a CD to start the map update and it would pull it from an SD card. Might be worth trying a RNS-510 repairer to see if they can provide the CD/SD combo to update your maps. Random example of a repairer who might be able to help: https://www.ebay.co.uk/itm/296282628527
I'm not super far away and I've got ODIS somewhere, I need to dig out the right laptop and make sure it still works. I've done a parameter upload on my TPMS module previously: Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb Part No SW: 5Q0 907 273 B HW: 5Q0 907 273 So I assume the D rev should be a near identical process. As for the HBA mirror, you need to reflash it rather than recode it based on the instructions here: https://www.drive2.ru/l/606426293524771900/ It's somewhat more risky but might work
Infotainment Model Numbers
Columbus has a nav button... That looks like a swing.
OEM ambient lighting retrofit
As per your other thread, it depends what your kit needs. OEM ambient lighting takes a permanent live feed from fuse 8:
Highway lights (octavia mk2) not switching back to DRL until stopped - is that normal?
That sounds normal to me. I don't remember any adaption channels or other methods to control the speeds at which highway lights turn on/off.
Tourist Mode vs. DLA
Tourist mode will stop your low beam cut off causing other drivers issues. If you leave tourist mode off and DLA on, although your high beams probably won't cause an issue, the low beam will. That's assuming the system will even take cars on the unexpected side into consideration
Add aftermarket ambient light
An OEM kit would connect to permanent power, ground and lin-bus. Probably sharing a fuse with other ambient lighting. I have zero idea what an aftermarket kit would connect to. What do they instructions say...? At a guess it'll want either permanent or switched power and earth. The latter will stop any battery drain but they'll only work with the ignition on.
Use a multimeter?
VCDS Security acces code for 09 control electronics in Superb mk2
What guide are you following? Pretty sure in a MK2 cornering fogs are part of the lcode and not an adaptation channel... Can you post an auto scan and adaption map from 09?
SKODA OCTIVIA TYRE BURST WHILE RUNNING IN CRUISE CONTROL
I had my front left tyre blow out on a pothole recently along a wet motorway at 70mph (~112kph). The car continued in a straight line and I was able to pullover in a controlled manner without issue. Based on that, it feels there is more to your sons incident than your post suggests... Regardless, I would suggest contacting a legal representative who's familiar with Indian laws to see what your options are. I doubt many on this forum have many skills in that area
Memory seat not working!
Based on your existing unit being H06, you probably need a replacement fitting. Get it booked in to a dealer - at least for the Octavia it's TPI 2049942/3
Skoda infotainment systems - are they based on Android?
I think you're vastly over estimating how much VAG/Skoda care about stuff like this Typically, a dealer will only update firmware if the customer complains about an issue and there is a relevant TSB/TPI which addresses that specific complaint. As for the Bolero in a 2019/2020 Octavia, the latest version is 0480 which you may already have. I would be quite surprised if there are any more updates... I posted a copy of the 0480 update TPI a while ago if you want to take a look
It's QNX based rather than android iirc...
Amundsen Mib2 Map Updates 2024
I can't see the village names round me using the latest Europe maps on the last gen of Amundsen running the latest 0480 firmware. Maybe try something like Waze over Android Auto (or carplay) - that does show village names
- 98 replies
- amundsen
- discover media
- maps
- mib
Tagged with:
Headlights , fog lights problem after VCDS changes - need restart some channels.
Check the coding.log to see what changes you made and change them back...
struggling with 2014 standard sat nav system
Sounds like an RNS-315 aka Amundsen+. The maps are copied from an SD card to the units inbuilt storage at which point the SD card is wiped and useless. It's no longer getting updates, the latest is 2020/21 which is V12 if I remember correctly. A dealer will charge loads but there should be a selection on eBay etc...
Dash Central Vent Part Code - 2016 RHD VRS 230
New generation steering wheel swap
If you're capable, you can create you're own adaptor very cheaply. Much like this person has: https://wirer.sk/o3_volant22-modul/ Should be doable for £20-30 by the looks. More info from the codes creator here: https://github.com/GabrielMastny/Skoda_2021MUFUSteeringWheel_Converter/blob/main/README.en.md I don't have any first hand experience but it all looks simple enough...
Alloy options
Loads of options in the accessories brochure See attached. accessories.pdf
Problems with my lights
The forum rules/guidelines state no content should promote illegal activity or infringe on the legal rights of others. Helping folk with cloned/pirated interfaces probably goes against that statement so I tend to leave well alone
Your VCDS version is out of date, can you update to the latest please: https://www.ross-tech.com/vcds/download/current.php
Sounds like you should post a full autoscan from VCDS along with an adaption map from 09
Memory settings not working for seats
Very unlikely... Anything after the TPI date should be 'fixed' from factory. That doesn't mean there isn't another issue though with a separate TPI
Air bag warning light
You'll need diagnostic equipment to check what the cause is and hopefully just clear whatever code caused the airbag light to turn on. Once on, it won't clear itself
