Amundsen MIB2 Firmware Update
38 minutes ago, wowrin said:
Hi I have 5q0035874c h41 0472 what is latest update and is there any problems with updating?
0480 is latest, and 99.9% of people have no trouble with update.
  • Replies 4.7k
  • Views 882.2k
33 minutes ago, ngc2392 said:
Hello guys. just bought a 2020/11 kodiak. next week i go to official service for checks. as i saw there is an update for my vin number (navigation 2022/45). problem is that i don't have any sd slots in the unit in glove box compartment...? i have unit with knobs so probably it is amudsen. i have 3V0035820B, H22 and 0270 software unit if that helps what i have. i am not planning to update here (i dont even know how :). are these firmware updates just thing for home hacks or guys in the service shop also do that during check?
just to know, is there an update for my unit?
thanks.
You should hold down the Menu/Setup button for about 10 seconds to locate your Software Train value, post back value.
You could update at home, dealers usually don't bother unless you make "correct" complaint of some bugs, they match this and then find update and apply.
Thanks I just updated I will test tomorrow at the end was message about connecting some tester but some guy mentioned about it and there could be an error when checking by vcds will see many thanks
Hoi,
is this the last version MST2_EU_SE_ZR_P0369T
Yes there will be a stored error that won't affect operation of the unit.
It can be cleared with VCDS and generating a checksum.
1 hour ago, myirtici said:
Hoi,
Yes
LIke this:
Quote
VCDS CODING:
1) 5F (Infotainment) module, Adaptations, channel: 'Confirmation of installation change'
2) Note your current coding
3) Start Windows calculator and set it to 'Programming mode' and select 'HEX' option
4) Calculation: (current coding) Xor C9D2
5) Change the adaptation channel to the new code (Don't be surprised if it changes back to the original coding, this is normal!)
6) VCDS main screen, 'Auto-Scan'
7) Check for fault codes on all modules and clear the DTCs
Note that VCDS displays your code in 'xx xx' format (small letters and a space character).
You have to remove the space before you calculate your new code.
When you enter your new (calculated) code, insert the space again and use lower cases.
EXAMPLE (don't use these values):
'1a 1a' (original coding of the adaptation channel)
1A1A Xor C9D2 equals D3C8
Enter it as 'd3 c8'
If your original code starts with zero(s) just remove them before calculating (i.e. 0A fb=AFB).
If the new (calculated) code is less than 4 characters, insert zeros in the beginning (i.e. FBB=0f bb).
On 06/04/2023 at 14:53, PetrolDave said:
LIke this:
Thank you guys sorted coded
Hi, could you please send me the latest version for mine if there is one. I am having intermittent issues with android auto not connecting.
Many thanks in advance
@sirhc93 You have PM for 0480 version.
Is there an update available for my unit?
Br,
Raoul
And of course this is what you need, please disregard my previous post.
Br,
Raoul
Absolute legend, many thanks!
Hello Guys,
1st of all Happt Easter for all catolics!
2nd issue.
I have a skoda octavia III 2016, but i dont have car play, i have only mirror link and its not working with my iphone 13. Also sometimes the bluetooth loosing the connection and dont show the call log.
I have uploaded my version of 5Q0 035 864 - MIB2 Skoda Amundsen
Can I get a newer update?
Manny thanks ! 😇
@RaoulE & @myxw0rld Check your PM's in next few minutes.
Dear experts, I'm also looking for latest firmware update. Having currently version 0475 (MIB2 Amundsen in an Octavia III) - see attached picture for details.
Background: I tried out a sw update with a wrong source and the update failed. Since that time I get every 10, 15 or sometimes 20 minutes a strange notification sound during driving. I don't know what triggers this and couldn't find any reason.
It sounds like a message notification sound and I don't know how to get rid of it.
My hope is that an update to latest firmware version could fix this.
Or any other idea or proposal?
Would be really happy to get rid of this nasty thing...
Thanks a lot in advance for any help!
Hi, could I also please ask for MST2_EU_SK_ZR_P0480T ?
I am currently running MST2_EU_SK_ZR_P0475T.
Thank you
@paperbrd @adikovec You both have PM's for 0480 version
On 05/04/2023 at 11:00, varooom said:
@krisopl @omide Sorry I missed your posts, did you still need firmware updates?
I have already updated my unit to 0363, thanks!
Now I'm trying to figure out if I can unlock any features, which require codes, which require MIB STD Toolbox installed, which requires soldering in a one-slot unit - as far as I am aware... Is it correct?
I see "Latest possible firmware: MST2_EU_SK_ZR_P0480T" at mib-helper. Is it worth it? Anything I need to know before upgrading?
21 minutes ago, krisopl said:
.. to 0367, the latest I've found
Hi Everyone,
Any new update for this hardware:
Device part number: 5Q0035864A
Hardware: H24
Software: 0253
I have    MST2_EU_SK_ZR_P0253T
0369 is current version for your Software Train
1 hour ago, Baltazar said:
Hi Everyone,
Hardware: H24
Software: 0253
No, 0253 is still current latest 02xx version
hi Varooom,
Is there any update for H41, 0478 amundsen version? 5Q0035864C
Thank you, Mitcho
Hello,
Not updated Skoda firmware before so please let me know if further info is required, but I would like to know if there is a more up-to-date firmware version available for my unit, and if so would anyone be able to help me out with a copy, please?
Installed SW train version: MST2_EU_SK_ZR_P0472T
Installed SW MU version: 0472
Part number: 5Q0035874C
Software version: H29.319.51_STD2Nav_EU
Many thanks
@Mitcho @joek666 I will send you links to 0480 version of firmware
